Help with if statements (Micromouse)
I'm making a micromouse, this is my first robotic project I've ever done. I plan to use a flood fill algorithm and to do that I'm using hall effect sensor to tell the direction and rotation count of the wheel. I'm trying to code it so that both wheels are detected and both their states are printed in the serial monitor. But only one wheel is being detected. Here is my code so far.
// Pin numbers for the Hall effect sensors
const int sensorA_pin = 2;
const int sensorB_pin = 3;
const int sensorC_pin = 4;
const int sensorD_pin = 5;
// Variables to store the previous sensor states
int prevSensorAState = LOW;
int prevSensorBState = LOW;
int prevSensorCState = LOW;
int prevSensorDState = LOW;
// Variables to store the position and direction of rotation
int position = 0;
int direction = 0;
int direction2 = 0;
int position2 = 0;
  // Set the Hall effect sensor pins as inputs
  pinMode(sensorA_pin, INPUT);
  pinMode(sensorB_pin, INPUT);
  pinMode(sensorC_pin, INPUT);
  pinMode(sensorD_pin, INPUT);
  // Start the serial communication
  int sensorAState = digitalRead(sensorA_pin);
  int sensorBState = digitalRead(sensorB_pin);
  int sensorCState = digitalRead(sensorC_pin);
  int sensorDState = digitalRead(sensorD_pin);
  if (sensorAState != prevSensorAState) {
    if (sensorBState != sensorAState) {
      direction = 1;  // Clockwise rotation
      direction = -1;  // Counterclockwise rotation
    position += direction;
  if (sensorCState != prevSensorCState) {
    if (sensorDState != sensorCState) {
      direction2 = 1;  // Clockwise rotation
      direction2 = -1;  // Counterclockwise rotation
    position2 += direction2;
    Serial.print("Position: ");
    Serial.println(position2);
    Serial.print("Direction: ");
    if (direction2 > 0) {
      Serial.println("Clockwise2");
    } else if (direction2 < 0) {
      Serial.println("Counterclockwise2");
      Serial.println("No rotation2");
    // Output the position and direction of rotation
    Serial.println(position);
    if (direction > 0) {
      Serial.println("Clockwise");
    } else if (direction < 0) {
      Serial.println("Counterclockwise");
      Serial.println("No rotation");
  // Update the previous sensor states
  prevSensorAState = sensorAState;
  prevSensorBState = sensorBState;
  prevSensorCState = sensorCState;
  prevSensorDState = sensorDState;
How do I code it so that both wheels are detected and their states printed simultaneously.
The large structure of your loop() looks oddly balanced.
So I mean there are some misplaced { braces } and the presentation is misleading you.
Perhaps using the IDE Auto Format tool would make your error pop out.
I'd do it myself but I am in transit looking through the tiny window.
a7
Which one? Which sensors are associated with which wheel?
Sensors A and B are associated with wheel one. Sensor C and D are associated with wheel 2
Which wheel is being detected and which not?
wheel 2 is not being detected
Your code, formatted. Now it is easier to see that the handling of sensors C and D is wholly within the code block that handles sensors A and B. This seems wrong.
int position = 0;
int direction = 0;
int direction2 = 0;
int position2 = 0;
It's 2024. You might want to use 115200 instead of your grandfather's "fast" baud rate. It will help avoid timing issues that s l o w printing might cause.
a7
It still did not work, I will test the hall effect sensors to check if they are working.
All hall effect sensors are working, idk what is wrong.
Hello wyreyt
Welcome to the best Arduino forum ever :slight_smile:
Check the usability of the following libray:
I'm not using a rotary encoder.
ok, I realise that the article has not been read and understood.
Have fun.
What am I meant to find in the article?
Please post the code. The code that you came up with following the advices given, that compiles and runs but does not work.
Please describe what it does now, and how that differs to what it should do.
Obvsly there is still some kind of problem, but without seeing exactly what you are trying now, it is not possible to help.
This is what a rotary encoder does; @paulpaulson no doubt referred you to that article so that you might see how a rotary can be used, with the hope and expectation that you might benefit from learning about what you are trying to do.
a7
Are you fixed the errors in the code?
The sketch in #7 is not a solution, it was only formatted to make the errors more visible for you.
But now you have to fix the errors yourself.
That's right, it is not. It is exactly the code @wyreyt posted.
With the obvious changes, it responds to both encoders.
I say repsond, but the response is unsatisfactory. This is caused by the large amount of printing that is done at the 20th century band rate of 9600.
Changing to
  Serial.begin(115200);    // it's 2024!
lets the polling successfully read both sensors. I wonder with doubt, however, that this primitive method will work in the context of any other code that might take attention away from the need to continuously poll the sensor inputs.
An alternate method would have no such problem. Since each hall effect sensor is indistinguishable logically from a rotary encoder, it is again suggested that @wyreyt find and deploy a good rotary encoder algorithm.
@paulpaulson has provided a link that appears to cover the ups and downs (see what I did there?) of various ways of capturing the signals and providing meaningful output.
a7
Also, sorry for any misunderstandings, I'm very new to robotics and code so I'm still learning. This is the current code.
const int sensorC_pin = 6;
const int sensorD_pin = 7;
int position = 0;
int direction = 0;
int direction2 = 0;
int position2 = 0;
      Serial.print("Position2: ");
      Serial.print("Direction2: ");
What this code is meant to do is respond to the rotation's of two different wheels. It's meant to then tell me the direction it's spinning and how far it has changed from the starting position, adding 1 for every clockwise rotation and taking one away for every counter-clockwise rotation. I'm using a donut magnet with 8 poles on each wheel, and two hall effect sensors per wheel at a 112.5 degree angle I believe. I'm using an arduino Uno as well. It should output the position of wheel 1 when it turns by adding or subtracting 1 from the position variable and outputting the direction it's spinning, it does this successfully. It should do the same for wheel 2 but the serial monitor does not respond to any change in wheel 2's position.
How is this code different?
What did you change?
Why is the handling of inputs C and D still wholly within the block that handles inputs A and B? There could be a good reason, somehow I don't think so.
The formatting you applied shows this clearly. Code that is within a block is indented, that is for human consumption, the compiler doesn't care, but the indentation level lets you see what is subordinate to what.
  if (A and B whatever) {
         stuff for A and B
         if (C and D whatever) {
                 stuff for C and D
         stuff for both
probably should look like
         stuff for A and B
         stuff for C and D
   stuff for both sets
a7
So what would you do if this was your code? As I said, I'm very new to code so I can't understand half of what you're saying, the rules of indentation are not known to me so this is why I'm asking for help, I barely know what I'm doing.
int position = 0;
int direction = 0;
int direction2 = 0;
int position2 = 0;
Ok, I just shuffled around the statements in the void loop section and it worked, I'll post the code and mark it as the solution for future people.
int position = 0;
int direction = 0;
int direction2 = 0;
int position2 = 0;
