I wanted to ask i somebody could help with encoder RPM calculations. According to motor driver datasheet motor driver datasheet at 6V it gives 8000 rpm.
It has a gearratio of 1:(52,734) which means the encoder rpm should around 8000*52,734 = 421872 rpm. Since i know what the solution should be I looked around the forum how to calculate rpm from encoder pulse values
which I got on the monitor using the code from this library encoder_buffer code .
I also had to know the pulses per revolutions. Since i already knew that encoder rpm is 421872 rpm, I converted it so RPS which is 7031 RPS. Using an oscilloscoop I saw that the encoder outputs( of the motor) had a frequency of around 379 hz or cyles/sec). Since i knew the frequency and the RPS, i could calculate counts per revolution = 379/7031 => 0,054. The formula for calculating RPM is revolutions/minute = (counts/minute) / (counts/revolution). So i changed the counts( i think those are the pulse values) per minute to:
interval is 100 ms
RPM = ((new_reading - old_reading )/ interval ) * 60*10)/ CPR. The only problem is the value I calculated is much larger than it should be. Could somebody tell where i did something wrong and how to fix it?
thank you very much. Oh I made only some changes when i tested it in de encoder_buffer_code so it would in quadrature count mode.
the problem is the value i should get for RPM is 421872, but instead i get the value 21777777. Where did I do wrong with the calculations. I based to code of the formula revolutions/minute = (counts/minute) / (counts/revolution).
Ok thank you for your response for my problem. Maybe i wasn't clear about my other problem, which i will apologize for that. But again, my problem is I want make a formula to calculate the RPM from a LS766r quadrature encoder counter, but I'm not sure if i made the right approach(I don't have
a definite code for formula, so I wrote one on paper).
If i made a mistake somewhere could somebody point it out? So what I did
1e : To make the formula I looked into another forum and I found that to calculate RPM => revolutions/minute = (counts/minute) / (counts/revolution).
2e : The motor datasheet gives 150RPM(+/-15%), I converted this value to revolutions per sec. I also used
a oscilloscoop to measure frequency of the pulses which I found a value of 379 cycles/sec. Using those two
values I freq/rps => I have a CPR of around 3.
3e: To find (counts/minute) I considered the counts as the reading of the pulses( difference between the old and new value. Is it oke to consider that? Also the I considered the minute as the interval between the readings. So if I take for example a interval of 100 ms, do I need to make the interval 1001060 to make it one minute again? Or did I make a wrong approach here?
So in short I have some trouble defining a formule for RPM calculations and I was hoping if somebody
could help or point out the errors I made in the 3 steps I did.
yes I use that one, RPM => revolutions/minute = (counts/minute) / (counts/revolution). I used your your rps and I using the formula freq/rps = counts per revolution. I get a value of 149 right?
Slow the motor down so you have a stable reading of 60 RPM, then count the revs against a stopwatch or clock. Start counting in your head at 0 seconds, count revs to 300 (don't miscount ), the clock should show exactly 5 minutes elapsed.
This is finally starting to look reasonable. You have fixed most of the earlier mistakes.
You need to be very clear on what end of the gearbox you are measuring. 150rpm is the output of the gearbox. The gear ratio is about 52, meaning the motor is spinning about 7800rpm.
You never said, but is the encoder on the motor end or on the output end of the gearbox? It is usually on the motor. That allows the encoder to measure the output very accurately because 1 revolution of the output requires 52 motor revolutions.
There are.two ways to go:
A) measure the number of pulses in a fixed time.
B) measure the time between a fixed number of pulses.
It sort of sounds like you are doiing (A). You could wait for a whole minute and count all the pulses in a minute. Then divide by 3 (pulses per motor revolutions) and divide by 52.734. (gear ratio.) That will give you the output rpm.
But a minute is a long time and a lot of pulses. If you only counted for a quarter (1/4) of a minute then multiply by 4 before dividing by 3 and 52.734. If you count for 100ms then that is a 100/1000/60th of a minute.
Method (B) is sometimes more suitable. Measuring the time between one pulse and the next can be very fast but has a lot of errors. In your case, if the 3 pulses in one revolution are not perfectly spaced then it will always measure incorrectly. You would probably choose to measure the time taken for 6 pulses or 30 or 300.
