Help with Audio player
I'm trying to play audio through a speaker (8 ohm 0.25w) via an amplification module (lm386). The sounds come from a 32gb sd card in a micro sd adapter connected to the arduino. Each file is an 8 bit wav 88200 mhz. Every time I run the code I wrote it makes a "cilck" noise, then sort of hums/buzzes, not playing the required sounds.
#include <SPI.h>     // include Arduino SPI library
#include <SD.h>      // include Arduino SD library
#include "TMRpcm.h"  // include TMRpcm library
TMRpcm audio;
void setup(void) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(10)) {
    Serial.println("failed!");
    while(true);  // stay here.
  Serial.println("OK!");
  audio.speakerPin = 3;
  audio.setVolume(7);
  audio.play("1.wav");
// main loop
Here's a wiring diagram
Doesn't the SD card require a ground connection?
I believe that a Uno is limited to 9 as speakerPin.
