Help writing code for HMI screen
Hello!
I have DOP-107BV HMI from Delta. I'm trying to display a number on the screen without any luck! Since I'm not knowledgeable in the field, I can't find thing easily, but I can do as you say. I couldn't do it while the HMI is set to master or slave using the Modbus settings.
On the HMI, I've created a numeric element and gave it the read address of 40001. This will have the letter W in front of it, on the Delta app it say somelink like {Link1}W40001. On the arduino uno, I set pins 10 and 11 as serial ports.
The HMI is connected to 24v power source. The arduino Rx is connected to the HMI Tx, and the Tx is connected to the Rx.
On slave mode, the HMI doesn't do anything. On the master mode, it keeps complaining about communication error.
I know the HMI is OK since it's working fine with a PLC.
Can someone please write a small code that will use pins 10 and 11 to print a number on the HMI that has the read address 40001 using the RS-232 serial protocol? This will help me a lot to understand how this thing work.
Thank you!
Why don't you use a Modbus simulator program running on a PC to test it?
I had no idea such thing exist!!
And this thing work with linux without issues?
google is your friend.
