Help with displaying on a tft lcd
So I have been dealing with this LCD for weeks now and decided to set the record straight by making a post with absolutely everything to resolve all the problems.
Note that I am not an expert at this, so if anything isn’t clear, feel free to ask!
I have a 3.5" TFT LCD with a shield for an Arduino MEGA 2560 that is 480 x 320. It uses an ILI9486 driver with a parallel interface:
My goal is to display JPGs and GIFs from the built-in SD card reader on it using an ESP32 Wroom32D Devkit C . The connections are as follows:
So my first question is: Should I connect the 3V3 to the 3.3V pin on the ESP32? I am asking this question because I can't find the specifications for this specific LCD. Also, when I first used it on an Arduino, it would get hot on the side where the flex connector is. The TFT-Arduino shield would also connect the pin between the GND and 5V pins to GND.
I am using the TFT_eSPI library. Once I managed to connect it to the ESP32 with the connections I mentioned above, but without the 3.3V, I uploaded the "TFT_Meters" sketch, and it worked fine. It didn't get hot at all, and everything was smooth.
The problem arose when I started uploading JPGs. The code had no errors and uploaded successfully, but the output was the problem. This is what would happen:
The screen would go from a bright white to a much darker white, and not only that, but the serial monitor would display nothing. I checked everything: the port, the board, the baud rate... and nothing seemed to help.
Here is the code:
#include <SPI.h>
#include <FS.h>
#include <SD.h>
#include <TFT_eSPI.h>
#include <JPEGDecoder.h>
TFT_eSPI tft = TFT_eSPI(); // Initialize TFT
Serial.println("Starting...");
// Set chip select high to avoid bus contention during initialization
digitalWrite(33, HIGH); // TFT chip select
digitalWrite(5, HIGH); // SD card chip select
tft.begin();
// Initialize the SD card
if (!SD.begin(5)) { // Pass only the CS pin
Serial.println("Card Mount Failed");
return;
Serial.println("SD card initialized.");
displayImage("/DispenserScreen_resized.jpg"); // Display the image
// Nothing to do in loop
void displayImage(const char *filename) {
File jpegFile = SD.open(filename, FILE_READ);
if (!jpegFile) {
Serial.print("ERROR: File "");
Serial.print(filename);
Serial.println("" not found!");
return;
Serial.println("===========================");
Serial.print("Drawing file: ");
Serial.println(filename);
bool decoded = JpegDec.decodeSdFile(jpegFile); // Decode the image
if (decoded) {
jpegRender(0, 0); // Render the image at (0, 0)
Serial.println("Jpeg file format not supported!");
void jpegRender(int xpos, int ypos) {
uint16_t *pImg;
uint16_t mcu_w = JpegDec.MCUWidth;
uint16_t mcu_h = JpegDec.MCUHeight;
tft.setSwapBytes(true);
while (JpegDec.read()) {
pImg = JpegDec.pImage;
int mcu_x = JpegDec.MCUx * mcu_w + xpos;
int mcu_y = JpegDec.MCUy * mcu_h + ypos;
// Directly push the image since dimensions match
tft.pushImage(mcu_x, mcu_y, mcu_w, mcu_h, pImg);
tft.setSwapBytes(false);
That is all!
If you have any ideas, code, or alternatives, please let me know.
Thanks!
Please read the forum guide in the sticky post and then edit and correct your post above which is currently breaking forum rules.
Can you please direct me to the forum guide in the sticky post?
Thanks!
:roll_eyes:
