Help with my first arduino code
my code:
int buttonPin = 5;`
int GREEN = 2;
int YELLOW = 3;
int RED = 4;
int DELAY_GREEN = 1000;
int DELAY_YELLOW = 1000;
int DELAY_RED = 1000;
// basic functions
  pinMode(GREEN, OUTPUT);
  pinMode(YELLOW, OUTPUT);
  pinMode(RED, OUTPUT);
 int green_light();
  delay(DELAY_GREEN);
 int yellow_light();
  delay(DELAY_YELLOW);
 int red_light();
  delay(DELAY_RED);
void green_light()
  digitalWrite(GREEN, HIGH);
  digitalWrite(YELLOW, LOW);
  digitalWrite(RED, LOW);
void yellow_light()
  digitalWrite(GREEN, LOW);
  digitalWrite(YELLOW, HIGH);
void red_light()
  digitalWrite(RED, HIGH);
  if(digitalRead(buttonPin) == LOW)
    void green_light()
    void yellow_light()
      void red_light()
The error i am getting:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
nuclear_thing_idk:51:3: error: expected unqualified-id before 'if'
nuclear_thing_idk:75:3: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
I'm sorry if this post isnt really well put together its 1AM i have school and my english is very bad.
You already defined the function, remove the void keyword from where you use them inside loop().
Welcome to the forum.
What do you want your code to do?
Apart from what @anon57585045 has said you may need to read up on the format of functions and how to call them?
Tom... :grinning: :coffee:
Looks to me like you are trying to write something like this..
int buttonPin = 5;
int GREEN = 2;
int YELLOW = 3;
int RED = 4;
// basic functions
   green_light();
   delay(DELAY_GREEN);
   yellow_light();
   red_light();
   delay(DELAY_RED);
void green_light() {
void yellow_light() {
void red_light() {
// TROUBLE HERE, YOU CAN ONLY HAVE ONE loop().
  if(digitalRead(buttonPin) == LOW) {
      green_light();
      yellow_light();
      red_light();
But I may be wrong. Also you can only have one loop() function. You tried to write two of them.
Looks like code tags are different here.. I guess at some point the'll sort that one out.
-jim lee
thanks for your help but it is not exactly what im trying to do.
I want to, whenever i press the button, it will start the green, yellow, red thing.
sorry if i'm asking for to much
Can you post your circuit?
A hand drawn and posted image will be fine.
How have you got your button wired?
Did you try @jimLee 's code without the last void loop?
Tom.... :grinning: :+1: :coffee: :australia:
Oh! Like this?
int buttonPin = 5;
int GREEN = 2;
int YELLOW = 3;
int RED = 4;
// basic functions
      green_light();
      delay(DELAY_GREEN);
      yellow_light();
      red_light();
      delay(DELAY_RED);
void red_light() {
-jim lee
im writing it but it might be long cuz im bad a this.
thanks for helping me!
Hi loik,
Take a look into this tutorial:
Arduino Programming Course
It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
best regards Stefan
Hi loik,
here is a version of your code that compiles.
I added some comments to explain what the different parts of the code do.
Though my comments do not explain all details.
int buttonPin = 5;
int GREEN = 2;
int YELLOW = 3;
int RED = 4;
// define function named green_light
// define function named yellow_light
// define function named red_light
void red_light() {
// basic functions
  if (digitalRead(buttonPin) == LOW) {
    green_light();  // execute commands of function green_light
    delay(DELAY_GREEN);
    yellow_light(); // execute commands of function yellow_light
    red_light();    // execute commands of function red_light
    delay(DELAY_RED);
best regards Stefan
@StefanL38 You missed the button bit.
-jim lee
You don't have to copy it by writing the code you want to try.
Just select the icon in the top right corner of the code block then paste into the IDE.
Tom... :grinning: :+1: :coffee: :australia:
YOu are right. I added the if-condition for the button.
best regards Stefan
