I have two XBees Series 2, and I need to learn how to use them for a research that I will do. Does anyone know where I can download the library XBee, I use Arduino 1.0 and it doesn't have this library. Anyone can give an example or a site that teaches sets them.
Hi Edinho,
Take a look at these two links for the xbee's libraries.
I looked at these sites and I've got some questions.
To configure the XBee firmware I need software? Where can I download it? As I'm using the series 2 I can set it at the prompt of the Arduino?
To communicate two XBees I need to configure the firmware, or what comes standard is enough?
Yes.
X-CTU from digi.com
No clue what you are asking. Probably not.
Yes.
No.
I downloaded the X-CTU software and it has many parameters to be configured. Does anyone have an example of how to configure them.
I use Arduino 1.0 and XBee Series 2 modem XB24-B, I need to update the firmware on the XBee to work with this version of the Arduino?
No.
There are several tutorials around. I expect that Jack will be along shortly to address any specific questions you have.
Hi, see if this gets you started:
...(I feel a blog post coming on)
See. Jack did come along...
PaulS:
Correct as usual, Paul ![]()
