Help with Bluetooth Serial transfer
I am a novice Arduino enthusiast. Learning as I go.
I am working on a simple project of a Bluetooth controlled tank. I am having issues with serial transfer of the data from the transmitter to the tank (receiver). I have read the Serial tutorial that many people suggest. It is very good, but I guess I am not applying it correctly or something. Anyway, maybe someone can point my obvious mistake.
I am using two Arduino Nano. One for the transmitter and the other for the receiver. On the transmitter side I am using two joysticks to generate the direction and throttle data and the output to be sent via serial are two integers that control the speed of the left track (speedL) and the right track (speedR). I am trying to send these using two HC-05s set as slave (receiver) and master (transmitter). These two I have verified are connected together as I followed the pairing process and the light blinking is the right pattern for paired.
The receiver has two DC motors connected through an Adafruit tb6612 driver. The motor/driver connection works well as I have tested via serial form the computer when connected directly.
To minimize the length of this post, I have written a test code just to troubleshoot receiving the data through BT so I will post that one below. Once I figure that one I can use that in my more length receiver code
My issues have to do (I guess) with how I am sending and receiving the data with both codes (transmitter/receiver). I will post them below and hopefully someone will see the obvious mistake.
Transmitter Code
#include <SoftwareSerial.h>
int throttle; //mapped variable of y axis on left joystick
int speedL; // Resultant speed for left motor
int speedR; // Resultant speed for right motor
int yRight; // Measured input from y-axis on right joystick
int xRight; // Measured input from x-axis on right joystick
int yLeft; // Measured input from y-axis on left joystick
int MFactor; // mapped variable for direction input - yRight. Can only be -1 (rev), 0 (static) and 1 (forward)
long LSFactor; //mapped variable for motor speed and direction multiplier to achieve left turn
long RSFactor; //mapped variable for motor speed and direction multiplier to achieve right turn
// pin definition for joystick inputs
#define yLpin A1
#define yRpin A2
#define xRpin A3
SoftwareSerial Myserial(4, 3);   // RX | TX
  Myserial.begin(9600); // Bluetooth serial communication
  Serial.println("Code starting");
  yRight = analogRead(A2); // Read Joysticks X-axis
  yLeft = analogRead(A1); // Read Joysticks Y-axis
  xRight = analogRead(A3); // Read Joysticks Y-axis
//control logic with central buffer
//left joystick controlling throttle intensity
 if (yLeft >= 530)
    throttle=0;
    throttle = map(yLeft, 520, 0, 0, 255);  //only using center-top range of left y-axis to control throttle
//right throttle controlling direction (y-axis) and moderation of motor intensity to achieve turning
//y-axis right joystick controlling direction
 if ((yRight < 530)&&(yRight>500))
    MFactor=0; //no movement
  else if (yRight <= 500)
    MFactor=1;  //forward
    MFactor=-1; //backward
// x-axis right joystick controlling speed moderation for both motors based on turning input.
//Using 100 range to get around limitation of map function of ony using integer math. At the resutant equation will divide by 100 to
//achieve fractional input as required
if ((xRight < 540)&&(xRight>490)) //defines a central buffer box where no turning is inferred to account for joystick variability around center
  LSFactor=100; //100 means no change on direction
  RSFactor=100;
else if (xRight>=540) //joystick tilted right - right turning intensity based on how much the joystick is tilted
LSFactor=100; //no change on left motor
RSFactor=map(xRight, 540, 1023, 100, -100); //mapped right motor factor from all forward (100) to all backward (-100 achieves turn in place)
else // any other condition means left turn
  RSFactor=100; //no change on right
  LSFactor=map(xRight, 0, 490, -100, 100); //mapped left motor factor from all forward (100) to all backward (-100 achieves turn in place)
//Resultand speed calculation based on throttle intensity (left joystick) and moderation factors
//(Mfactor - forward/backward) and turning factors (LSFactor - left turn, RSFactor - right turn)
//dividing by 100 to return to fractional input by the turning factors
speedL = throttle*MFactor*LSFactor/100;
speedR = throttle*MFactor*RSFactor/100;
/* Serial output when connected to PC for debugging
Serial.print(speedL);
Serial.print("      ");
Serial.println(speedR);
delay(50);
//Bluetooth transfer
sendBluetoothData (speedL, speedR);
delay (200);
void sendBluetoothData(int speedL, int speedR) {
  if (speedL <-255 || speedL > 255){
    return; // invalid data range
  else if (speedR <-255 || speedR > 255){
  Myserial.write('<');
  Myserial.write(speedL);
  Myserial.write(',');
  Myserial.write(speedR);
  Myserial.write('>');
Test Receiver Code
#include<SoftwareSerial.h>
SoftwareSerial Myserial(3, 4);//Rx, Tx
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];        // temporary array for use when parsing
      // variables to hold the parsed data
int SpeedL = 0;
int SpeedR = 0;
boolean newData = false;
int dataNumber = 0;             // new for this version
  Serial.print("Test Code");
  recvWithStartEndMarkers();
    if (newData == true) {
        strcpy(tempChars, receivedChars);
            // this temporary copy is necessary to protect the original data
            //   because strtok() used in parseData() replaces the commas with \0
        parseData();
        showParsedData();
        newData = false;
void recvWithStartEndMarkers() {
    static boolean recvInProgress = false;
    static byte ndx = 0;
    char startMarker = '<';
    char endMarker = '>';
    char rc;
    while (Serial.available() > 0 && newData == false) {
        rc = Serial.read();
        Serial.println("We have serial");
        if (recvInProgress == true) {
            if (rc != endMarker) {
                receivedChars[ndx] = rc;
                ndx++;
                if (ndx >= numChars) {
                    ndx = numChars - 1;
            else {
                receivedChars[ndx] = '\0'; // terminate the string
                ndx = 0;
                newData = true;
        else if (rc == startMarker) {
            recvInProgress = true;
void parseData() {      // split the data into its parts
    char * strtokIndx; // this is used by strtok() as an index
    strtokIndx = strtok(tempChars,",");      // get the first part - the string
    SpeedL = atoi(strtokIndx);
    strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
    SpeedR = atoi(strtokIndx);     // convert this part to an integer
void showParsedData() {
    Serial.print("SpeedL ");
    Serial.println(SpeedL);
    Serial.print("SpeedR ");
    Serial.println(SpeedR);
Thanks in advance for the help.
Welcome to the forum
What are you seeing in the Serial monitor at the Rx end of the link ?
Nothing prints on the Serial Monitor. I move the joysticks to make sure the data is being generated in the transmitter, but nothing shows up on the receiver end.
In that case it is time to add some Serial.print()s to the Rx code to see what is going on, such as what functions are being called and which characters, if any, are being received
I have a Serial.print callout in the while loop and it is not showing which tells me that the "while (Serial.available() > 0 && newData == false) " boolean is turning false. So, why is the Serial.available() giving me false?
Did you start with an example from the tutorial and verify that communications are working?
Copied part of one, but not full... might try that right now. Thanks
Figured it out. I was not referring to the SoftwareSerial I had created... once I changed the name from Serial to Myserial (the name I gave it) all worked. Thanks for the help.
