when printing to serial port like below
byte x = 255
Serial.print(x, HEX);
outputs FF as expected
but if x is 0 to 15
the output is 0 to F
is there as easy way to make the output 00 to 0F
thanks
byte x = 255
but if x is 0 to 15
thanks
thanks i will try that as for the misspelling
a capital S works and a small gives me an error
error: 'serial' was not declared in this scope
zarobhr:
when printing to serial port like belowbyte x = 255
outputs FF as expected but if x is 0 to 15 the output is 0 to F is there as easy way to make the output 00 to 0F thanks
How about doing it the "right" way?
runtest();
void runtest(void)
char buffer[8];
const char *mask = "%02X\n";
byte x;
for(x=0; x<16; x++) {
sprintf(buffer, mask, x);
Serial.print(buffer);
krupski:
zarobhr:
outputs FF as expected but if x is 0 to 15 the output is 0 to F is there as easy way to make the output 00 to 0F thanksHow about doing it the "right" way?
runtest();
}void loop()
}void runtest(void)
char buffer[8];
byte x;
i have tried both ways the orginal suggestion and the "Right Way"
the both work but the "Right Way" uses 1520 more bytes than the other way. so for now i will do the wrong way, since space will be of importance
i am still open to other suggestions as well
thanks
Imho the code of Delta-G is most pragmatic (short and clear).
You might consider replacing the value 16 with its hex equivalent, and wrapping it in a function so it becomes reusable
serialHEX(byte x)
if (x < 0x10) serial.print('0');
serial.print(x, HEX);
an alternative (for your collection ![]()
serialHEX(byte x)
char h[16] = {'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'}; // might be declared global
serial.print(h[x>>4]);
serial.print(h[x&0x0F];
robtillaart:
serialHEX(byte x)
I thought we'd already got past the correct spelling of "Serial".
(that was left in as an exercise ![]()
sprintf(destination,"write anything here %02X", source);
will do the same e.g 0x0F
sprintf(destination,"write anything here %04X", source);
will print to 4 places e.g 0x000F
zarobhr:
thanks
Well, if you need all the 32K and are up against the edge, then sure do whatever you need to in order to save space.
But, if your sketch only takes up 8K but you can shrink it to 6K, why bother?
I like using "sprintf" because you can do more than just simple conversion to hex.
For example, to print something like "The sensor is at address 0x00FE, it is sampling at 1000 samples per second and the average reading is 1023"
Compare THIS:
Serial.print("The sensor is at address 0x");
if (address < 0x1000) {
Serial.print("0");
if (address < 0x100) {
Serial.print("0");
if (address < 0x10) {
Serial.print("0");
Serial.print(address, HEX);
Serial.print(", it is sampling at ");
Serial.print(samprate, DEC);
Serial.print(" samples per second and the average reading is ");
Serial.print(average, DEC);
Serial.println("");
...to THIS:
char buffer[128];
const char *mask = "The sensor is at address 0x%04X, it is sampling at %d samples per second and the average reading is %d\n";
sprintf (buffer, mask, address, samprate, average);
Need I say more?
Need I say more?
Think you made your point clear and your arguments are definitely valid.
Besides memory, performance can also be an issue. Not tested but I expect sprintf() will execute a bit slower than the "the pragmatic" code if done in a tight loop. [yes I know when printing over serial communication takes most time]
@krupski
Sorry, i didn't realise you had already mentioned Sprintf, but you right it is more versatile
