I have measured voltage on the Nreset, SDA and SCL pins and they are all fine, the only thing i am afraid of is that i melted the chip, but i tried 5 chips and none of them worked.
i am using the simple I2C adress finder code here:
// SPDX-FileCopyrightText: 2023 Carter Nelson for Adafruit Industries
// SPDX-License-Identifier: MIT
// i2c_scanner
// Modified from https://playground.arduino.cc/Main/I2cScanner/
#include <Wire.h>
// Set I2C bus to use: Wire, Wire1, etc.
#define WIRE Wire
WIRE.begin(1,2,100000);
while (!Serial)
delay(10);
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
WIRE.beginTransmission(address);
error = WIRE.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(500); // wait 5 seconds for next scan
there isnt a problem with the board or pins since i have tried to scan the SX1509 on pins 8 and 9 and I also tried connecting another I2C device to the pins 1 and 2 and it worked fine with no problem. is changing the adress a good idea?
the solders also look fine and i can provide gerber for the pcb if that helps
its an esp32 supermini S3, the i2c worked with other i2c devices fine on those pins.
leaving it bland doesnt also work, i just pasted my most recent code with most tweaks, but i will try it later with the original frequency again
I cant send photos now but there is a pinout i am using, most of the pins dont work like advertised but pins 1 and 2 worked on another i2c device.
Tying nreset to ground would keep the board in reset, because of the n before reset which stands for not negating the whole logic
when signal is low it resets and when signal is high id doesnt
EDIT: Checking your schematic more carefully, I see you have done this (bottom of schematic). The floating NRESET shown at the top of your schematic fooled me at first.
Should i try to solder it according to the solder profile? I soldered it for about 250 degrees with a hot air gun for about 20 seconds with about 3 cm gap from nozzle to component
Rosin flux and sn67pb33 solder paste 187 melting point.
the footprint should be fine, i tested it with a multimeter eith continuity mode, but cant test if the pads are soldered because it is a no lead chip
You don't use flux with a paste.
You should follow the profile for the paste you are using.
If I'm going to hand solder a part, I usually make the pads a little longer so that I can get at it with an iron if needed. It also makes checking for shorts and continuity easy
