And even if it didnt work for some compleatly unknown reason, we could just add a bigger battery.
Yeah, a 9V will work, but for how long? Without knowing the amperage requirements of a single igniter, we can't really know. I have read, though, that a 9V can supply 500mAH of capacity, which really isn't a lot. Plus 9V batteries are expensive.
You would be much better off in the long run to at least use a C or D-cell battery pack supplying 9-12 volts to the igniters. It will be less expensive, last longer, and give you more launches.
According to this PDF, though, for Estes igniters (which I have to assume you are using - or at least, something similar):
http://www.estesrockets.com/images/uploads/2811_Estes_Model_Rocket_Launch_Systems.pdf
...because of the extremely low resistance of the igniter, the larger the voltage of the battery, the greater the current needed (which is also going to vary depending on the length and gauge of the wire from the controller to the igniter) - and ultimately this determines how long your battery can last based on its amp-hour rating.
The bad thing about a 9V is that it might get to a point where it can't push enough current to fully ignite the igniter, but perhaps enough to start a "slow burn", that can later (a few seconds or more) ignite, shooting the rocket off. This can be a "danger factor", if you wonder why the rocket didn't go off, and approach it, then it takes of (nearly or fully "in your face"). If you or your students don't understand this, you all need to study the above PDF; in theory, you might be better off over time and safety-wise with a few D-cell flashlight batteries in series, than the simple 9-volt.
Plus you'll get to learn Ohm's Law!
