Help Needed: Integrating Arduino Modbus TCP Server with C# Modbus TCP Client
Hello everyone,
I'm currently working on a project where I have an Arduino Modbus TCP server and a C# Modbus TCP client. I've managed to get both the server and client code working separately, but I'm having trouble integrating them to establish communication between the two.
Here's a brief overview of what I'm working with:
Arduino Modbus TCP Server:
#include <ArduinoModbus.h>
#include <SPI.h>
#include <Controllino.h>
#include <Ethernet.h>
#include <ArduinoRS485.h>
 byte mac[] = {0xFC, 0x8F, 0xC4, 0x0C, 0x2D, 0x07};
 IPAddress ip(169,254,70,133);
 IPAddress myDns(169,254,70,1);
 IPAddress gateway(169,254,70,1);
 IPAddress subnet(255,255,0,0);
 ModbusTCPServer modbusTCPServer;
 EthernetServer server(502);
const int baudRate=9600;
const int Inputs=16;
const int Outputs=8;
const uint16_t Input_Pins[Inputs]={A0, A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11, A12, A13, 10, 11};    //16 Input-Signale
const uint16_t Output_Pins[Outputs]={CONTROLLINO_D0,CONTROLLINO_D1,CONTROLLINO_D2,CONTROLLINO_D3,CONTROLLINO_D4,CONTROLLINO_D5,CONTROLLINO_D6,CONTROLLINO_D7};   //8 Output-Signale
uint16_t  Inputstate[Inputs];
uint16_t Data[Outputs];
  Ethernet.begin(mac, ip, myDns, gateway, subnet);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    while (true) {
      delay(1); // do nothing, no point running without Ethernet hardware
  server.begin();
  Serial.print("Modbus server address:");
  Serial.println(Ethernet.localIP());
  // start the Modbus TCP server
  if (!modbusTCPServer.begin()) {
    Serial.println("Failed to start Modbus TCP Server!");
    while (1);
  for (int i = 0; i < Inputs; i++) {
    pinMode(Input_Pins[i], INPUT_PULLUP);     //Controllino Inputs set as Input Pullup
    modbusTCPServer.configureInputRegisters(0x00, Inputs);
   for (int i = 0; i < Outputs; i++) {
    pinMode(Output_Pins[i], OUTPUT);          //Controllino Outputs set as Output
    Data[i] = false;
    modbusTCPServer.configureCoils(0x00, Outputs);
  if (Ethernet.linkStatus() == LinkON) {
    Serial.println("Ethernet cable is not connected.");
  if (client) {
  Serial.println("new client");
  modbusTCPServer.accept(client);
  while (client.connected()) {
     modbusTCPServer.poll();
      Inputstate[i] = digitalRead(Input_Pins[i]);
      client.write((uint8_t *)Inputstate, sizeof(Inputstate));
    // Empfangen Sie Coils-Daten vom Client und verarbeiten Sie sie
    if (client.available() >= Outputs) {
      client.readBytes((char *)Data, sizeof(Data));
 if(Inputstate[9] == LOW && Inputstate[11] == LOW && Inputstate[15] == HIGH)              //Sofortabschaltung && keine Störung(Frequenzumrichter) && Sicherungsautomat(eingesichert)
    //Ausgabe der Signale
    if(Inputstate[0] == HIGH)         //Signal Fehler Quittieren
    digitalWrite(Output_Pins[4], HIGH);      //Fehler quittieren
    digitalWrite(Output_Pins[4], LOW);
  client.stop();
C# Modbus TCP Client:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Net;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.Net.Sockets;
namespace ModbusTCPClient
    public partial class Form1 : Form
        private int port = 502;
        private EasyModbus.ModbusClient  modbusTCP;
        private string ipAddress = "169.254.70.133";
        public Form1()
            InitializeComponent();
            modbusTCP = new EasyModbus.ModbusClient();
            modbusTCP.IPAddress = ipAddress;
            modbusTCP.ConnectedChanged += ModbusTCP_ConnectedChanged;
        private void ModbusTCP_ConnectedChanged(object sender)
            buttonReadDiscreteInputs.Enabled = modbusTCP.Connected;
            buttonReadDiscreteCoils.Enabled = modbusTCP.Connected;
            checkBoxC1.Enabled = modbusTCP.Connected;
            checkBoxC2.Enabled = modbusTCP.Connected;
            checkBoxC3.Enabled = modbusTCP.Connected;
            checkBoxC4.Enabled = modbusTCP.Connected;
            checkBoxC5.Enabled = modbusTCP.Connected;
            checkBoxC6.Enabled = modbusTCP.Connected;
            checkBoxC7.Enabled = modbusTCP.Connected;
            checkBoxC8.Enabled = modbusTCP.Connected;
        private void button2_Click(object sender, EventArgs e)
            if (!modbusTCP.Connected)
                modbusTCP.Connect(textBoxIpAddress.Text, (int)numericUpDownPort.Value);
            var data = modbusTCP.ReadDiscreteInputs(0, 16);
            UpdateDiscreteInputs(data);
        private void UpdateDiscreteInputs(bool[] data)
            for (int i = 1; i < data.Length + 1; i++)
                var name = string.Concat("CheckboxDI", i);
                var control = this.Controls.Find(name, true).First();
                if (control is CheckBox myCheckbox)
                    myCheckbox.Checked = data[i - 1];
        private void UpdateCoils(bool[] data)
                var name = string.Concat("CheckboxC", i);
        private void button1_Click(object sender, EventArgs e)
            var data = modbusTCP.ReadCoils(0, 8);
            UpdateCoils(data);
        private void checkBoxC_Click(object sender, EventArgs e)
            if (sender is CheckBox chb)
                int number = Convert.ToInt32(chb.Tag);
                modbusTCP.WriteSingleCoil(number - 1, chb.Checked);
        private void buttonConnect_Click(object sender, EventArgs e)
            if (!IPAddress.TryParse(textBoxIpAddress.Text, out _))
                toolStripStatusLabelMessages.Text = "ip address not valid";
                return;
            try
            catch (Exception ex)
                toolStripStatusLabelMessages.Text = ex.Message;
Network Information:
Ethernet-Adapter Ethernet 4:
Verbindungsspezifisches DNS-Suffix: Verbindungslokale IPv6-Adresse . : fe80::4919:e73c:2add:8203%6 IPv4-Adresse (Auto. Konfiguration): 169.254.70.133 Subnetzmaske . . . . . . . . . . : 255.255.0.0 Standardgateway . . . . . . . . . :
Ping Results:
Ping wird ausgeführt für 169.254.70.133 mit 32 Bytes Daten:
Antwort von 169.254.70.133: Bytes=32 Zeit<1ms TTL=128
Ping-Statistik für 169.254.70.133:
Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
(0% Verlust),
Ca. Zeitangaben in Millisek.:
Minimum = 0ms, Maximum = 0ms, Mittelwert = 0ms
As you can see i can ping the Controllino Maxi Automation, where my Arduino program runs on, but if i test my C# program i keep getting connection timeouts.
I'm not sure if the configuration of my C# Modbus TCP client is correct to communicate with the Arduino Modbus TCP server. Specifically, I'm unsure about how to properly configure the client to read/write data from/to the server. I suspect that the issue might also be related to the network setup or a potential firewall on the company network.
If anyone has experience with integrating Arduino Modbus TCP servers with C# Modbus TCP clients or can offer guidance on how to correctly set up the communication between the two, I would greatly appreciate your help. Any insights, code snippets, suggestions, or resources you could provide would be incredibly valuable.
Thank you in advance for your assistance!
Best regards,
Xiltor
