Hi
I am wishing retrieve some information from my Tado internet thermostat using an ESP8266 and have found this curl command detailed by chap called Terrence Eden (thank you) on his Web Blog:
curl -s "https://auth.tado.com/oauth/token" -d client_id=tado-web-app -d grant_type=password -d scope=home.user -d username="you@example.com" -d password="Password123" -d client_secret=wZa
Being on Windows I have executed this curl using the online "reqbin" service and it returns the information that it promises.
I have tried to convert this curl command into code that will run on the ESP, but it fails as described below:
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <WiFiClientSecureBearSSL.h>
#include <ESP8266HTTPClient.h>
String Host = "https://auth.tado.com/oauth/token";
String PostData = "client_id=tado-web-app&grant_type=password&scope=home.user&username=you@example.com&password=Password123&client_secret=wZa";
std::unique_ptr<BearSSL::WiFiClientSecure>client(new BearSSL::WiFiClientSecure);
if (client) {
// set secure client without certificate
client->setInsecure();
//create an HTTPClient instance
HTTPClient https;
// Set the content type."
https.addHeader("Content-Type", "application/x-www-form-urlencoded");
//Start HTTPS comms"
Serial.println("Start HTTPS comms");
if (https.begin(*client, Host)) {
Serial.println("In https.begin");
// Execute the POST
int httpCode = https.POST(PostData);
if (httpCode > 0) {
// HTTP response
Serial.printf("HTTPS respnse %d\n", httpCode);
// Payload
String payload = https.getString();
Serial.println(payload);
https.end();
Serial.println("Connection failure");
Serial.println("Pausing for a long time.");
delay(1000000);
The ouput from this is:
Start HTTPS comms
In https.begin
HTTPS respnse 401
{"error":"unauthorized","error_description":"Full authentication is required to access this resource"}
Can anyone help me understand what I am doing wrong please?
This is my first attempt at HTTP/HTTPS communication. So please treat me as a complete beginner.
Thank you.
