Problem playing .wav file
I am trying to play a .wav file on an Arduino Uno. I get no output from the speaker. It appears to be reading the SD card, as it does not return a fail on the serial monitor.
I believe the speaker is wired correctly, as it played some noise when I ran some other code. I am not familiar with the MicroSD card reader or audio conversion, so any help would be appreciated.
I tried to follow this tutorial:
My .wav settings are: 16000hz, Mono, PCM unsigned 8 bit
#include "SD.h"
#define SD_ChipSelectPin 4
#include "TMRpcm.h"
#include "SPI.h"
TMRpcm tmrpcm;
void setup(){
tmrpcm.speakerPin = 9;
Serial.println("i turned on");
if (!SD.begin(SD_ChipSelectPin)) {
Serial.println("SD fail");
return;
tmrpcm.setVolume(9);
tmrpcm.play("shark.wav");
void loop(){
Please read this:-
How to use this forum
Because your post is breaking the rules about posting code.
https://maker.pro/arduino/projects/arduino-audio-player
Yes and that is probably where you mistakes are. We need to know what YOU did not what you were following and think you did.
This is a very common problem and you have misunderstood a step or not done it right. So give us a clue what did you do. This means clear photographs where we can follow the wiring. Fritzing layout diagrams are useless please don't post them again here.
Sorry. 2nd attempt: Arduino Uno
I have wired it as:
SD Module:
CS-4
SCK 13
MOSI 11
MISO 12
VCC 5v on arduino
Grnd to arduino ground
Pin 9 of arduino through 6.8k resistor to base of BC 546b transistor
Emitter to ground
Collector to ground side of 1w 8ohm speaker
No sound comes out of the speaker. I even ran the test program for TMRpcm with the same result.
Again, any guidance is appreciated.
#include "SD.h"
#include "TMRpcm.h"
#include "SPI.h"
TMRpcm tmrpcm;
void setup(){
return;
tmrpcm.play("baby.wav");
void loop(){
This is the second image
Try
tmrpcm.play("BABY.WAV");
The SD library may require strict 8.3 filenames. 8.3 filename - Wikipedia
MarkT:
Try
I have tried that. No change. Thank you for the suggestion.
