Upload fails: "stk500_recv(): programmer is not responding"
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\Ghost\AppData\Local\Temp\arduino\sketches\C9AD78DF866D65BFB310C2F72A5D0006\sketch\yeneee2.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src C:\Users\Ghost\AppData\Local\Temp\arduino\sketches\C9AD78DF866D65BFB310C2F72A5D0006\sketch\yeneee2.ino.cpp -o nul
Alternatives for LiquidCrystal.h: [LiquidCrystal@1.0.7]
ResolveLibrary(LiquidCrystal.h)
  -> candidates: [LiquidCrystal@1.0.7]
C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\Ghost\AppData\Local\Arduino15\libraries\LiquidCrystal\src C:\Users\Ghost\AppData\Local\Temp\arduino\sketches\C9AD78DF866D65BFB310C2F72A5D0006\sketch\yeneee2.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\utility\twi.c
Using cached library dependencies for file: C:\Users\Ghost\AppData\Local\Arduino15\libraries\LiquidCrystal\src\LiquidCrystal.cpp
Generating function prototypes...
C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\Ghost\AppData\Local\Arduino15\libraries\LiquidCrystal\src C:\Users\Ghost\AppData\Local\Temp\arduino\sketches\C9AD78DF866D65BFB310C2F72A5D0006\sketch\yeneee2.ino.cpp -o C:\Users\Ghost\AppData\Local\Temp\4103106842\sketch_merged.cpp
C:\Users\Ghost\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Ghost\AppData\Local\Temp\4103106842\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Ghost\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Ghost\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Ghost\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\Ghost\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\Ghost\\AppData\\Local\\Arduino15\\libraries\\LiquidCrystal\\src" "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006\\sketch\\yeneee2.ino.cpp" -o "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006\\sketch\\yeneee2.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
Using previously compiled file: C:\Users\Ghost\AppData\Local\Temp\arduino\sketches\C9AD78DF866D65BFB310C2F72A5D0006\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\Ghost\AppData\Local\Temp\arduino\sketches\C9AD78DF866D65BFB310C2F72A5D0006\libraries\Wire\utility\twi.c.o
Compiling library "LiquidCrystal"
Using previously compiled file: C:\Users\Ghost\AppData\Local\Temp\arduino\sketches\C9AD78DF866D65BFB310C2F72A5D0006\libraries\LiquidCrystal\LiquidCrystal.cpp.o
Compiling core...
Using precompiled core: C:\Users\Ghost\AppData\Local\Temp\arduino\cores\arduino_avr_uno_5964c7bbeaff6a740eae26e39b5825ca\core.a
Linking everything together...
"C:\\Users\\Ghost\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006/yeneee2.ino.elf" "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006\\sketch\\yeneee2.ino.cpp.o" "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006\\libraries\\LiquidCrystal\\LiquidCrystal.cpp.o" "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006/..\\..\\cores\\arduino_avr_uno_5964c7bbeaff6a740eae26e39b5825ca\\core.a" "-LC:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006" -lm
"C:\\Users\\Ghost\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006/yeneee2.ino.elf" "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006/yeneee2.ino.eep"
"C:\\Users\\Ghost\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006/yeneee2.ino.elf" "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006/yeneee2.ino.hex"
Using library Wire at version 1.0 in folder: C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
Using library LiquidCrystal at version 1.0.7 in folder: C:\Users\Ghost\AppData\Local\Arduino15\libraries\LiquidCrystal
"C:\\Users\\Ghost\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\Ghost\\AppData\\Local\\Temp\\arduino\\sketches\\C9AD78DF866D65BFB310C2F72A5D0006/yeneee2.ino.elf"
Sketch uses 4160 bytes (12%) of program storage space. Maximum is 32256 bytes.
Global variables use 214 bytes (10%) of dynamic memory, leaving 1834 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM8" -b115200 -D "-Uflash:w:C:\Users\Ghost\AppData\Local\Temp\arduino\sketches\C9AD78DF866D65BFB310C2F72A5D0006/yeneee2.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Ghost\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM8
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x47
avrdude done.  Thank you.
Failed uploading: uploading error: exit status 1
Please don't hijack threads @tinsaeg. I have split your post out to its own topic.
Hijacking is against the Arduino forum rules. The reason is that it may sidetrack the discussion, even preventing the creator of the topic from getting the assistance they need. It also reduces your own chances of getting assistance.
This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Hi @tinsaeg. Please add a reply here on this forum thread to tell us which Arduino board you are using.
Please be as specific as possible as some Arduino boards with similar names have significant differences and the forum helpers can only provide effective assistance if we are aware of which one is being used.
If you aren't sure how to describe which board you are using, you can provide the link to the online product listing you bought the board from and we'll proceed based on the information found there.
