Help! Programmer not responding Elegoo Uno R3
Hello! Complete newbie here. My son (12 years old) got the Elegoo Super Starter Kit UNO R3 project. When he tries to upload, he gets the following. Would appreciate any guidance! Thanks!
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: /Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Using core 'arduino' from platform in folder: /Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Detecting libraries used...
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/sketch/Blink.ino.cpp -o /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/2182841911/sketch_merged.cpp
/Users/calebdaniels/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/2182841911/sketch_merged.cpp
Compiling sketch...
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/sketch/Blink.ino.cpp -o /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/cores/arduino_avr_uno_3f069f66b421090f864eeb1523ccf308/core.a
Linking everything together...
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/Blink.ino.elf /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/sketch/Blink.ino.cpp.o /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/../../cores/arduino_avr_uno_3f069f66b421090f864eeb1523ccf308/core.a -L/private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C -lm
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/Blink.ino.elf /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/Blink.ino.eep
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/Blink.ino.elf /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/Blink.ino.hex
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/Blink.ino.elf
Sketch uses 922 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
"/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-P/dev/cu.wlan-debug" -b115200 -D "-Uflash:w:/private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/58EC7ACE2B1D0547951214623EBB2D8C/Blink.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/Users/calebdaniels/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.wlan-debug
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
Failed uploading: uploading error: exit status 1
Hi @zimputi
You selected the wrong port from Arduino IDE's Tools > Port menu. This is a port produced internally by your computer. You must select the port that is produced by the UNO R3 board.
With official boards, the port will be labeled with the board name in the menu (e.g., "COM42 (Arduino Uno)"). In this case, you can be fairly confident that you have identified the port. Select that port from the menu and try uploading again.
With some cheap derivative boards the port will not be labeled. You can positively identify the port using this procedure:
  1. Disconnect the USB cable of the Arduino board from your computer.
  2. Select Tools > Port from the Arduino IDE menus.
  3. Take note of the ports, if any, listed in the menu.
  4. Close the Tools menu.
    :exclamation: The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  5. Connect the Arduino board to your computer with a USB cable.
  6. Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
If the upload still fails, or if no new port appeared after you plugged the Arduino board into your computer, add a reply here to let us know and we'll investigate the problem further.
Thank you. I changed the port (to the only other option of the two that were showing). Now I get the message above and it adds this too:
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/sketch/Blink.ino.cpp -o /dev/null
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/sketch/Blink.ino.cpp -o /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/2680387256/sketch_merged.cpp
/Users/calebdaniels/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/2680387256/sketch_merged.cpp
Compiling sketch...
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/sketch/Blink.ino.cpp -o /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/sketch/Blink.ino.cpp.o
Compiling core...
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/Blink.ino.elf /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/sketch/Blink.ino.cpp.o /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/../../cores/arduino_avr_uno_3f069f66b421090f864eeb1523ccf308/core.a -L/private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1 -lm
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/Blink.ino.elf /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/Blink.ino.eep
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/Blink.ino.elf /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/Blink.ino.hex
/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/Blink.ino.elf
"/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/calebdaniels/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-P/dev/cu.Bluetooth-Incoming-Port" -b115200 -D "-Uflash:w:/private/var/folders/84/g3rwrc155v1fwyj9j07bqc_c0000gn/T/arduino/sketches/06CAE230EF8814E56CF1DF23DB15FAE1/Blink.ino.hex:i"
         Using Port                    : /dev/cu.Bluetooth-Incoming-Port
That is not what I told you to do. Selecting ports at random is not an effective approach. You simply selected another of the internal ports.
If you follow the instructions I provided in my previous reply, there will be one of two outcomes:
  • If you saw a port in the menu at step (6) that was not present at step (3), then you will know that is the port of your board.
  • If you didn't see a new port at step (6), then your board is not producing a port.
Now please add a reply here to tell me which of the two outcomes you received after carefully following my instructions. If it was the first outcome, then tell me the name of the port.
I received the second outcome. It only showed two ports.
You could have a bad USB cable...
You're on a Mac, right? Which one (and what OS version?)
as a 1st sanity check, When you plug in your Uno clone, does the "ON" light turn on? (Orange circle, below)
If that's working, push the "reset" button in the upper left corner. That should cause the "L" led (Pink circle) to flash quickly, about three times. If this works, it confirms that the bootloader is present on the 328 chip (but it's lack wouldn't cause the PORT to not show up, so this is just another "is it completely dead" test.")
The other chip on the board, near the USB connector, could also have problems. I don't THINK that there is an easy way to confirm that it is operating properly (Hmm. that'd be an intersting feature to add; maybe some sort of dance on the Tx/Rx LEDs on first powerup...)
Thank you. The 'on' light turns on when plugged in and reset does show the triple flash...
This is on a MacBook Air running Sonoma 14.5
The only two ports that show are the two that ptillisch said are internal ports.
Please try this troubleshooting procedure and then report your results in a reply on this forum thread:
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
  1. Unplug the USB cable of your Arduino board from your computer if it is currently connected.
  2. Click the Apple logo on the left side of the menu bar at the top of the screen ("Apple menu").
  3. Select "System Settings..." from the menu.
  4. A "System Settings" window will open. Click "General" in the menu on the left side of the window.
    You may need to scroll the menu down to see "General".
  5. Click "About" on the panel at the right side of the "System Settings" window.
  6. The "About" panel will open. Click the "System Report..." button at the bottom of the panel.
  7. The "System Information" window will now open. Select Hardware > USB from the tree on the left side of the window.
  8. Take note of the contents of the "USB Device Tree" panel of the "System Information" window.
  9. Connect the Arduino board to your computer with a USB cable.
  10. Select File > Refresh Information from the menu bar.
Do you see any new device appear in the "USB Device Tree" panel of the "System Information" window after doing the last step?
Yes when I plugged in the Arduino it said "Communication Device:
Product ID: 0x0043
Vendor ID: 0x2341
Version: 0.01
Serial Number: 34330313331351501231
Manufacturer: Arduino (www.arduino.cc)
Location ID: 0x01100000" under a new tab that said communication device.
OK, this tells us that the board is being recognized at the operating system level. So we must now try to discover why it is not being recognized by Arduino IDE.
I'm going to ask you to provide some additional information that might help us to identify the problem.
Please do this:
  1. Select Arduino IDE > Quit Arduino IDE from the Arduino IDE menus if it is running.
  2. Open macOS Launchpad.
  3. Type terminal in the "Search" field.
  4. Click on the "Terminal" icon.
    A "zsh" window will open.
  5. Type the following command in the zsh window:
    "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
  6. Press the Enter key
  7. Wait for Arduino IDE to finish starting.
  8. Switch back to the Terminal window.
  9. Press the Command+A keyboard shortcut.
    This will select all the text in the Terminal window.
  10. Press the Command+C keyboard shortcut.
    This will copy the selected text to the clipboard.
  11. Open a forum reply here by clicking the "Reply" button.
  12. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.
    Code block icon on toolbar
  13. Press the Command+V keyboard shortcut.
    This will paste the output into the code block.
  14. Move the cursor outside of the code block markup before you add any additional text to your reply.
  15. Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Last login: Tue Jul  2 14:14:49 on console
calebdaniels@Calebs-MacBook-Air ~ % "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
2024-07-03 14:20:50.575 Arduino IDE[27928:409885] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T09:53:59.281Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T09:53:59.281Z"}
Starting backend process. PID: 27949
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/calebdaniels/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-07-03T18:20:50.895Z root INFO Backend Object.initialize: 2.5 ms [Finished 0.260 s after backend start]
2024-07-03T18:20:50.897Z root INFO Backend Object.configure: 2.0 ms [Finished 0.260 s after backend start]
2024-07-03T18:20:50.897Z root INFO Backend s.onStart: 0.9 ms [Finished 0.260 s after backend start]
2024-07-03T18:20:50.897Z root INFO Backend s.configure: 0.2 ms [Finished 0.274 s after backend start]
2024-07-03T18:20:50.898Z root INFO Backend d.onStart: 0.1 ms [Finished 0.274 s after backend start]
2024-07-03T18:20:50.898Z root INFO Backend d.configure: 0.1 ms [Finished 0.275 s after backend start]
2024-07-03T18:20:50.898Z root INFO Backend d.initialize: 14.0 ms [Finished 0.275 s after backend start]
2024-07-03T18:20:50.899Z root INFO Backend c.onStart: 0.2 ms [Finished 0.275 s after backend start]
2024-07-03T18:20:50.899Z root INFO Backend a.configure: 2.3 ms [Finished 0.277 s after backend start]
2024-07-03T18:20:50.900Z config INFO >>> Initializing CLI configuration...
2024-07-03T18:20:50.900Z root INFO Backend c.initialize: 0.3 ms [Finished 0.277 s after backend start]
2024-07-03T18:20:50.900Z root INFO Backend R.onStart: 0.4 ms [Finished 0.278 s after backend start]
2024-07-03T18:20:50.900Z config INFO Loading CLI configuration from /Users/calebdaniels/.arduinoIDE/arduino-cli.yaml...
2024-07-03T18:20:50.900Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-07-03T18:20:50.900Z root INFO Backend a.initialize: 0.2 ms [Finished 0.278 s after backend start]
2024-07-03T18:20:50.900Z root INFO Backend w.onStart: 0.5 ms [Finished 0.278 s after backend start]
2024-07-03T18:20:50.900Z root INFO Backend r.configure: 0.9 ms [Finished 0.278 s after backend start]
2024-07-03T18:20:50.900Z discovery-log INFO start
2024-07-03T18:20:50.900Z discovery-log INFO start new deferred
2024-07-03T18:20:50.900Z root INFO Backend d.initialize: 0.2 ms [Finished 0.279 s after backend start]
2024-07-03T18:20:50.900Z root INFO Backend y.onStart: 1.0 ms [Finished 0.279 s after backend start]
2024-07-03T18:20:50.900Z root INFO Backend r.configure: 0.9 ms [Finished 0.280 s after backend start]
2024-07-03T18:20:50.900Z root INFO Backend a.onStart: 0.2 ms [Finished 0.280 s after backend start]
2024-07-03T18:20:50.900Z root INFO Backend h.configure: 0.2 ms [Finished 0.280 s after backend start]
2024-07-03T18:20:50.900Z root INFO Backend s.configure: 0.1 ms [Finished 0.280 s after backend start]
2024-07-03T18:20:50.900Z root INFO Backend l.configure: 0.0 ms [Finished 0.280 s after backend start]
2024-07-03T18:20:50.902Z root INFO Theia app listening on http://127.0.0.1:59702.
2024-07-03T18:20:50.902Z root INFO Finished starting backend application: 1.7 ms [Finished 0.282 s after backend start]
2024-07-03T18:20:50.902Z root WARN The local plugin referenced by local-dir:/Users/calebdaniels/.arduinoIDE/plugins does not exist.
2024-07-03T18:20:50.903Z root WARN The local plugin referenced by local-dir:/Users/calebdaniels/.arduinoIDE/extensions does not exist.
2024-07-03T18:20:50.908Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"/Users/calebdaniels/Library/Arduino15","downloads":"/Users/calebdaniels/Library/Arduino15/staging","user":"/Users/calebdaniels/Documents/Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-07-03T18:20:50.908Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-07-03T18:20:50.908Z config INFO Loaded the CLI configuration.
2024-07-03T18:20:50.910Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/calebdaniels/Library/Arduino15","sketchDirUri":"file:///Users/calebdaniels/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-07-03T18:20:50.910Z config INFO Validating the CLI configuration...
2024-07-03T18:20:50.918Z root INFO Resolve plugins list: 18.5 ms [Finished 0.298 s after backend start]
2024-07-03T18:20:51.007Z daemon INFO time="2024-07-03T14:20:51-04:00" level=info msg="Using config file: /Users/calebdaniels/.arduinoIDE/arduino-cli.yaml"
time="2024-07-03T14:20:51-04:00" level=info msg="arduino-cli version 0.35.3"
time="2024-07-03T14:20:51-04:00" level=info msg="Executing `arduino-cli daemon`"
2024-07-03T18:20:51.031Z daemon INFO Daemon is now listening on 127.0.0.1:59703
{"IP":"127.0.0.1","Port":"59703"}
2024-07-03T18:20:51.031Z daemon INFO Daemon is running.
2024-07-03T18:20:51.099Z daemon INFO time="2024-07-03T14:20:51-04:00" level=info msg="Checking signature" index=/Users/calebdaniels/Library/Arduino15/package_index.json signatureFile=/Users/calebdaniels/Library/Arduino15/package_index.json.sig trusted=true
time="2024-07-03T14:20:51-04:00" level=info msg="Loading hardware from: /Users/calebdaniels/Library/Arduino15/packages"
time="2024-07-03T14:20:51-04:00" level=info msg="Loading package arduino from: /Users/calebdaniels/Library/Arduino15/packages/arduino/hardware"
time="2024-07-03T14:20:51-04:00" level=info msg="Missing signature file" index=/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/installed.json
time="2024-07-03T14:20:51-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-07-03T14:20:51-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-07-03T14:20:51-04:00" level=info msg="Checking existence of 'tools' path: /Users/calebdaniels/Library/Arduino15/packages/arduino/tools"
time="2024-07-03T14:20:51-04:00" level=info msg="Loading tools from dir: /Users/calebdaniels/Library/Arduino15/packages/arduino/tools"
time="2024-07-03T14:20:51-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-07-03T14:20:51-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-07-03T14:20:51-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-07-03T14:20:51-04:00" level=info msg="Loading package builtin from: /Users/calebdaniels/Library/Arduino15/packages/builtin"
time="2024-07-03T14:20:51-04:00" level=info msg="Checking existence of 'tools' path: /Users/calebdaniels/Library/Arduino15/packages/builtin/tools"
time="2024-07-03T14:20:51-04:00" level=info msg="Loading tools from dir: /Users/calebdaniels/Library/Arduino15/packages/builtin/tools"
time="2024-07-03T14:20:51-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-07-03T14:20:51-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-07-03T14:20:51-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-07-03T14:20:51-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-07-03T14:20:51-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-07-03T14:20:51-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries location=platform
time="2024-07-03T14:20:51-04:00" level=info msg="Loading libraries index file" index=/Users/calebdaniels/Library/Arduino15/library_index.json
2024-07-03T18:20:51.225Z daemon INFO time="2024-07-03T14:20:51-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Library/Arduino15/libraries location=ide
time="2024-07-03T14:20:51-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Documents/Arduino/libraries location=user
2024-07-03T18:20:51.430Z root INFO Deploy plugins list: 18.5 ms [Finished 0.810 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-07-03T18:20:52.083Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 165.3 ms [Finished 1.002 s after frontend start]
2024-07-03T18:20:52.115Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-07-03T18:20:54.937Z config INFO The CLI config is valid.
2024-07-03T18:20:54.938Z config INFO <<< Initialized the CLI configuration.
2024-07-03T18:20:54.945Z discovery-log INFO start resolved watching
2024-07-03T18:20:54.950Z daemon INFO time="2024-07-03T14:20:54-04:00" level=info msg="starting discovery builtin:serial-discovery process"
2024-07-03T18:20:54.950Z daemon INFO time="2024-07-03T14:20:54-04:00" level=info msg="starting discovery builtin:mdns-discovery process"
2024-07-03T18:20:54.962Z daemon INFO time="2024-07-03T14:20:54-04:00" level=info msg="started discovery builtin:serial-discovery process"
2024-07-03T18:20:54.962Z daemon INFO time="2024-07-03T14:20:54-04:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:serial-discovery"
time="2024-07-03T14:20:54-04:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2024-07-03T14:20:54-04:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:mdns-discovery"
2024-07-03T18:20:54.991Z daemon INFO time="2024-07-03T14:20:54-04:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
time="2024-07-03T14:20:54-04:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
2024-07-03T18:20:54.992Z daemon INFO time="2024-07-03T14:20:54-04:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2024-07-03T18:20:54.992Z daemon INFO time="2024-07-03T14:20:54-04:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.wlan-debug"
time="2024-07-03T14:20:54-04:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.Bluetooth-Incoming-Port"
2024-07-03T18:20:54.997Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 2830.5 ms [Finished 3.927 s after frontend start]
2024-07-03T18:20:55.002Z daemon INFO time="2024-07-03T14:20:54-04:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
time="2024-07-03T14:20:54-04:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
time="2024-07-03T14:20:54-04:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2024-07-03T18:20:55.004Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.wlan-debug","label":"/dev/cu.wlan-debug","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-07-03T18:20:55.005Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.Bluetooth-Incoming-Port","label":"/dev/cu.Bluetooth-Incoming-Port","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-07-03T18:20:55.019Z root INFO Start frontend contributions: 3136.5 ms [Finished 3.934 s after frontend start]
2024-07-03T18:20:55.019Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-07-03T18:20:55.032Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-07-03T18:20:55.032Z root INFO >>> Restoring the layout state...
2024-07-03T18:20:55.034Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-07-03T18:20:55.034Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///Users/calebdaniels/Documents/Arduino/Blink/Blink.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":38,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":195,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"},\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2024-07-03T18:20:55.034Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-07-03T18:20:55.060Z root INFO [eee4f842-3226-4407-9607-e32c05595193] Waiting for backend deployment: 62.0 ms [Finished 3.990 s after frontend start]
2024-07-03T18:20:55.349Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963) starting instance
2024-07-03T18:20:55.597Z root INFO [eee4f842-3226-4407-9607-e32c05595193] Sync of 23 plugins: 539.4 ms [Finished 4.529 s after frontend start]
2024-07-03 14:20:55.663 Arduino IDE Helper (Renderer)[27952:410071] CoreText note: Client requested name ".NewYork-Regular", it will get TimesNewRomanPSMT rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
2024-07-03 14:20:55.663 Arduino IDE Helper (Renderer)[27952:410071] CoreText note: Set a breakpoint on CTFontLogSystemFontNameRequest to debug.
2024-07-03T18:20:55.750Z root INFO <<< The layout has been successfully restored.
2024-07-03T18:20:55.787Z root INFO Initialize the workbench layout: 724.5 ms [Finished 4.682 s after frontend start]
2024-07-03T18:20:55.788Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-07-03T18:20:55.788Z root INFO [eee4f842-3226-4407-9607-e32c05595193] Loading plugin contributions
2024-07-03T18:20:55.788Z root INFO [eee4f842-3226-4407-9607-e32c05595193] Load contributions of 23 plugins: 35.9 ms [Finished 4.718 s after frontend start]
2024-07-03T18:20:55.802Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-07-03T18:20:55.803Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-07-03T18:20:55.858Z root ERROR [hosted-plugin: 27963] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-07-03T18:20:55.883Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): PluginManagerExtImpl/init()
2024-07-03T18:20:55.883Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-arduino-api@0.1.2 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.920Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(cortex-debug@1.5.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.920Z root INFO [hosted-plugin: 27963] Debugger contribution has been registered: cortex-debug
2024-07-03T18:20:55.921Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-arduino-tools@0.1.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.922Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(cpp@1.52.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.923Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(json@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.924Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(json-language-features@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.925Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-bg@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.925Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-cs@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.926Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-de@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.926Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-es@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.927Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-fr@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.927Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-hu@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.928Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-it@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.928Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-ja@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.928Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-ko@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.929Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-nl@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.929Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-pl@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.929Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-pt-BR@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.929Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-ru@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.929Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-tr@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.930Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-uk@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.930Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-zh-hans@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:55.932Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): initializing(vscode-language-pack-zh-hant@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-07-03T18:20:56.023Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-api/extension/dist/extension.js)
2024-07-03T18:20:56.026Z root INFO [hosted-plugin: 27963] calling activation function on Arduino IDE API for VS Code extensions
2024-07-03T18:20:56.030Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain)
2024-07-03T18:20:56.044Z root INFO [hosted-plugin: 27963] calling activation function on JSON Language Features (built-in)
2024-07-03T18:20:56.047Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/extension.js)
2024-07-03T18:20:56.060Z root INFO [hosted-plugin: 27963] calling activation function on VS Code Arduino Tools
2024-07-03T18:20:56.064Z root INFO [eee4f842-3226-4407-9607-e32c05595193] Starting plugins.
2024-07-03T18:20:56.074Z root INFO [hosted-plugin: 27963] PLUGIN_HOST(27963): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js)
2024-07-03T18:20:56.089Z root INFO [hosted-plugin: 27963] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-07-03T18:20:56.089Z root INFO [hosted-plugin: 27963] calling activation function on Cortex-Debug
2024-07-03T18:20:56.091Z root INFO [hosted-plugin: 27963] GDB server console created
2024-07-03T18:20:56.094Z root INFO [eee4f842-3226-4407-9607-e32c05595193] Start of 23 plugins: 305.0 ms [Finished 5.026 s after frontend start]
2024-07-03T18:20:56.720Z root INFO Frontend application start: 4652.3 ms [Finished 6.100 s after backend start]
Checking for update
2024-07-03T18:20:56.735Z root INFO Replace loading indicator with ready workbench UI (animation): 835.9 ms [Finished 5.556 s after frontend start]
2024-07-03T18:20:56.736Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-07-03T18:20:56.736Z root WARN Linked preference "workbench.colorCustomizations" not found.
2024-07-03T18:20:56.787Z daemon INFO time="2024-07-03T14:20:56-04:00" level=info msg="Updating libraries index"
time="2024-07-03T14:20:56-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-07-03T18:20:56.787Z daemon INFO time="2024-07-03T14:20:56-04:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-07-03T18:20:56.787Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-07-03T18:20:56.788Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-07-03T18:20:56.788Z daemon INFO time="2024-07-03T14:20:56-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-07-03T18:20:56.818Z daemon INFO time="2024-07-03T14:20:56-04:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2024-07-03T14:20:56-04:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-07-03T14:20:56-04:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-07-03T14:20:56-04:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2024-07-03T14:20:56-04:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2024-07-03T14:20:56-04:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2024-07-03T14:20:56-04:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
time="2024-07-03T14:20:56-04:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.14.1"
2024-07-03T18:20:56.818Z root ERROR Failed to get debug config: arduino:avr:uno, undefined Error: Debugging is not supported.
    at Object.callback (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:81196)
    at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:788562)
    at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:784513)
    at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:783958)
    at /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:870080
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
2024-07-03T18:20:56.818Z root ERROR Request checkDebugEnabled failed with error: Debugging is not supported. Error: Debugging is not supported.
2024-07-03T18:20:56.910Z root ERROR ---- !!!SLOW!!! DURATION: search took 173.330 ms. Args: [{"type":"Updatable"}] ----
2024-07-03T18:20:56.910Z root INFO Starting language server: arduino:avr:uno
2024-07-03T18:20:56.968Z daemon INFO time="2024-07-03T14:20:56-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Library/Arduino15/libraries location=ide
2024-07-03T18:20:56.968Z daemon INFO time="2024-07-03T14:20:56-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries location=platform
time="2024-07-03T14:20:56-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Documents/Arduino/libraries location=user
Update for version 2.3.2 is not available (latest version: 2.3.2, downgrade is allowed).
2024-07-03T18:20:57.774Z daemon INFO time="2024-07-03T14:20:57-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Library/Arduino15/libraries location=ide
time="2024-07-03T14:20:57-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries location=platform
time="2024-07-03T14:20:57-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Documents/Arduino/libraries location=user
2024-07-03T18:20:58.192Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Checking signature" index=/Users/calebdaniels/Library/Arduino15/package_index.json signatureFile=/Users/calebdaniels/Library/Arduino15/package_index.json.sig trusted=true
2024-07-03T18:20:58.192Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loading hardware from: /Users/calebdaniels/Library/Arduino15/packages"
2024-07-03T18:20:58.192Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loading package arduino from: /Users/calebdaniels/Library/Arduino15/packages/arduino/hardware"
2024-07-03T18:20:58.193Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Missing signature file" index=/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/installed.json
2024-07-03T18:20:58.195Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-07-03T18:20:58.195Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-07-03T14:20:58-04:00" level=info msg="Checking existence of 'tools' path: /Users/calebdaniels/Library/Arduino15/packages/arduino/tools"
time="2024-07-03T14:20:58-04:00" level=info msg="Loading tools from dir: /Users/calebdaniels/Library/Arduino15/packages/arduino/tools"
2024-07-03T18:20:58.195Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-07-03T18:20:58.195Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-07-03T14:20:58-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-07-03T18:20:58.195Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loading package builtin from: /Users/calebdaniels/Library/Arduino15/packages/builtin"
2024-07-03T18:20:58.195Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Checking existence of 'tools' path: /Users/calebdaniels/Library/Arduino15/packages/builtin/tools"
time="2024-07-03T14:20:58-04:00" level=info msg="Loading tools from dir: /Users/calebdaniels/Library/Arduino15/packages/builtin/tools"
2024-07-03T18:20:58.195Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-07-03T18:20:58.195Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-07-03T18:20:58.195Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-07-03T18:20:58.195Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2024-07-03T18:20:58.196Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-07-03T18:20:58.196Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="sending command QUIT to discovery builtin:serial-discovery"
2024-07-03T18:20:58.196Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="from discovery builtin:serial-discovery received message type: quit, message: OK"
2024-07-03T18:20:58.196Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="killing discovery builtin:serial-discovery process"
2024-07-03T18:20:58.196Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Discovery event channel closed builtin:serial-discovery. Exiting goroutine."
2024-07-03T18:20:58.196Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.wlan-debug","label":"/dev/cu.wlan-debug","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-07-03T18:20:58.196Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.Bluetooth-Incoming-Port","label":"/dev/cu.Bluetooth-Incoming-Port","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-07-03T18:20:58.196Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="killed discovery builtin:serial-discovery process"
time="2024-07-03T14:20:58-04:00" level=info msg="Closed and removed discovery builtin:serial-discovery"
time="2024-07-03T14:20:58-04:00" level=info msg="sending command QUIT to discovery builtin:mdns-discovery"
2024-07-03T18:20:58.196Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="from discovery builtin:mdns-discovery received message type: quit, message: OK"
2024-07-03T18:20:58.196Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="killing discovery builtin:mdns-discovery process"
2024-07-03T18:20:58.196Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
2024-07-03T18:20:58.197Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="killed discovery builtin:mdns-discovery process"
2024-07-03T18:20:58.197Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Closed and removed discovery builtin:mdns-discovery"
2024-07-03T18:20:58.197Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="starting discovery builtin:serial-discovery process"
2024-07-03T18:20:58.198Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="started discovery builtin:serial-discovery process"
2024-07-03T18:20:58.198Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:serial-discovery"
2024-07-03T18:20:58.201Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2024-07-03T18:20:58.201Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
2024-07-03T18:20:58.201Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2024-07-03T18:20:58.201Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="starting discovery builtin:mdns-discovery process"
2024-07-03T18:20:58.202Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.wlan-debug"
2024-07-03T18:20:58.202Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.Bluetooth-Incoming-Port"
2024-07-03T18:20:58.202Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.wlan-debug","label":"/dev/cu.wlan-debug","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-07-03T18:20:58.202Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.Bluetooth-Incoming-Port","label":"/dev/cu.Bluetooth-Incoming-Port","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-07-03T18:20:58.203Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="started discovery builtin:mdns-discovery process"
2024-07-03T18:20:58.203Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:mdns-discovery"
2024-07-03T18:20:58.206Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
2024-07-03T18:20:58.206Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
time="2024-07-03T14:20:58-04:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2024-07-03T18:20:58.206Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries location=platform
2024-07-03T18:20:58.206Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Loading libraries index file" index=/Users/calebdaniels/Library/Arduino15/library_index.json
2024-07-03T18:20:58.310Z daemon INFO time="2024-07-03T14:20:58-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Library/Arduino15/libraries location=ide
time="2024-07-03T14:20:58-04:00" level=info msg="Adding libraries dir" dir=/Users/calebdaniels/Documents/Arduino/libraries location=user
Is anyone able to provide any more assistance or tips on this topic? Any help is greatly appreciated!
I wanted to check in again to see if anyone can offer any advice so that my son can make use of his kit? Thanks.
Since MacOS seems to see the board, but the IDE doesn't, you could try loading an older IDE (1.8.19 is the latest "old IDE", I think.)
I don't have anything as new as Sonoma, but if you open a terminal window and do "ls /dev/tty*" do you see anything called "/dev/tty.usbmodem..."
How do I download an older IDE?
It should be at the bottom of the software page, labeled "Legacy IDE"
My wife has a M1 MacBook Air with Sonoma; if I track down the cables and adapters I need to connect its USB-C port to my USB-B Arduino, I'll play with it some...
Thank you so much! We have been struggling with this for over a month now. we can now download stuff onto the Arduino
