Hello,I am still kind of new to the Arduino so any help is greatly appreciated. I am working on a whole house RFID Entry system. I started out with a Arduino Duemilanove and an ID-20. After getting that working I found the cheaper weatherproof Wiegand RFID readers on ebay and decided to order one to try out.
By Modifying the Crazy People code by Mike Cook I got the general concept working and all seemed well except I needed more digital IO pins to control everything, So i purchased a Mega2560, and uploaded the same sketch. My problem is that The Mega never sends the RFID card data over serial. I can send serial data from the computer to the mega and it operates as expected.
I am thinking this has something to do with the interrupts not directly converting over to the mega, but the documentation for this is almost completely non existent (Or at least I can't find it). I also need to add 1 or 2 more readers but all my attempts failed with errors. (For example, I cannot add a volatile variable &PCMSK3, I get an " 'PCMSK3' was not declared in this scope" error when trying to compile, This is where better documentation would come in, Are these not just unsigned int variables? I thought this line
volatile uint8_t *port_to_pcmask[] = {
&PCMSK0,
&PCMSK1,
&PCMSK2
was the declaration)
Here is the code: (works on Duemilanove but not Mega, yes I changed the settings in the tools menu)
/* Wiegand Lock System derived from Crazy People By Mike Cook April 2009
* 4 RFID readers outputing 26 bit Wiegand code to pins
* Reader A (Front DOOR1) Pins 4 & 5
* Reader B (First DOOR2) Pins 6 & 7
* Reader C (Second DOOR3) Pins 8 & 9
* Reader D (Third DOOR4) Pins 10 & 11?
* Interrupt service routine gathers Wiegand pulses (zero or one) until 26 have been recieved
* Then a sting is sent to processing
#include "pins_arduino.h"
int inByte = 0;
* an extension to the interrupt support for arduino.
* add pin change interrupts to the external interrupts, giving a way
* for users to have interrupts drive off of any pin.
* Refer to avr-gcc header files, arduino source and atmega datasheet.
* Theory: all IO pins on Atmega168 are covered by Pin Change Interrupts.
* The PCINT corresponding to the pin must be enabled and masked, and
* an ISR routine provided. Since PCINTs are per port, not per pin, the ISR
* must use some logic to actually implement a per-pin interrupt service.
/* Pin to interrupt map:
* D0-D7 = PCINT 16-23 = PCIR2 = PD = PCIE2 = pcmsk2
* D8-D13 = PCINT 0-5 = PCIR0 = PB = PCIE0 = pcmsk0
* A0-A5 (D14-D19) = PCINT 8-13 = PCIR1 = PC = PCIE1 = pcmsk1
&PCMSK0,
&PCMSK1,
&PCMSK2
typedef void (*voidFuncPtr)(void);
volatile static voidFuncPtr PCintFunc[24] = { NULL };
volatile static uint8_t PCintLast[3];
* attach an interrupt to a specific pin using pin change interrupts.
* First version only supports CHANGE mode.
void PCattachInterrupt(uint8_t pin, void (*userFunc)(void), int mode) {
uint8_t bit = digitalPinToBitMask(pin);
uint8_t port = digitalPinToPort(pin);
uint8_t slot;
volatile uint8_t *pcmask;
if (mode != CHANGE) {
return;
// map pin to PCIR register
if (port == NOT_A_PORT) {
return;
else {
port -= 2;
pcmask = port_to_pcmask[port];
slot = port * 8 + (pin % 8);
PCintFunc[slot] = userFunc;
// set the mask
*pcmask |= bit;
// enable the interrupt
PCICR |= 0x01 << port;
void PCdetachInterrupt(uint8_t pin) {
return;
else {
port -= 2;
// disable the mask.
*pcmask &= ~bit;
// if that's the last one, disable the interrupt.
if (*pcmask == 0) {
PCICR &= ~(0x01 << port);
// common code for isr handler. "port" is the PCINT number.
// there isn't really a good way to back-map ports and masks to pins.
static void PCint(uint8_t port) {
uint8_t bit;
uint8_t curr;
uint8_t mask;
uint8_t pin;
// get the pin states for the indicated port.
curr = *portInputRegister(port+2);
mask = curr ^ PCintLast[port];
PCintLast[port] = curr;
// mask is pins that have changed. screen out non pcint pins.
if ((mask &= *port_to_pcmask[port]) == 0) {
return;
// mask is pcint pins that have changed.
for (uint8_t i=0; i < 8; i++) {
bit = 0x01 << i;
if (bit & mask) {
pin = port * 8 + i;
if (PCintFunc[pin] != NULL) {
PCintFunc[pin]();
SIGNAL(PCINT0_vect) {
PCint(0);
SIGNAL(PCINT1_vect) {
PCint(1);
SIGNAL(PCINT2_vect) {
PCint(2);
// End of interrupts code and start of the reader code
volatile long reader1 = 0,reader2 = 0, reader3 = 0;
volatile int reader1Count = 0, reader2Count = 0, reader3Count = 0;
void reader1One(void) {
if(digitalRead(4) == LOW){
reader1Count++;
reader1 = reader1 << 1;
reader1 |= 1;
void reader1Zero(void) {
if(digitalRead(5) == LOW){
reader1Count++;
void reader2One(void) {
if(digitalRead(6) == LOW){
reader2Count++;
reader2 = reader2 << 1;
reader2 |= 1;
void reader2Zero(void) {
if(digitalRead(7) == LOW){
reader2Count++;
void reader3One(void) {
if(digitalRead(8) == LOW){
reader3Count++;
reader3 = reader3 << 1;
reader3 |= 1;
void reader3Zero(void) {
if(digitalRead(9) == LOW){
reader3Count++;
pinMode(2, OUTPUT); //Reader 1 LED
pinMode(3, OUTPUT); //Reader 1 Buzzer
pinMode(14, OUTPUT); //Door 1 Unlock
Serial.begin(57000);
// Attach pin change interrupt service routines from the Wiegand RFID readers
PCattachInterrupt(4, reader1One, CHANGE);
PCattachInterrupt(5, reader1Zero, CHANGE);
PCattachInterrupt(6, reader2One, CHANGE);
PCattachInterrupt(7, reader2Zero, CHANGE);
PCattachInterrupt(8, reader3One, CHANGE);
PCattachInterrupt(9, reader3Zero, CHANGE);
delay(10);
// the interrupt in the Atmel processor mises out the first negitave pulse as the inputs are already high,
// so this gives a pulse to each reader input line to get the interrupts working properly.
// Then clear out the reader variables.
// The readers are open collector sitting normally at a one so this is OK
for(int i = 4; i<10; i++){
pinMode(i, OUTPUT);
digitalWrite(i, HIGH); // enable internal pull up causing a one
digitalWrite(i, LOW); // disable internal pull up causing zero and thus an interrupt
pinMode(i, INPUT);
delay(10);
// put the reader input variables to zero
reader1 = reader2 = reader3 = 0;
reader1Count = reader2Count = reader3Count = 0;
digitalWrite(13, HIGH); // show Arduino has finished initilisation
if(reader1Count >= 26){
// Serial.print(" Reader 1 ");Serial.println(reader1,HEX);
Serial.println("A");Serial.println(reader1 & 0xfffffff);
reader1 = 0;
reader1Count = 0;
if(reader2Count >= 26){
Serial.println("B");Serial.println(reader2 & 0xfffffff);
reader2 = 0;
reader2Count = 0;
if(reader3Count >= 26){
Serial.println("C");Serial.println(reader3 & 0xfffffff);
reader3 = 0;
reader3Count = 0;
if (Serial.available() > 0) {
inByte = Serial.read();
if (inByte == 'a') {
delay(10);
digitalWrite(13,LOW);
switch (inByte){
case '1':
digitalWrite(2,HIGH);
digitalWrite(14,HIGH);
delay(3000);
digitalWrite(2,LOW);
digitalWrite(14,LOW);
case '2':
for(int index = 1; index<3 ; index++) {
delay(100);
delay(200);
default:
for(int index = 1; index < 6; index++) {
digitalWrite(3,HIGH);
delay(100);
digitalWrite(3,LOW);
delay(200);
digitalWrite(13,HIGH);
On the PC end I just wrote a simple VB program that receives serial data and decodes the RFID Number into the site code and serial number, and has buttons that trigger the "Grant Access", "Read Error, and "Deny Access" code on the arduino (by sending "a1" , "a2" or "a")
Any ideas why the Mega isn't sending any data? Anybody know of a good set of documentation for interfacing Wiegand and the Arduino? (or a more thorough description of the setup of the interrupts in the crazy people sketch, I am not really new to programming, just to Arduino)
Thanks in advance
-Brad
