Help Rename the arduino leonardo DIY
Hello friends, I have a problem... I want to change the name of my "Arduino Leonardo" that appears in the printer area that says, I already changed the values in board.txt and it still doesn't work.
my arduino is a ProMicroAtmega32u4-MU.
The code I use in joystick mode is this.
solved!!!, the solution is to look for the folder from: C:\Users\miguel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5... from there you have to replace the "board": D If the AppData folder does not appear, it is because it is hidden and you have to enter the folder option and then
See.
and brand
show hidden files and
uncheck:
Hide files protected by the operating system.
and ready.
Great :+1:
Be aware that an update of the board package will undo those changes (you already seem to be a version behind). Although a bit messy (I had to learn some things), this topic might be useful in future: Change board name, multiple boards of the same type. It possibly goes a bit further than what you need.
