Help needed with Canarytoken
Hello,
I'm trying to implement a simple honeypot on an ESP8266 board as part of a school project. The idea is the board will act as wi-fi network, running an ftp. The moment the attacker does an ftp request a Canarytoken will trigger, notifying in the process. Unfortunately I'm having difficulty with getting the token to trigger. Would greatly appreciate the help and also if I'm writing in the proper category
// NAPT example released to public domain
#if LWIP_FEATURES && !LWIP_IPV6
#define HAVE_NETDUMP 0
#ifndef STASSID
#define STASSID "Your_Wifi_Network_Name" // set the SSID (name) of the Wi-Fi network the ESP8266 will connect to for internet
#define STAPSK  "Your_Wifi_Network_Password" // set the password of the Wi-Fi network the ESP8266 will connect to for internet
#define NEWSSID  "honeypot_Wifi_Name" // set the name (SSID) of the Wi-Fi network the ESP8266 will create
#define NEWPASS  "honeypot_Wifi_Password" // set the password of the Wi-Fi network the ESP8266 will create
#endif
#include <ESP8266WiFi.h>
#include <lwip/napt.h>
#include <lwip/dns.h>
#include <dhcpserver.h>
#include <ESPCanary.h>
#define NAPT 1000
#define NAPT_PORT 10
#if HAVE_NETDUMP
#include <NetDump.h>
void dump(int netif_idx, const char* data, size_t len, int out, int success) {
  (void)success;
  Serial.print(out ? F("out ") : F(" in "));
  Serial.printf("%d ", netif_idx);
  // optional filter example: if (netDump_is_ARP(data))
    netDump(Serial, data, len);
    //netDumpHex(Serial, data, len);
#endif
String canary = "Your_Canarytoken_URL";  //grab FREE web bug/URL tokens at http://canarytokens.org
String ftp_user = "admin";    //if you replace this with "%" it will accept ANY username
String ftp_pass = "password"; //if you replace this with "%" it will accept ANY password
bool append_ip = false;       //if you are using a canary token, leave this as false
String append_char = "?";     //if you are using a canary token, this doesn't matter
                              //if you are using your own webhook,with a bunch of GET
                              //parameters then you would want this to be "&" so the IP
                              //address becomes the final GET parameter
FtpServer ftpSrv;   //set #define FTP_DEBUG in ESPCanary.h to see ftp verbose on serial
  Serial.printf("\n\nNAPT Range extender\n");
  Serial.printf("Heap on start: %d\n", ESP.getFreeHeap());
#if HAVE_NETDUMP
  phy_capture = dump;
#endif
  // first, connect to STA so we can get a proper local DNS server
  WiFi.mode(WIFI_STA);
  WiFi.begin(STASSID, STAPSK);
    Serial.print('.');
  Serial.printf("\nSTA: %s (dns: %s / %s)\n",
                WiFi.localIP().toString().c_str(),
                WiFi.dnsIP(0).toString().c_str(),
                WiFi.dnsIP(1).toString().c_str());
  // give DNS servers to AP side
  dhcps_set_dns(0, WiFi.dnsIP(0));
  dhcps_set_dns(1, WiFi.dnsIP(1));
  WiFi.softAPConfig(  // enable AP, with android-compatible google domain
    IPAddress(172, 217, 28, 254),
    IPAddress(255, 255, 255, 0));
  WiFi.softAP(NEWSSID, NEWPASS);
  Serial.printf("AP: %s\n", WiFi.softAPIP().toString().c_str());
  Serial.printf("Heap before: %d\n", ESP.getFreeHeap());
  err_t ret = ip_napt_init(NAPT, NAPT_PORT);
  Serial.printf("ip_napt_init(%d,%d): ret=%d (OK=%d)\n", NAPT, NAPT_PORT, (int)ret, (int)ERR_OK);
  if (ret == ERR_OK) {
    ret = ip_napt_enable_no(SOFTAP_IF, 1);
    Serial.printf("ip_napt_enable_no(SOFTAP_IF): ret=%d (OK=%d)\n", (int)ret, (int)ERR_OK);
      Serial.printf("WiFi Network '%s' with password '%s' is now NATed behind '%s'\n", NEWSSID, NEWPASS, STASSID);
  Serial.printf("Heap after napt init: %d\n", ESP.getFreeHeap());
  if (ret != ERR_OK) {
    Serial.printf("NAPT initialization failed\n");
  /////FTP Setup, ensure SPIFFS is started before ftp;  /////////
    if (SPIFFS.begin()) {
        Serial.println("SPIFFS opened!");
        ftpSrv.begin(ftp_user,ftp_pass,canary,append_ip,append_char);    //username, password for ftp.  set ports in ESPCanary.h  (default 21, 50009 for PASV)
#else
#error "NAPT not supported in this configuration"
  Serial.printf("\n\nNAPT not supported in this configuration\n");
#endif
  ftpSrv.handleFTP();
Running ver. 2.3.2 of the IDE.
I've put the proper board information and libraries.
