Hi im 100% new to Arduino and trying to build my first project that I purchased from someone it’s a game
It’s called plasma ball this is the diagram and I fallow it to the " T " but when im trying to install the code its not working. can anyone please help me with it. what it does when u hold both of the plasma ball together it trigger actuator up when u touch it and when u let it go its go down but the problem when I try to upload the code i`m keep getting error messages can someone please help me with it and see why its not letting me upload the code im using the Arduino UNO r4 wifi thank you : (
This is the code –
* Dual Plasma Ball
* This sketch is an escape room puzzle in which players must simultaneously place their hands on two plasma balls,
* in order to make a linear actuator rise up. When a plasma ball is touched, the current through it rises, and this
* is detected using an IN219 sensor.
// DEFINES
#define DEBUG
// INCLUDES
// Arduino library for I2C connection
#include <Wire.h>
// Current sensor library. See https://github.com/johngineer/ArduinoINA219
#include "src/INA219/INA219.h"
// Since the INA219 reading can be a bit noisy, we'll smooth out values using a running average of a value
#include "src/RunningAverage/RunningAverage.h"
// CONSTANTS
// You can use up to 16 IN219 devices on the same I2C bus, so long as each is assigned a unique
// address as described in the datasheet http://www.ti.com/lit/ds/symlink/ina219.pdf
const byte numSensors = 2;
const byte relayPins[2] = {A0, A1};
// GLOBALS
// Declare the array of sensors
INA219 sensors[numSensors] = {
INA219(0x40), // Default I2C address
INA219(0x44) // I2C address when jumper A1 has been bridged to GND
// An array to record the starting reading of each sensor
float baseReading[numSensors];
// Array of running averages to smooth readings
RunningAverage averageReadings[numSensors] = {
RunningAverage(5),
RunningAverage(5)
// The amount by which power measured on each circuit needs to deviate
// to be interpreted as a touch on the plasma ball
float tolerance = 0.05;
void setup(void) {
#ifdef DEBUG
Serial.println(F("Starting setup..."));
#endif
// Setup the sensors
for(int i=0;i<numSensors;i++){
// Explicitly clear the running average value
averageReadings[i].clear();
// Start the sensor, with default configuration (range of <32V, <2A)
// If you only need to monitor lower values, you can increase precision by reducing this range
sensors[i].begin();
// Sample each sensor several times to get the average base reading
for(int j=0; j<numSensors; j++){
for(int k=0; k<5; k++){
averageReadings[j].addValue(sensors[j].busPower());
delay(50);
// Assign the running average value to the array
baseReading[j] = averageReadings[j].getAverage();
#ifdef DEBUG
Serial.print(F("Sensor "));
Serial.print(j);
Serial.print(F(" initialised with base reading "));
Serial.println(baseReading[j]);
#endif
// Initialise the relay pins
for(int i=0;i<2;i++){
pinMode(relayPins[i], OUTPUT);
digitalWrite(relayPins[i], LOW);
#ifdef DEBUG
Serial.println(F("Setup complete."));
#endif
// Pause to let everything stabilise before running the main program loop
bool allBallsBeingTouched() {
// If all the balls are being touched, then all sensor readings should be outside the
// tolerance limit from their base (untouched) readings. Put another way, if any sensor
// reading is *within* the tolerance, then all the balls can't be being touched:
for(int i=0; i<numSensors; i++) {
if((averageReadings[i].getAverage() - baseReading[i]) < tolerance) {
return false;
return true;
/* Make the linear actuator extend */
void extend() {
digitalWrite(relayPins[0], LOW);
digitalWrite(relayPins[1], HIGH);
/* Make the linear actuator contract */
void contract() {
digitalWrite(relayPins[0], HIGH);
digitalWrite(relayPins[1], LOW);
/* Main program loop */
void loop(void) {
// Loop over each sensor
for(int i=0; i<numSensors; i++){
// The bus power is the total power used by the circuit under test, as measured between GND and V-
float busPower = sensors[i].busPower();
// Add the current reading to the running array
averageReadings[i].addValue(busPower);
#ifdef DEBUG
Serial.print(averageReadings[i].getAverage());
// Put comma delimiter between values
if(i<numSensors-1) {Serial.print(",");}
#endif
#ifdef DEBUG
Serial.println("");
#endif
// Activate the actuator based on the inputs
if(allBallsBeingTouched()) {
extend();
else {
contract();
// Introduce a slight delay before next polling the sensors
delay(100);
This is the diagram
this is the erorr message that im getting
C:\Users\Global W design\OneDrive\Desktop\Arduino projects\PLASMA GAME\ARDUINO_CODE___PlasmaBall_copy_20240601141125\ARDUINO_CODE___PlasmaBall_copy_20240601141125.ino:29:14: error: invalid conversion from 'int' to 'INA219::t_i2caddr' [-fpermissive]
In file included from C:\Users\Global W design\OneDrive\Desktop\Arduino projects\PLASMA GAME\ARDUINO_CODE___PlasmaBall_copy_20240601141125\ARDUINO_CODE___PlasmaBall_copy_20240601141125.ino:16:0:
C:\Users\Global W design\OneDrive\Desktop\Arduino projects\PLASMA GAME\ARDUINO_CODE___PlasmaBall_copy_20240601141125\src\INA219\INA219.h:128:5: note: initializing argument 1 of 'INA219::INA219(INA219::t_i2caddr)'
INA219( t_i2caddr addr = I2C_ADDR_40 ///< Device address.
C:\Users\Global W design\OneDrive\Desktop\Arduino projects\PLASMA GAME\ARDUINO_CODE___PlasmaBall_copy_20240601141125\ARDUINO_CODE___PlasmaBall_copy_20240601141125.ino:30:14: error: invalid conversion from 'int' to 'INA219::t_i2caddr' [-fpermissive]
exit status 1
Compilation error: invalid conversion from 'int' to 'INA219::t_i2caddr' [-fpermissive]
