Help with test program for 4g/LTE board
Hello,
I'm trying to use this board, with Arduino uno.
I have wired it up, and using this code from ChatGPT, I dont get any response. Any ideas?
#include <SoftwareSerial.h>
SoftwareSerial sim7600(0, 1);
  sim7600.begin(115200);
  Serial.println("SIM7600G-H testprogram");
  sendATCommand("AT");
  if (sim7600.available()) {
    while (sim7600.available()) {
      char c = sim7600.read();
      Serial.write(c);
  if (Serial.available()) {
    String userInput = Serial.readString();
    sim7600.println(userInput);
    Serial.print("Sendt til SIM7600: ");
    Serial.println(userInput);
void sendATCommand(String command) {
  Serial.print("Sender: ");
  Serial.println(command);
  sim7600.println(command);
    Serial.write(c);
Ask ChatGPT why it doesn't work.
And you’re surprised ?
Me? No. Perhaps you should ask OP?
Just lemme ask DeepShit, I mean DeepSeek.
What is your goal? Just to evaluate this board, or something more? Tell us your plan.
Hello,
My goal is to connect to my HiveMQ MQTT broker, and publish data. For testing I just want to publish a counter value.
Below is the code i'm currently testing.
// Define the pins for SoftwareSerial
#define SIM7600_TX_PIN 4  // Arduino RX (connect to SIM7600 TX)
#define SIM7600_RX_PIN 5  // Arduino TX (connect to SIM7600 RX)
// Define the pins for PWRKEY and SLEEP
#define PWRKEY_PIN 12  // PWRKEY pin
#define SLEEP_PIN 13   // SLEEP pin
// Create a SoftwareSerial object
SoftwareSerial sim7600Serial(SIM7600_TX_PIN, SIM7600_RX_PIN);
// Counter variable
int counter = 0;
// MQTT Broker Details
const char* MQTT_BROKER = "**URL TO BROKER**"; // Replace with your broker address
const int MQTT_PORT = 8883;                   // TLS port
const char* MQTT_CLIENT_ID = "myClientID";    // Replace with your client ID
const char* MQTT_USERNAME = "**USERNAME**";  // Replace with your username
const char* MQTT_PASSWORD = "**PASSWORD**";  // Replace with your password
const char* MQTT_TOPIC = "myTopic";           // Replace with your topic
  // Initialize the serial communication
  Serial.begin(9600);        // For debugging (Serial Monitor)
  sim7600Serial.begin(115200); // For SIM7600 communication (baud rate set to 115200)
  // Initialize the PWRKEY and SLEEP pins
  pinMode(PWRKEY_PIN, OUTPUT);
  pinMode(SLEEP_PIN, OUTPUT);
  // Power on the SIM7600 module
  digitalWrite(PWRKEY_PIN, LOW);
  digitalWrite(PWRKEY_PIN, HIGH);
  delay(2000);
  // Disable sleep mode (SLEEP pin HIGH = active mode, LOW = sleep mode)
  digitalWrite(SLEEP_PIN, HIGH);
  // Wait for the module to initialize
  delay(10000);
  // Send AT commands to check if the module is responding
  sendCommand("AT", 1000);
  sendCommand("AT+CPIN?", 1000);
  sendCommand("AT+CREG?", 1000);
  sendCommand("AT+CGATT=1", 1000); // Enable GPRS
  sendCommand("AT+CGATT?", 1000);
  // Configure TLS without certificate verification
  sendCommand("AT+CSSLCFG=\"sslversion\",0,4", 1000); // Use TLS 1.2
  sendCommand("AT+CSSLCFG=\"authmode\",0,1", 1000);  // Disable certificate verification
  // Initialize MQTT
  sendCommand("AT+CMQTTSTART", 1000); // Start MQTT service
  sendCommand("AT+CMQTTACCQ=0,\"" + String(MQTT_CLIENT_ID) + "\"", 1000); // Acquire client ID
  // Set username and password
  sendCommand("AT+CMQTTWILLTOPIC=0," + String(strlen(MQTT_USERNAME)), 1000);
  sendCommand(MQTT_USERNAME, 1000);
  sendCommand("AT+CMQTTWILLMSG=0," + String(strlen(MQTT_PASSWORD)) + ",1", 1000);
  sendCommand(MQTT_PASSWORD, 1000);
  // Connect to the MQTT broker
  String connectCmd = "AT+CMQTTCONNECT=0,\"" + String(MQTT_BROKER) + "\"," + String(MQTT_PORT) + ",60,1";
  sendCommand(connectCmd, 5000); // Connect with TLS
  Serial.println("SIM7600 initialization and MQTT setup complete.");
  // Increment the counter (0-100)
  counter++;
  if (counter > 100) {
    counter = 0;
  // Publish a message to the MQTT topic
  String payload = "Counter: " + String(counter);
  sendCommand("AT+CMQTTTOPIC=0," + String(strlen(MQTT_TOPIC)), 1000);
  sendCommand(MQTT_TOPIC, 1000);
  sendCommand("AT+CMQTTPAYLOAD=0," + String(payload.length()), 1000);
  sendCommand(payload, 1000);
  sendCommand("AT+CMQTTPUB=0,1", 1000); // Publish with QoS 1
  // Wait for 5 seconds before publishing the next message
  delay(5000);
// Function to send a command and read the response
void sendCommand(const String& command, int delayTime) {
  sim7600Serial.println(command);
  delay(delayTime);
  readResponse();
// Function to read the response from the SIM7600 module
void readResponse() {
  while (sim7600Serial.available()) {
    String response = sim7600Serial.readString();
    Serial.println("SIM7600 Response: " + response);
And, this is what happens in serial monitor. Something is wrong with the MQTT....
22:19:17.922 ->
22:19:19.854 -> SIM7600 Response: AT+CMQTTWILLTOPIC=0,8
22:19:19.893 -> >
22:19:21.869 -> SIM7600 Response: *** MY USERNAME ***
22:19:21.869 -> OK
22:19:21.869 ->
22:19:23.899 -> SIM7600 Response: AT+CMQTTWILLMSG=0,10,1
22:19:23.900 -> >
22:19:25.892 -> SIM7600 Response: *** MY PASSWORD ***
22:19:25.892 -> OK
22:19:25.892 ->
22:19:31.894 -> SIM7600 Response: AT+CMQTTCONNECT=0,"***URL TO MY BROKER ***
22:19:31.933 -> SIM7600 initialization and MQTT setup complete.
22:19:33.895 -> SIM7600 Response: AT+CMQTTTOPIC=0,7
22:19:33.941 -> +CMQTTTOPIC: 0,11
22:19:33.941 ->
22:19:33.941 -> ERROR
22:19:33.941 ->
22:19:36.894 -> SIM7600 Response: AT+CMQTTPAYLOAD=0,10
22:19:36.941 -> +CMQTTPAYLOAD: 0,11
22:19:36.941 ->
22:19:36.941 -> ERROR
22:19:36.941 ->
22:19:39.898 -> SIM7600 Response: AT+CMQTTPUB=0,1
22:19:39.944 -> +CMQTTPUB: 0,12
22:19:39.944 ->
22:19:39.944 -> ERROR
22:19:39.944 ->
22:19:46.914 -> SIM7600 Response: AT+CMQTTTOPIC=0,7
22:19:46.961 -> +CMQTTTOPIC: 0,11
22:19:46.961 ->
22:19:46.961 -> ERROR
22:19:46.961 ->
22:19:49.921 -> SIM7600 Response: AT+CMQTTPAYLOAD=0,10
22:19:49.921 -> +CMQTTPAYLOAD: 0,11
22:19:49.921 ->
22:19:49.959 -> ERROR
22:19:49.959 ->
22:19:52.924 -> SIM7600 Response: AT+CMQTTPUB=0,1
22:19:52.924 -> +CMQTTPUB: 0,12
22:19:52.924 ->
22:19:52.924 -> ERROR
22:19:52.924 ->
22:19:59.910 -> SIM7600 Response: AT+CMQTTTOPIC=0,7
22:19:59.956 -> +CMQTTTOPIC: 0,11
22:19:59.956 ->
22:19:59.956 -> ERROR
22:19:59.956 ->
22:20:02.931 -> SIM7600 Response: AT+CMQTTPAYLOAD=0,10
22:20:02.931 -> +CMQTTPAYLOAD: 0,11
22:20:02.931 ->
22:20:02.971 -> ERROR
22:20:02.971 ->
22:20:05.933 -> SIM7600 Response: AT+CMQTTPUB=0,1
22:20:05.933 -> +CMQTTPUB: 0,12
22:20:05.933 ->
22:20:05.933 -> ERROR
MQTT isn't my ballpark at all, but the timestamps in that log are messed up.
