Hi, First of all, sorry for my poor English!
I am working on a project in which I have to display some integer values on Weintek HMI and after several intervals of time, I want to write data on Arduino UNO from HMI (to change the speed of the DC motor). Using Arduino UNO and MAX485, I established the communication between Arduino & HMI, and values were successfully displayed on HMI. But I am unable to set communication for writing data on Arduino UNO from HMI . I want to set the speed of the DC motor connected to the Arduino at any time when the process is executing. Code is here
#include <modbus.h>
#include <modbusDevice.h>
#include <modbusRegBank.h>
#include <modbusSlave.h>
modbusDevice regBank;
modbusSlave slave;
#define RS485TxEnablePin 2
#define RS485Baud 9600
#define RS485Format SERIAL_8E1
// Nema 23
#include <AccelStepper.h>
AccelStepper stepper (AccelStepper::DRIVER, 9,8);
int gearRatio = 10;
int RpmSet = 10;
int DirRpm = -(RpmSet);
int Speed = DirRpm*gearRatio*3.333334;
unsigned long previousmillis = 0;
// Vacuum Motor
#define RPWM 5
#define LPWM 6
//int Vacuumspeed = 150;
//int Vacuumspeed ;
// seed counting
int A_V;
int seedcount, missing, doubling, interval = 0;
int null, flag, flag1, flag2, flag3 = 0;
unsigned long PST=0;
float single;
int singulation=100;
{ //Serial.begin(9600);
//Assign the modbus device ID.
regBank.setId(1);
//Add Analog Input registers to the register bank
regBank.add(30001); //Singulation
regBank.add(30002); //Seed Counted
regBank.add(30003); //Seed Missed
regBank.add(30004); //Seed doubled
regBank.add(30005); //seed to seed distance
regBank.add(30009); //Nema RPM
//Add Analog OUTPUT registers to the register bank
regBank.add(40001); //Vacuum speed
slave._device = ®Bank;
slave.setBaud(&Serial,RS485Baud,RS485Format,RS485TxEnablePin);
// Vacuum
pinMode(RPWM, OUTPUT);
pinMode(LPWM, OUTPUT);
analogWrite(LPWM, 0);
//Nema
stepper.setMaxSpeed(1000);
stepper.setSpeed(Speed);
{ //int Vacuumspeed;
word Vacuumspeed = regBank.get(40001);
analogWrite(RPWM, Vacuumspeed); //vacuum
stepper.runSpeed(); //nema
//Seed
A_V = analogRead(A0);
//Serial.println(A_V);
if (A_V >=30 && flag == 0)
seedcount = seedcount+1;
unsigned long SeedT = millis();
//Serial.println(SeedT);
if(PST==0 ){
null =1;
flag1=1;
PST = SeedT;
if( null == 0 && flag1 == 1){
interval = SeedT-PST;
flag1=0;
if( null==1 && flag1==1){
null=0;
if(((SeedT-PST) >= (interval+80)) && flag2 == 0) {
missing = missing+1; // missing
flag2=1;
if(((SeedT-PST) < (interval+15)) && flag2 == 1){
flag2 = 0;
if(((SeedT-PST) < (interval-30)) && flag3 == 0){
doubling = doubling+1; // doubling
flag3=1;
if(((SeedT-PST) > (interval-20)) && flag3 == 1){
flag3=0;
PST = SeedT;
single = seedcount*100/(missing+seedcount); //singulation
singulation = single;
flag=1;
//Serial.println(seedcount);
//Serial.println(missing);
//slave.run();
else if (A_V < 23 && flag == 1)
flag = 0;
regBank.set(30001, (int) singulation);
regBank.set(30002, (int) seedcount);
regBank.set(30003, (int) missing);
regBank.set(30004, (int) doubling);
regBank.set(30005, (int) interval);
regBank.set(30009, (int) RpmSet);
//regBank.set(30007, (int) Vacuumspeed); //from 0 - 1023
slave.run();
//delay(300);
I am using 4x 1 register to set the speed of the motor. every time I set the value on HMI, nothing happens to the motor.
I have followed this tutorial to understand MODBUS communication and used the same RS485 module & MODBUS library provided.
you can find the library in the provided link.
using the analog input registers (as in the code), values are displayed on the HMI screen but the problem is only while writing data to Arduino. I am beginner in programming and really need your help. I also opened the modbusSlave.cpp file to understand the functionality of the RS485 enabler pin but still unable to fix the problem. I am also familiar with the half duplex and full duplex mode of RS485. Plz help me how to modify that code or any thing that will be helpful for me.
Thankyou in Advance.
regards
