Hello everyone new to Arduino and new to coding. I downloaded an Arduino menu library from github and I am receiving an error in the downloaded code attached below. I probably could have figured it out myself but perhaps you big brain experts could save me some time. As stated in title 'INT_MODE_TYPE' not declared for line 113. My first instinct was to attach unit8_t in that incorrect line of code but it didn't fix the problem so here I am. A general explanation of why this error is occurring would be appreciated as well as a replacement of corrected line of coding. Thanks in advanced guys and gals. *Updated error message added
Rui Azevedo - ruihfazevedo(@rrob@)gmail.com
adapted from: http://playground.arduino.cc/Main/PcInt
with many changes to make it compatible with arduino boards (original worked on Uno)
not tested on many boards but has the code uses arduino macros for pin mappings
it should be more compatible and also more easy to extend
some boards migh need pcintPinMap definition
Sept. 2014
small changes to existing PCINT library, supporting an optional cargo parameter
Nov.2014 large changes
- Use arduino standard macros for PCINT mapping instead of specific map math, broaden compatibility
- array[a][b] is 17% faster than array[(a<<3)+b], same memory
- reverse pin mappings for pin change check (not on arduino env. AFAIK)
#ifndef ARDUINO_PCINT_MANAGER
#define ARDUINO_PCINT_MANAGER
#if ARDUINO < 100
#include <WProgram.h>
#else
#include <Arduino.h>
#endif
#include "pins_arduino.h"
typedef void (*voidFuncPtr)(void);
#define HANDLER_TYPE mixHandler
/*#if (defined (_mk20dx128_h_) || defined (__MK20DX128__)) && defined (CORE_TEENSY)
#define RSITE_TEENSY3
#endif
defined(RSITE_TEENSY3) || defined(ARDUINO_SAM_DUE)*/
#if defined(__arm__) || defined(ESP8266) || defined(ESP32)
#warning Compiling for arm
#define PCINT_NO_MAPS
#endif
#ifndef PCINT_NO_MAPS
// PCINT reverse map
#if defined(digital_pin_to_pcint)
#define digitalPinFromPCINTSlot(slot,bit) pgm_read_byte(digital_pin_to_pcint+(((slot)<<3)+(bit)))
#define pcintPinMapBank(slot) ((uint8_t*)((uint8_t*)digital_pin_to_pcint+((slot)<<3)))
#else
#warning using maps!
#if ( defined(__AVR_ATmega328__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega16u4__) )
//UNO
const uint8_t pcintPinMap[3][8] PROGMEM={{8,9,10,11,12,13,0x80,0x80},{14,15,16,17,18,19,20,21},{0,1,2,3,4,5,6,7}};
#elif ( defined(__AVR_ATmega2560__) )
const uint8_t pcintPinMap[3][8] PROGMEM={{53,52,51,50,10,11,12,13},{0,15,14,0x80,0x80,0x80,0x80,0x80},{A8,A9,A10,A11,A12,A13,A14,A15}};
#elif ( defined(__AVR_ATmega1284P__) || defined(__AVR_ATmega1284__) || defined(__AVR_ATmega644__))
#error "uC PCINT REVERSE MAP IS NOT DEFINED, ATmega1284P variant unknown"
//run the mkPCIntMap example to obtain a map for your board!
#else
#warning "uC PCINT REVERSE MAP IS NOT DEFINED"
#endif
#define digitalPinFromPCINTSlot(slot,bit) pgm_read_byte(pcintPinMap+(((slot)<<3)+(bit)))
#define pcintPinMapBank(slot) ((uint8_t*)((uint8_t*)pcintPinMap+((slot)<<3)))
#endif
#define digitalPinFromPCINTBank(bank,bit) pgm_read_byte((uint8_t*)bank+bit)
#endif
//this handler can be used instead of any void(*)() and optionally it can have an associated void *
//and use it to call void(*)(void* payload)
struct mixHandler {
union {
void (*voidFunc)(void);
void (*payloadFunc)(void*);
} handler;
void *payload;
inline mixHandler():payload(NULL) {handler.voidFunc=NULL;}
inline mixHandler(void (*f)(void)):payload(NULL) {handler.voidFunc=f;}
inline mixHandler(void (*f)(void*),void *payload):payload(payload) {handler.payloadFunc=f;}
inline void operator()() {payload?handler.payloadFunc(payload):handler.voidFunc();}
inline bool operator==(void*ptr) {return handler.voidFunc==ptr;}
inline bool operator!=(void*ptr) {return handler.voidFunc!=ptr;}
#ifdef PCINT_NO_MAPS
#if defined(__STM32F1__) || defined(__STM32F4__) // https://github.com/rogerclarkmelbourne/Arduino_STM32
#define INT_MODE_TYPE ExtIntTriggerMode
#define NUM_DIGITAL_PINS BOARD_NR_GPIO_PINS
#else
#define INT_MODE_TYPE uint8_t
#endif
extern HANDLER_TYPE PCintFunc[NUM_DIGITAL_PINS];
template<uint8_t N> void PCint() {PCintFunc[N]();}
#else
void PCattachInterrupt(uint8_t pin,HANDLER_TYPE userFunc, uint8_t mode);
void PCdetachInterrupt(uint8_t pin);
// common code for isr handler. "port" is the PCINT number.
// there isn't really a good way to back-map ports and masks to pins.
// here we consider only the first change found ignoring subsequent, assuming no interrupt cascade
// static void PCint(uint8_t port);
#endif
* attach an interrupt to a specific pin using pin change interrupts.
template<uint8_t PIN>
void PCattachInterrupt(HANDLER_TYPE userFunc, INT_MODE_TYPE mode) {
PCintFunc[PIN]=userFunc;
attachInterrupt(digitalPinToInterrupt(PIN),PCint<PIN>,mode);
#else
PCattachInterrupt(PIN,userFunc,mode);
#endif
void PCdetachInterrupt() {
detachInterrupt(PIN);
#else
PCdetachInterrupt(PIN);
#endif
#endif
ERROR CODE BELOW
`C:\Users\jojom\AppData\Local\Temp\.arduinoIDE-unsaved2023021-17876-ahqprk.kdtr\sketch_jan21b\sketch_jan21b.ino:113:48: error: 'INT_MODE_TYPE' has not been declared
exit status 1
Compilation error: 'INT_MODE_TYPE' has not been declared`
