Help with the Arduino BLE
Hello, I am trying to connect my 2 Arduino Nanos BLE to each other. The current setup is Arduino(1) has a distance sensor, Arduino(2) has a button and LCD screen. I would like to be able to read the distance sensor on Arduino(1) and send the data to Arduino(2) and view the data on the LCD screen. After use a button on Arduino(2) to control a switch on Arduino(1)
Arduino(2) code
#include <ArduinoBLE.h>
BLEService customService("19B10000-E8F2-537E-4F6C-D104768A1214");
BLEUnsignedIntCharacteristic distanceSensor("19b10001-e8f2-537e-4f6c-d104768a1214", BLERead | BLEWrite);
  while(!Serial);
  BLE.begin();
  BLE.setLocalName("COM port7");
  BLE.setAdvertisedService(customService);
  customService.addCharacteristic(distanceSensor);
  BLE.addService(customService);
  BLE.advertise();
  Serial.println("Being advertised");
  Serial.println("Bluetooth® Low Energy Central - Conteol");
  BLE.scanForUuid("19b10000-e8f2-537e-4f6c-d104768a1214");
    BLEDevice peripheral = BLE.available();
  if (peripheral) {
    Serial.print("Found ");
    Serial.print(peripheral.address());
    Serial.print(" '");
    Serial.print(peripheral.localName());
    Serial.print("' ");
    Serial.print(peripheral.advertisedServiceUuid());
    if (peripheral.localName() != "COM port5"){
      return;
    BLE.stopScan();
    controlBoard(peripheral);
void controlBoard(BLEDevice peripheral){
  Serial.println("Connecting ...");
  if (peripheral.connect()){
    Serial.println("Connected");
    Serial.println("Failed to connect!");
    return;
   // discover peripheral attributes
  Serial.println("Discovering attributes ...");
  if (peripheral.discoverAttributes()) {
    Serial.println("Attributes discovered");
    Serial.println("Attribute discovery failed!");
    peripheral.disconnect();
    return;
BLECharacteristic distanceSensor = peripheral.characteristic("19b10001-e8f2-537e-4f6c-d104768a1214");
    if (!distanceSensor) {
    Serial.println("Peripheral does not have distanceSensor characteristic!");
    return;
  } else if (!distanceSensor.canWrite()) {
    Serial.println("Peripheral does not have a writable distanceSensor characteristic!");
    return;
  while(peripheral.connected()){
    if (distanceSensor.written()) {
        unsigned int value = distanceSensor.readValue();
        Serial.print("Received value: ");
        Serial.println(value);
  Serial.println("Peripheral disconnected");
Ardunio(1) code
  long previousMillis = 0; // last time readings were checked, in ms
  unsigned int previousDistance = 0;
  const float UPDATE_FREQUENCY = 2000;
  int trigPin= 12;
  int echoPin= 11;
  float distanceToTarget;
  float pingTravelTime;
  float pingTravelDistance;
  BLEUnsignedIntCharacteristic BLE_distance("19b10001-e8f2-537e-4f6c-d104768a1214", BLERead | BLEWrite);
  pinMode(trigPin,OUTPUT);
  pinMode(echoPin,INPUT);
  while(!Serial);
      if(!BLE.begin()){
      Serial.println("starting Bluetooth® Low Energy module failed!");
      while(1);
  BLE.setLocalName("COM port5");
  //add what you need to send
  customService.addCharacteristic(BLE_distance);
  BLE_distance.setValue(0);
  BLE.advertise();
 BLEDevice central = BLE.central();
  if (central){
    Serial.print("Connected to central: ");
    Serial.println(central.address());
    while (central.connected()){
        long currentMillis = millis();
        if (currentMillis - previousMillis >= UPDATE_FREQUENCY) {
           updateReadings();
    Serial.print(F("Disconnected from central: "));
 unsigned int getDistance() {
  readValues();
  return (unsigned int) (distanceToTarget);
void updateReadings() {
   unsigned int distance = getDistance();
    if (distance != previousDistance){}
    Serial.print("Distance: ");
    Serial.println(distance);
    BLE_distance.writeValue(distance);
    previousDistance = distance;
void readValues(){
    digitalWrite(trigPin,LOW);
    delayMicroseconds(10);
    digitalWrite(trigPin,HIGH);
    pingTravelTime=pulseIn(echoPin,HIGH);
    pingTravelDistance=(pingTravelTime*765.*5280.*12.)/(3600.*1000000.);
    distanceToTarget=(pingTravelDistance/2)*100;
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it is not related to IDE version 2.0
i have updated my code hopefully this will make it easier to troubleshoot.
Central Code
BLEService customService("19b10000-e8f2-537e-4f6c-d104768a1214");
BLEUnsignedIntCharacteristic BLE_distance("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);
BLEUnsignedIntCharacteristic data("19B10002-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);
  while(!Serial);
    BLE.begin();
    Serial.println("Bluetooth® Low Energy Central");
    customService.addCharacteristic(data);
  if (peripheral) {
    // discovered a peripheral, print out address, local name, and advertised service
    Serial.print(" '");
    Serial.print("' ");
    if (peripheral.localName() != "COM port5") {
      return;
    // stop scanning
    BLE.stopScan();
    controlLed(peripheral);
    // peripheral disconnected, start scanning again
void controlLed(BLEDevice peripheral) {
  // connect to the peripheral
  if (peripheral.connect()) {
    return;
    return;
  BLECharacteristic BLE_distance = peripheral.characteristic("19B10001-E8F2-537E-4F6C-D104768A1214");
  BLECharacteristic data = peripheral.characteristic("19B10002-E8F2-537E-4F6C-D104768A1214");
  while(peripheral.connected()) {
   BLE_distance.written();
   Serial.print(F("Received value: "));
   Serial.println(BLE_distance.readValue());
   Serial.println(" Inches");
   delay(2000);
peripheral Code
  int trigPin= 12;
  int echoPin= 11;
  int value;
  while(!Serial);
  if (!BLE.begin()) {
    while (1);
    BLE.advertise();
      if(!BLE.advertise()){
        Serial.println("Failed To Advertise");
  if (central) {
    // print the central's MAC address:
    BLE.stopScan();
    sendData(central);
  //Serial.println("not connected");
void sendData(BLEDevice central){
  if (central.connect()){
    return;
   // discover Central attributes
  if (central.discoverAttributes()) {
    central.disconnect();
    return;
  BLECharacteristic BLE_distance = central.characteristic("19B10001-E8F2-537E-4F6C-D104768A1214");
  BLECharacteristic data = central.characteristic("19B10002-E8F2-537E-4F6C-D104768A1214");
    if (!BLE_distance) {
    Serial.println("Central does not have distanceSensor characteristic!");
    return;
  } else if (!BLE_distance.canWrite()) {
    Serial.println("Central does not have a writable distanceSensor characteristic!");
    return;
    if (!data) {
    Serial.println("Central does not have data characteristic!");
    return;
  } else if (!data.canWrite()) {
    Serial.println("Central does not have a writable data characteristic!");
    return;
      updateReadings();
    if (data.written()){
      Serial.println(String((char*)(data.value())));
void readValues(){
  readValues();
What troubles are we trying to shoot?
Does the peripheral code work correctly with a phone app like LightBlue or nrfConnect?
hi!
a quick look at your code tends to make me think you're not ready for a proper use of the BLE.
You use one arduino as central. This one is supposed to look for a specific service to connect.
You use another one as peripheral. This last one support the broadcast of the service and centrals can connect to it.
Therefore, if I see
in your cental code, there is a problem in my opinion.
Focus on the peripheral. Make it generates the BLE service
and add it every characteristics you need/want.
Each one of this characteristic should be related to the peripheral activities (meaning the peripheral handle the value, don't wait for an input by the master).
Every characteristic here to be shared with the central are advertised (the peripheral tell to everyone around "hey I got some data I will please to share").
Normally, any BLE app (phone, or PC) could connect to it and see the characteristic shared. It is a good test for debugging as it don't rely on your master code (and eventually mistakes in code).
THEN, you code your master in order it launch a BLE communication and look for your specific peripheral, by the use of the service UUID.
At this point, you can play and exchange data.
Note peripheral and master are names from the BLE protocol. It is your choice for wich is wich, but the peripheral broadcast the service and the master connect to it.
May I propose you to take a look at example in BLE library? Take some time to see the difference between Master and Peripheral behaviour.
Hope you will be brave enough to go back to your code, define precisely your needs (seems ok) and apply it to the specific behavior of BLE protocol.
Maybe an example from my personnal experience: my arduino remote controlled toy car is a peripheral. It contains data to drive the motors, and data from the IMU (accelerometer, gyroscope....) as an arduino 33BLE is the core of the device.
My remote control is driven by an Arduino 33IOT and plays the master: at start up, it seeks the service provided by the car (wisely named "FOURWHEELS"), connect, then allow data exchange: position of the joystick are sent to the car and IMU's data from the car are displayed on the OLED of the remote.
