I am working on a project with Arduino UNO but I'm having trouble with the mp3 player. I made a simple project to test this and what I'm finding is that when it's supposed to "play" it does nothing, but when told to "stop" it will play the previously instructed play file.
Any idea why this would be happening?
//Speaker
// For serial connection to DFPlayer audio module
#include <SoftwareSerial.h>
// For playing sounds from DFPlayerMini module using the serial connection
// Modified from https://github.com/DFRobot/DFRobotDFPlayerMini
#include "src/DFRobotDFPlayerMini/DFRobotDFPlayerMini.h"
const byte TxToDFPlayerSpeaker = 10;//4;
const byte RxFromDFPlayerSpeaker = 11;//5;
SoftwareSerial softwareSerialSpeaker(RxFromDFPlayerSpeaker, TxToDFPlayerSpeaker); // RX, TX
DFRobotDFPlayerMini dfPlayerSpeaker;
// Start the serial connection
Serial.begin (9600);
Serial.print(F("Initialising software serial interface to DFPlayerSpeaker..."));
for(int i=0; i<10; i++) {
softwareSerialSpeaker.begin(9600);
if(dfPlayerSpeaker.begin(softwareSerialSpeaker)){
Serial.println(F("OK!"));
else {
Serial.print(".");
if(i==9) {
Serial.println(F("Failed :("));
return;
// Set volume (value from 0 to 30)
dfPlayerSpeaker.volume(30);
//reset sounds test
Serial.println("speaker reset test begin");
Serial.println("stop");
dfPlayerSpeaker.stop();
Serial.println("play");
dfPlayerSpeaker.playMp3Folder(1);
Serial.println("speaker reset test finished");
delay(5000);
The original issue of stop() playing a track and play() stopping a track seems to persist.
What seems to make a difference is the amount of delay before issuing commands to the dfPlayer(). If It there is a delay of about 7 seconds (either through dfPlayerSpeaker.setTimeout(7000) or simply delay(7000)) then everything seems to work.
No delay at all seems to cause the first several commands to be ignored (or perhaps they are started later with the next commands).
Taking a proper look this morning at your last post. I'm confused! Your sketch and photo show no similarity to that referenced project?
And to be honest I don't fully understand your actual objective? Your original post essentially asked “why doesn’t my sketch do what I think it should do?” It would be better to tell us exactly what you want to do. Can we assume that your aim is to achieve the same as your referenced project?
Regarding delays: in most cases you will need one that's at least as long as the track, after any play() command . So that explains why much of your sketch is not working as it stands.
I note that you've now told us you are using a folder-based structure for your tracks, yes? No problem, but a simple flat structure in the root is simpler - although you must be alert to the tracks playing in the order they were added to the card.
Meanwhile try experimenting with this example. Note my pin numbers chosen for the Uno and breadboard at hand, and my comments.
Thu 3 Oct 2024 0623
Very simple example, loop() repeatedly plays next track,
for duration specified.
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
delay(200);
// Identify sketch
#define __FILENAME__ (strrchr(__FILE__, '\\') ? strrchr(__FILE__, '\\') + 1 : __FILE__)
Serial.println(__FILENAME__);
mySoftwareSerial.begin(9600);
myDFPlayer.begin(mySoftwareSerial); // Start communication with DFPlayer
// myDFPlayer.begin(mySoftwareSerial, true, false); // Start communication with DFPlayer
myDFPlayer.volume(10);
// delay(1000); // Sometimes needed
// Play a test track; e.g. track 1, so loop() will play the rest.
myDFPlayer.play(1);
delay(5000);
// For simplicity at this stage I've omitted the player tests
// in DFR's own examples. You'll know soon enough if it's working!
Serial.println("Setup ended");
// Play all tracks successively, then repeat.
myDFPlayer.next();
delay(8000); // Play this much of each track
The aim of this is to determine the cause of the issue I'm having. Sometimes the commands issued to the DFPlayer are not working, such that play() will play nothing until another command, such as stop() is called. This isn't just with this sketch and schematic, but on all attempts to use the DFPlayer.
I have a larger project where I want to use the DFPlayer but this is meant to be a simpler sketch to focus on the issue.
I'll experiment with your suggestion regarding the delays. But this wouldn't explain why the first play track has trouble playing.
I'd assumed you'd take a minute to try the crucial delay increases I suggested. I've just done so and it works exactly as I'd expect. No need for that stop() and play() stuff.
Thu 3 Oct 2024 0623
delay(200);
// Identify sketch
// Perform initialisation the correct way
// Play tests
Serial.println(F("Begin tests"));
Serial.println(F("plays for 1st time"));
myDFPlayer.playMp3Folder(1);
delay(3000); // Done OK
Serial.println(F("plays for 2nd time"));
Serial.println(F("plays for 3rd time"));
myDFPlayer.playMp3Folder(1); // Done OK
delay(3000); // Plays full track (10 s in my case) because there
// are no further play() commands.
Serial.println(F("Tests finished"));
* Monitor print output
14:39:37.708 -> dwwelch-example-e1.ino
14:39:38.399 -> Begin tests
14:39:38.399 -> plays for 1st time
14:39:41.446 -> plays for 2nd time
14:39:44.446 -> plays for 3rd time
14:39:47.482 -> Tests finished
I'm out of town so I don't have access to the hardware to try it out.
Your code only has a delay(200) before you play anything and it works. From my tests, mine would not without a longer delay. Also, your serial connection code is different than mine. I don't think I've been successful at connecting to the DFPlayer the way you are doing it, but I'll try it again.
If I added delays that are the length of the track, wouldn't that prevent the ability to stop and play new tracks abruptly?
Nothing plays until the third attempt ("plays for the 3rd time")
This is consistent with my earlier results where I theorized some kind of delay of around 6-8 seconds is required before it starts following commands. The combined delays after serialization in this sketch are 6 seconds.
Your sketch in post #1 is completely different from your reference link in post #7. A random image from the link is meaningless. Post the sketch you are using and a wiring diagram that reflects the sketch.
Meanwhile - hopefully to shorten the long gaps between your posts - I can confirm that I just ran my earlier sketch again, from post #11 four days ago, on a Uno, with the same success.
Redouble your checking.
And, to stay in sync, then use the following sketch which has minor edits:
Mon 7 Oct 2024 1215: Checking. Compiles, uploads and runs OK.
Mon 7 Oct 2024 1227: Trivial edits
- Fixes the powerup noise issue
- Plays different three tracks for variety
- Simplifies the play commands from 'playMp3Folder()' to
play(). Same result in both cases.
- Revised comments
delay(200);
// Identify sketch
// myDFPlayer.begin(mySoftwareSerial); // Start communication with DFPlayer
myDFPlayer.volume(15);
// Play tests
myDFPlayer.play(1);
delay(3000); // Plays OK
myDFPlayer.play(2);
myDFPlayer.play(3); // Done OK
delay(3000); // Plays OK, FULL track (10 s in my case) because
// there are no further play() commands.
12:20:59.829 -> MyRecentPost-dwwelch-e1.ino
12:20:59.829 -> Begin tests
12:20:59.829 -> plays for 1st time
12:21:02.876 -> plays for 2nd time
12:21:05.897 -> plays for 3rd time
12:21:08.883 -> Tests finished
EDIT: You could also eliminate one other possible cause. I use version 1.0.5 of the DFR library because I believe 1.0.6 is buggy.
These errors also persist on 1.06. The difference between now and before is that instead of installing a zip I was linking to a DFRobot DFPlayerMini library in a directory.
That version seems to be 1.03. I switched to version 1.03 and that is also giving these same errors.
But it will compile without errors if I point back to my directory library by changing this line.
Not sure why this is an issue. Should probably resolve it before further testing.
...\AppData\Local\Temp\arduino-sketch-734275D89608E4DB279462920C398DA5\libraries\DFRobotDFPlayerMini-1.0.5\DFRobotDFPlayerMini.cpp.o (symbol from plugin): In function `DFRobotDFPlayerMini::setTimeOut(unsigned long)':
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::setTimeOut(unsigned long)'
...\AppData\Local\Temp\arduino-sketch-734275D89608E4DB279462920C398DA5\sketch\src\DFRobotDFPlayerMini\DFRobotDFPlayerMini.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::uint16ToArray(unsigned int, unsigned char*)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::calculateCheckSum(unsigned char*)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::enableACK()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::disableACK()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readType()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::read()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::handleMessage(unsigned char, unsigned int)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::handleError(unsigned char, unsigned int)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readCommand()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::parseStack()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::arrayToUint16(unsigned char*)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::validateStack()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::available()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::sendStack()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::sendStack(unsigned char, unsigned int)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::sendStack(unsigned char)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::sendStack(unsigned char, unsigned char, unsigned char)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::waitAvailable(unsigned long)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::next()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::previous()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::play(int)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::volumeUp()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::volumeDown()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::volume(unsigned char)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::EQ(unsigned char)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::loop(int)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::outputDevice(unsigned char)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::sleep()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::reset()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::begin(Stream&, bool, bool)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::start()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::pause()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::playFolder(unsigned char, unsigned char)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::outputSetting(bool, unsigned char)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::enableLoopAll()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::disableLoopAll()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::playMp3Folder(int)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::advertise(int)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::playLargeFolder(unsigned char, unsigned int)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::stopAdvertise()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::stop()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::loopFolder(int)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::randomAll()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::enableLoop()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::disableLoop()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::enableDAC()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::disableDAC()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readState()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readVolume()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readEQ()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readFileCounts(unsigned char)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readCurrentFileNumber(unsigned char)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readFileCountsInFolder(int)'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readFolderCounts()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readFileCounts()'
(.text+0x0): multiple definition of `DFRobotDFPlayerMini::readCurrentFileNumber()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
I agree that this needs resolving before proceeding. I don't know why you have/had the DFRobotDFPlayerMini.h library in that strange looking location.
Perhaps one of the IDE gurus will comment, but AFAIK (and as you can read in the Arduino Reference documentation, etc), all contributed libraries (and some others) should be in a subfolder named \libraries within your \Sketches folder. For example mine are here:
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries
What have you specified as your Sketchbook location in the File > Preferences dialog?
