I have two arduino with lora i want to call their sons in rf
I want one of the arduino to connect to the internet so that I can upload it to the site, I use esp8266 esp-13e, my problem starts because I can not access the esp8266 I connected over the lora component of this uart connection.
Can anyone explain to me how I can access the esp8266 on the lora.
I upload a picture so you can understand the problem I'm dealing with, all I want to do is initially at commends.
Thanks to all the people!
I'm not even going to try to guess what the device is that is dangling from those wires. Nor am I going to guess what that device is connected to. Nor am I going to guess how the two devices are connected. Nor am I going to guess what code is running on the not-exactly-an-Arduino.
Finally, I am not going to guess what you are doing, or what the results are.
Guys first thanks for comment, I do not speak English, this is my second language.
I would be happy if you could try to help me.
Again I will explain the system compiler:
arduino uno
Semtech SX1272 LoRa Mbed Enabled Shield
I have two ardino uno with lora, what I'm interested in doing is make one arduino uno to getway, basically I want to connect the arduino uno to the internet.
My problem:
I can not run esp8266 esp-13e, because I'm using lora it's over the arduino uno I have no room for esp8266 esp-13e so I plugged it into uart connection on top of lora.
I want to explain how I connect the esp8266 esp-13e to lora in order to connect online
means that you want your Arduino to connect to the internet and to the LoRa module
However I don't know what Arduino board you want to use or how you propose to connect it to the internet or what sort of information you want to transfer from the internet using LoRa.
I probably have other questions, but this is enough for now.
yonatanchekol:
Rather than try to explain the technical requirements of your project (in a language you do not understand well) it would be an idea to describe what the project is actually trying to do, there must be a reason for wanting to connect the Arduino to the Internet.
If you cannot put that into words then ask someone else to do it for you.
I apologize for any misunderstanding that has been created here. I thank you for all your excesses to help me.
So I'm planning a system for monitoring fires in the woods
I want to make a lora network, which means I put two arduino uno with lora when the first arduino will receive information from the temperature and smoke sensors and it will transfer them to the second arduino which is actually connected to the internet and the communication between them will be done via RF lora.
As I mentioned one of what arduino will actually getway.
The components I work with are: arduino uno lora sx1272 esp8266-esp13
My problem is how I do the internet connection technically from the components I have a problem that I put the esp8266 component on top of the lora.
I hope I have explained myself well.
I've uploaded a picture url of the system here
Thanks again for a huge help!
