Thanks for your reply.
I don't have an annotated schematic but I could try do one if it's really needed?
As far as parts go I am using a Quadstick (www.quadstick.com) for control (why I need for a USB host), an iRangeX IRX4 Plus 2.4G transmitter to receive PPM signals from the Arduino, an RGB LCD Shield to display settings and a USB powerbank to power the Arduino, Quadstick and transmitter.
I'm starting with the following code that has been taken from the YouTube video:
* Sketch by David Simpson
* Adapted from sketch By DroneMesh
* I did not create the Library this was Found online links are below
* I did not create the PPM function Was found online links are below
* I merged both codes to create something usefull out of it
* PPM Output is on Pin 3
* Download USB Host Shield Library First
* https://github.com/felis/USB_Host_Shield_2.0/archive/master.zip
* Channel Info Currently Setup AS AETR you can change this by changing the PPM Value in the main loop
* Ch1 A (Steering) == ppm[0]
* Ch2 E (Throttle) == ppm[1]
* Ch3 T (NOT USED) == ppm[2]
* Ch4 R (NOT USED) == ppm[3]
* Ch5 AUX1 (NOT USED) == ppm[4]
* Ch6 AUX2 (NOT USED) == ppm[5]
* Ch7 AUX3 (NOT USED) == ppm[6]
* Ch8 AUX4 (NOT USED) == ppm[7]
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
// Includes for PS3 Controller
// https://github.com/felis/USB_Host_Shield_2.0/archive/master.zip
#include <PS3USB.h>
USB Usb;
PS3USB PS3(&Usb);
// Includes and Defines for Adafruit RGB LCD Shield
// https://github.com/adafruit/Adafruit-RGB-LCD-Shield-Library/archive/refs/heads/master.zip
#include <LiquidCrystal.h>
#include <Wire.h>
#include <Adafruit_RGBLCDShield.h>
#include <utility/Adafruit_MCP23017.h>
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// Define RGB LCD Colours
#define RED 0x1
#define GREEN 0x2
// Setup some variables
int steeringTrim = 0;
int steeringTrimLCD = 0;
int speedSetting = 1;
int speedMax = 1590;
int speedMin = 1410;
////////////// PPM
* PPM generator originally written by David Hasko
* on https://code.google.com/p/generate-ppm-signal/
//////////////////////CONFIGURATION///////////////////////////////
#define CHANNEL_NUMBER 8 //set the number of chanels
#define CHANNEL_DEFAULT_VALUE 1500 //set the default servo value
#define FRAME_LENGTH 22500 //set the PPM frame length in microseconds (1ms = 1000µs)
#define PULSE_LENGTH 300 //set the pulse length
#define onState 1 //set polarity of the pulses: 1 is positive, 0 is negative
#define sigPin 3 //set PPM signal output pin on the arduino
#define SWITCH_PIN 16
#define CHANNEL_TO_MODIFY 11
#define SWITCH_STEP 100
byte previousSwitchValue;
/*this array holds the servo values for the ppm signal
change these values in your code (usually servo values move between 1000 and 2000)*/
int ppm[CHANNEL_NUMBER];
int currentChannelStep;
bool printAngle;
uint8_t state = 0;
#if !defined(__MIPSEL__)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while (1); //halt
Serial.print(F("\r\nPS3 USB Library Started"));
previousSwitchValue = HIGH;
//initiallize default ppm values
for(int i=0; i<CHANNEL_NUMBER; i++){
if (i == 2 || i == CHANNEL_TO_MODIFY) {
ppm[i] = 1000;
ppm[i]= CHANNEL_DEFAULT_VALUE;
pinMode(sigPin, OUTPUT);
pinMode(SWITCH_PIN, INPUT_PULLUP);
digitalWrite(sigPin, !onState); //set the PPM signal pin to the default state (off)
// Set up the LCD's number of columns and rows and display static text
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("Steer trim: 0 ");
lcd.setCursor(0, 1);
lcd.print("Speed: 1");
lcd.setCursor(15, 1);
lcd.print("Q");
cli();
TCCR1A = 0; // set entire TCCR1 register to 0
TCCR1B = 0;
OCR1A = 100; // compare match register, change this
TCCR1B |= (1 << WGM12); // turn on CTC mode
TCCR1B |= (1 << CS11); // 8 prescaler: 0,5 microseconds at 16mhz
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
sei();
currentChannelStep = SWITCH_STEP;
Usb.Task();
if (PS3.PS3Connected) {
// Steering
// Attached to PS3 Left Joystick X Axis
// First calculate trim
// Steering trim adjusted by Left and Right D-Pad
if (PS3.getButtonClick(LEFT)){ // Incrementally trim steering to turn left
steeringTrim = steeringTrim - 5;
steeringTrimRefreshLCD();
if (PS3.getButtonClick(RIGHT)){ // Incrementally trim steering to turn right
steeringTrim = steeringTrim + 5;
if (PS3.getAnalogHat(LeftHatX)) { // Centre stick value = 127, full left = 0, full right = 255. Deadzone provided between 124 and 130.
if (PS3.getAnalogHat(LeftHatX) > 130 || PS3.getAnalogHat(LeftHatX) < 124) {
ppm[0] = map(PS3.getAnalogHat(LeftHatX), 0 , 255, 1000, 2000) + steeringTrim;
ppm[0] = 1500 + steeringTrim;
// Throttle
// Attached to PS3 Left Joystick Y Axis
// Allows adjustment of the speed range to allow a lower maximum speed to accommodate beginners
if (PS3.getButtonClick(UP) && speedSetting < 4) {
speedSetting = speedSetting + 1;
Serial.println(speedSetting);
speedSettingRefreshLCD();
if (PS3.getButtonClick(DOWN) && speedSetting > 1) {
speedSetting = speedSetting - 1;
if (speedSetting == 1) {
speedMax = 1590;
speedMin = 1410;
if (speedSetting == 2) {
speedMax = 1700;
speedMin = 1300;
if (speedSetting == 3) {
speedMax = 1850;
speedMin = 1150;
if (speedSetting == 4) {
speedMax = 2000;
speedMin = 1000;
if (PS3.getAnalogHat(LeftHatY)) { //Centre stick value = 127, full down/reverse = 255, full up/forward = 0. Deadzone provided between 124 and 130.
if (PS3.getAnalogHat(LeftHatY) > 130 || PS3.getAnalogHat(LeftHatY) < 124) {
ppm[1] = map(PS3.getAnalogHat(LeftHatY), 255 , 0, speedMin, speedMax);
ppm[1] = 1500;
// All available PS3 Buttons - placed here for reference
// if (PS3.getButtonClick(UP))
// Serial.println(F("Up"));
// if (PS3.getButtonClick(DOWN))
// Serial.println(F("Down"));
// if (PS3.getButtonClick(LEFT))
// Serial.println(F("Left"));
// if (PS3.getButtonClick(RIGHT))
// Serial.println(F("Right"));
// if (PS3.getButtonClick(SHARE))
// Serial.println(F("Share"));
// if (PS3.getButtonClick(OPTIONS))
// Serial.println(F("Options"));
// if (PS3.getButtonClick(TOUCHPAD))
// Serial.println(F("Touchpad"));
// if (PS3.getButtonClick(PS))
// Serial.println(F("PS"));
// if (PS3.getButtonClick(L1))
// Serial.println(F("L1"));
// if (PS3.getButtonClick(R1))
// Serial.println(F("R1"));
// if (PS3.getButtonClick(L2))
// Serial.println(F("L2"));
// if (PS3.getButtonClick(R2))
// Serial.println(F("R2"));
// if (PS3.getButtonClick(L3))
// Serial.println(F("L3"));
// if (PS3.getButtonClick(R3))
// Serial.println(F("R3"));
// if (PS3.getButtonClick(TRIANGLE))
// Serial.println(F("TRIANGLE"));
// if (PS3.getButtonClick(CIRCLE))
// Serial.println(F("CIRCLE"));
// if (PS3.getButtonClick(CROSS))
// Serial.println(F("CROSS"));
// if (PS3.getButtonClick(SQUARE))
// Serial.println(F("SQUARE"));
// if (PS3.getAnalogButton(L2) > 0 || PS3.getAnalogButton(R2) > 0) {
// if (PS3.getAnalogButton(L2) > 0) {
// Serial.print(F("L2: "));
// Serial.print(PS3.getAnalogButton(L2));
// Serial.print("\t");
// if (PS3.getAnalogButton(R2) > 0) {
// Serial.print(F("R2: "));
// Serial.print(PS3.getAnalogButton(R2));
// Serial.println();
if (PS3.PS3Connected == false){
lcd.setBacklight(RED);
ppm[1] = 1500; // if controller is disconnected for some reason, throttle gets zeroed
lcd.setBacklight(GREEN);
//Uncomment these for debugging if you want to see the ppm value for each channel
//Note: uncommenting these can disrupt the ppm signal so should be re-commented before actual use
//Serial.print("CH1: ");Serial.print(ppm[0]);Serial.print("\t");
//Serial.print("CH2: ");Serial.print(ppm[1]);Serial.print("\t");
//Serial.print("CH3: ");Serial.print(ppm[2]);Serial.print("\t");
//Serial.print("CH4: ");Serial.print(ppm[3]);Serial.print("\t");
//Serial.print("CH5: ");Serial.print(ppm[4]);Serial.print("\t");
//Serial.print("CH6: ");Serial.print(ppm[5]);Serial.print("\t");
//Serial.print("CH7: ");Serial.print(ppm[6]);Serial.print("\t");
//Serial.print("CH8: ");Serial.print(ppm[7]);Serial.print("\n");
//Serial.println(speedSetting);
ISR(TIMER1_COMPA_vect){ //leave this alone
static boolean state = true;
TCNT1 = 0;
if (state) { //start pulse
digitalWrite(sigPin, onState);
OCR1A = PULSE_LENGTH * 2;
state = false;
} else{ //end pulse and calculate when to start the next pulse
static byte cur_chan_numb;
static unsigned int calc_rest;
state = true;
if(cur_chan_numb >= CHANNEL_NUMBER){
cur_chan_numb = 0;
calc_rest = calc_rest + PULSE_LENGTH;//
OCR1A = (FRAME_LENGTH - calc_rest) * 2;
calc_rest = 0;
else{
OCR1A = (ppm[cur_chan_numb] - PULSE_LENGTH) * 2;
calc_rest = calc_rest + ppm[cur_chan_numb];
cur_chan_numb++;
// Function to update steering trim setting information on LCD
// Converts steeringTrimLCD from negative and positive numbers to L and R
void steeringTrimRefreshLCD() {
steeringTrimLCD = map(steeringTrim, -100, 100, -20, 20); // Remap steering trim adjustment to single increments
if (steeringTrimLCD < 0) {
steeringTrimLCD = abs(steeringTrimLCD);
lcd.setCursor(12, 0);
lcd.print(String(steeringTrimLCD) + "L ");
} else if (steeringTrimLCD > 0) {
lcd.print(String(steeringTrimLCD) + "R ");
lcd.print(String(steeringTrimLCD) + " ");
// Function to update Speed setting information on LCD
void speedSettingRefreshLCD() {
lcd.setCursor(7, 1);
lcd.print(String(speedSetting));
The Quadtick has coding that turns actions into PS3 outputs that are sent to the Arduino, the Arduino reads the inputs, converts them into PPM signals that are sent to the transmitter out of Arduino pin 3.
I cannot find or get a USB host controller to work so I need any type of Arduino that can read input from a USB, be powered by battery, host an LCD screen and send commands to a PPM transmitter.
Hope this helps.
