Help with dfplayermini error
I installed the dfplayer mini library from DFRobot and also tried to use the github zip but none of them worked i always got this as an error:
 fatal error: DFRobotDFPlayerMini.h: No such file or directory
 #include "DFRobotDFPlayerMini.h"
compilation terminated.
exit status 1
Compilation error: DFRobotDFPlayerMini.h: No such file or directory
Welcome to the forum
As your topic does not relate directly to the installation or operation of the IDE it has been moved to the Programming category of the forum
Does the DFRobotDFPlayerMini.h file exist on your PC and, if so, where is it located ?
How did you install the library ?
Please show the entire output of a verbose compile attempt.
Yes i did install the library and it is in the documents but it redirects to onedrive and then arduino instead of just documents and my onedrive name has some russian letters i really don't remember why. also yes i installed it both ways, arduino library manager and then github zip since library manager one didnt work
C:\Users\drroze\Downloads\DFPlayerPC\DFPlayerPC.ino:5:10: fatal error: DFRobotDFPlayerMini.h: No such file or directory
exit status 1
Turn on verbose output, please.
sorry my bad
FQBN: arduino:avr:nano
Using board 'nano' from platform in folder: C:\Users\drroze\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\drroze\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\drroze\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\drroze\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\drroze\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\drroze\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E\sketch\DFPlayerPC.ino.cpp -o nul
Alternatives for SoftwareSerial.h: [SoftwareSerial@1.0]
ResolveLibrary(SoftwareSerial.h)
  -> candidates: [SoftwareSerial@1.0]
C:\Users\drroze\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\drroze\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\drroze\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\drroze\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial\src C:\Users\drroze\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E\sketch\DFPlayerPC.ino.cpp -o nul
Alternatives for DFRobotDFPlayerMini.h: [DFRobotDFPlayerMini@1.0.6]
ResolveLibrary(DFRobotDFPlayerMini.h)
  -> candidates: [DFRobotDFPlayerMini@1.0.6]
C:\Users\drroze\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\drroze\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\drroze\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\drroze\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial\src -IC:\Users\drroze\OneDrive\Документы\Arduino\libraries\DFRobotDFPlayerMini C:\Users\drroze\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E\sketch\DFPlayerPC.ino.cpp -o nul
exit status 1
You have non ASCII characters in your library path, which causes the problem below:
And here's a workaround from @ptillisch:
thank you that did the job very well but now i have a new problem. the code i got from a youtuber that made a tutorial on this states that it should print some stuff on serial monitor but it just printed random stuff : S�#����������
heres the code:
 //Very much inspired by https://www.dfrobot.com/blog-1462.html by DFRobot Feb 26 2020
//Additions made by Just Baselmans https://www.youtube.com/justbaselmansYT Jan 23 2023
#include "SoftwareSerial.h"
// Initialize software serial on pins 10 and 11
SoftwareSerial mySoftwareSerial(10, 11);  // RX, TX
DFRobotDFPlayerMini myDFPlayer;
String line;
char command;
int pause = 0;
int repeat = 0;
  // Serial communication with the module
  mySoftwareSerial.begin(9600);
  // Initialize Arduino serial
  // Check if the module is responding and if the SD card is found
  Serial.println(F("DFRobot DFPlayer Mini"));
  Serial.println(F("Initializing DFPlayer module ... Wait!"));
  if (!myDFPlayer.begin(mySoftwareSerial)) {
    Serial.println(F("Not initialized:"));
    Serial.println(F("1. Check the DFPlayer Mini connections"));
    Serial.println(F("2. Insert an SD card"));
    while (true)
  Serial.println(F("DFPlayer Mini module initialized!"));
  // Initial settings
  myDFPlayer.setTimeOut(500);  // Serial timeout 500ms
  myDFPlayer.volume(5);        // Volume 5
  myDFPlayer.EQ(0);            // Normal equalization
  //  myDFPlayer.EQ(DFPLAYER_EQ_POP);
  //  myDFPlayer.EQ(DFPLAYER_EQ_ROCK);
  //  myDFPlayer.EQ(DFPLAYER_EQ_JAZZ);
  //  myDFPlayer.EQ(DFPLAYER_EQ_CLASSIC);
  //  myDFPlayer.EQ(DFPLAYER_EQ_BASS);
  menu_options();
  // Waits for data entry via serial
  while (Serial.available() > 0) {
    command = Serial.peek();
    line = Serial.readStringUntil('\n');
    // Play from first 9 files
    if ((command >= '1') && (command <= '9')) {
      Serial.print("Music reproduction");
      Serial.println(command);
      command = command - 48;
      myDFPlayer.play(command);
      menu_options();
    //Play from specific folder
    if (command == 'f') {
      int indexF = line.indexOf('f');
      int indexS = line.indexOf('s');
      if (indexF != -1 && indexS != -1 && indexF < indexS) {
        int folder = line.substring(indexF + 1, indexS).toInt();
        int song = line.substring(indexS + 1).toInt();
        Serial.print("From folder: ");
        Serial.print(folder);
        Serial.print(", playing song: ");
        Serial.println(song);
        myDFPlayer.playFolder(folder, song);  //play specific mp3 in SD:/folder/song.mp3; Folder Name(1~99); File Name(1~255)
        Serial.println("Incomplete 'f' command. Specify both folder and song numbers.");
      menu_options();
    // Reproduction
    // Stop
    if (command == 's') {
      myDFPlayer.stop();
      Serial.println("Music Stopped!");
      menu_options();
    // Pause/Continue the music
    if (command == 'p') {
      pause = !pause;
      if (pause == 0) {
        Serial.println("Continue...");
        myDFPlayer.start();
      if (pause == 1) {
        Serial.println("Music Paused!");
        myDFPlayer.pause();
      menu_options();
    // Toggle repeat mode
    if (command == 'r') {
      repeat = !repeat;
      if (repeat == 1) {
        myDFPlayer.enableLoop();
        Serial.println("Repeat mode enabled.");
        myDFPlayer.disableLoop();
        Serial.println("Repeat mode disabled.");
      menu_options();
    // Set volume
    if (command == 'v') {
      int myVolume = line.substring(1).toInt();
      if (myVolume >= 0 && myVolume <= 30) {
        myDFPlayer.volume(myVolume);
        Serial.print("Current Volume:");
        Serial.println(myDFPlayer.readVolume());
        Serial.println("Invalid volume level, choose a number between 0-30.");
      menu_options();
    // Increases volume
    if (command == '+') {
      myDFPlayer.volumeUp();
      menu_options();
    // Decreases volume
    if (command == '-') {
      myDFPlayer.volumeDown();
      menu_options();
    // Play previouse
    if (command == '<') {
      myDFPlayer.previous();
      Serial.println("Previous:");
      Serial.print("Current track:");
      Serial.println(myDFPlayer.readCurrentFileNumber() - 1);
      menu_options();
    // Play next
    if (command == '>') {
      myDFPlayer.next();
      Serial.println("Next:");
      Serial.println(myDFPlayer.readCurrentFileNumber() + 1);
      menu_options();
void menu_options() {
  Serial.println(F("=================================================================================================================================="));
  Serial.println(F("Commands:"));
  Serial.println(F(" [1-9] To select the MP3 file"));
  Serial.println(F(" [fXsY] Play song from folder X, song Y"));
  Serial.println(F(" [s] stopping reproduction"));
  Serial.println(F(" [p] pause/continue music"));
  Serial.println(F(" [r] toggle repeat mode"));
  Serial.println(F(" [vX] set volume to X"));
  Serial.println(F(" [+ or -] increases or decreases the volume"));
  Serial.println(F(" [< or >] forwards or backwards the track"));
  Serial.println(F("================================================================================================================================="));
here is the verbose output:
Using board 'nano' from platform in folder: C:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
C:\Users\sixey\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\sixey\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E\sketch\DFPlayerPC.ino.cpp -o nul
C:\Users\sixey\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial\src C:\Users\sixey\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E\sketch\DFPlayerPC.ino.cpp -o nul
C:\Users\sixey\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial\src -Ic:\Users\sixey\Videos\Arduino\libraries\DFRobotDFPlayerMini C:\Users\sixey\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E\sketch\DFPlayerPC.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial\src\SoftwareSerial.cpp
Using cached library dependencies for file: c:\Users\sixey\Videos\Arduino\libraries\DFRobotDFPlayerMini\DFRobotDFPlayerMini.cpp
Generating function prototypes...
C:\Users\sixey\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial\src -Ic:\Users\sixey\Videos\Arduino\libraries\DFRobotDFPlayerMini C:\Users\sixey\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E\sketch\DFPlayerPC.ino.cpp -o C:\Users\sixey\AppData\Local\Temp\1653722751\sketch_merged.cpp
C:\Users\sixey\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\sixey\AppData\Local\Temp\1653722751\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\sixey\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\sixey\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\sixey\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\sixey\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-Ic:\\Users\\sixey\\Videos\\Arduino\\libraries\\DFRobotDFPlayerMini" "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E\\sketch\\DFPlayerPC.ino.cpp" -o "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E\\sketch\\DFPlayerPC.ino.cpp.o"
Compiling libraries...
Compiling library "SoftwareSerial"
Using previously compiled file: C:\Users\sixey\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E\libraries\SoftwareSerial\SoftwareSerial.cpp.o
Compiling library "DFRobotDFPlayerMini"
Using previously compiled file: C:\Users\sixey\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E\libraries\DFRobotDFPlayerMini\DFRobotDFPlayerMini.cpp.o
Compiling core...
Using precompiled core: C:\Users\sixey\AppData\Local\arduino\cores\arduino_avr_nano_cpu_atmega328_b9d922d1f481fee03c248fe007c6af99\core.a
Linking everything together...
"C:\\Users\\sixey\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E/DFPlayerPC.ino.elf" "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E\\sketch\\DFPlayerPC.ino.cpp.o" "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E\\libraries\\SoftwareSerial\\SoftwareSerial.cpp.o" "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E\\libraries\\DFRobotDFPlayerMini\\DFRobotDFPlayerMini.cpp.o" "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E/..\\..\\cores\\arduino_avr_nano_cpu_atmega328_b9d922d1f481fee03c248fe007c6af99\\core.a" "-LC:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E" -lm
"C:\\Users\\sixey\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E/DFPlayerPC.ino.elf" "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E/DFPlayerPC.ino.eep"
"C:\\Users\\sixey\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E/DFPlayerPC.ino.elf" "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E/DFPlayerPC.ino.hex"
Using library SoftwareSerial at version 1.0 in folder: C:\Users\sixey\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial
Using library DFRobotDFPlayerMini at version 1.0.6 in folder: C:\Users\sixey\Videos\Arduino\libraries\DFRobotDFPlayerMini
"C:\\Users\\sixey\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\sixey\\AppData\\Local\\arduino\\sketches\\7C4A6BB853627FC4E93BB0A6D479435E/DFPlayerPC.ino.elf"
Sketch uses 8796 bytes (28%) of program storage space. Maximum is 30720 bytes.
Global variables use 668 bytes (32%) of dynamic memory, leaving 1380 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\sixey\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\sixey\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM8" -b115200 -D "-Uflash:w:C:\Users\sixey\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E/DFPlayerPC.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\sixey\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM8
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\sixey\AppData\Local\arduino\sketches\7C4A6BB853627FC4E93BB0A6D479435E/DFPlayerPC.ino.hex"
avrdude: writing flash (8796 bytes):
Writing | ################################################## | 100% 1.39s
avrdude: 8796 bytes of flash written
avrdude done.  Thank you.
What baud rate have you got the Serial monitor set to ?
