Help on how to read rc receiver in arduino nano
Hello!!!!
I have just bought a rc receiver to continuo working on my bicopter project.
I was checking google to see how to read the rc receiver and i saw that there different ways to do it.
Can you share some code to read the rc receiver channels on the arduino nano???
Thanks in advance!!!
Marco
These are the links I keep on hand for bringing myself back up to speed.
http://playground.arduino.cc/Code/ReadReceiver
Edit: Uh, pics. Cause cool projects require pics! :slight_smile:
Another edit: What receiver did you get? If it supports PCCM (or any of the single pin protocols) you only need one arduino pin to read it.
As far as i could check the code the problem is that it uses timer uno. The servo library that i use to move the servos also use it so it will cause conflicts.
Am I wrong?
any idea?
What code? And you haven't answered the question about what receiver.
There is a simplified alternative servo library called ServoTimer2.
Steve
Sorry the rc controles is the flysky fs-i6
Read through the second link. He mentions that he does not sue the timer. I admit that I have not run into conflict, but I ended up going a different way. CPPM (I typoed above) lets me use just one pin/interrupt.
Oh, that receiver has iBus.
This library looks like it was written to read that protocol.
What do you mean with "I ended up going a different way" what did you do
Btw some pics
vinceherman:
How should i use this???
Sorry for the stupid question but this is brand new for me
I have not used that library (because I do not have your receiver)
But it has an examples section with code you can try.
Are you comfortable installing a library? I usually fumble around copying it to different locations until my code compiles.
You design looks cool. I would worry that the motors will twist off of the servos. I think you need a bearing on the opposite side from the servo to relieve the load of the motor lift and torque.
Thanks!
What i need to figure out is how to connect the receiver to the arduino. If you have an idea on how to wire it up i will appreciate it
I am new to the rc controller. I have been playing with this bicopter project for a year. I made an arduino app to control it but it is almos imposible to control it.
Thanks for the advice about the motor. i tested it and it seems to work ok
Thanks again,
Marco
I now understand how ibus works
I should connect it to serial (rx) pin
is that right?
Here is an image I hacked up to try to demonstrate.
Yes i understand
Bad news my controller doesnt have ibus
the controler is the Fs-ia6
Any suggestion?
but it is almost impossible to control it.
I see a nano. Is that a gyro behind it?
rossi86m:
Any suggestion?
Ahh. when I looked up the controller that you mentioned, it showed a Fs-ia6B receiver which DOES have iBus. No worries. The link I posted earlier does let you read all the channels with one pin per channel.
Yes for the autolevel. In fact that is working quite well but to control the bicopter with the android app is difficult
