Hi guys, I am trying to build a final project for school. Trying to control a stepper motor speed with a rotary encoder, but so far no luck
I am using a NEMA 17 stepper with a A4988 driver, and the standard rotary encoder. I'm trying to get a base layout for my project, and would appreciate any tips to map the rotary encoder to control the speed of the motor. What I currently have is not working for the speed adjustment.
int startPinState;
int lastStartPinState;
int EMOstate;
const int CLK = 11;
const int DT = 10;
const int SWpin = 9;
const int dirPin = 2;
const int stepPin = 3;
const int startPin = 4;
const int GLED = 5;
const int EMOButton = 13;
const int RLED = 12;
int lastCLKState;
int currentCLKState;
int speedControl;
const int maxSpeed = 500;
const int minSpeed = 0;
  pinMode(startPin, INPUT);
  pinMode(EMOButton, INPUT);
  pinMode(dirPin, OUTPUT);
  pinMode(stepPin, OUTPUT);
  pinMode(CLK, INPUT);
  pinMode(DT, INPUT);
  pinMode(SWpin, INPUT_PULLUP);
  pinMode(RLED, OUTPUT);
  pinMode(GLED, OUTPUT);
  lastCLKState = digitalRead(CLK);
  currentCLKState = digitalRead(CLK);
  if (currentCLKState != lastCLKState) {
    if (digitalRead(DT) != currentCLKState) {
      speedControl++;
      speedControl--;
    speedControl = constrain(speedControl, minSpeed, maxSpeed);
  lastCLKState = currentCLKState;
  Serial.println(speedControl);
  startPinState = digitalRead(startPin);
  if (startPinState == HIGH) {
    digitalWrite(dirPin, LOW);
    digitalWrite(RLED, LOW);
    digitalWrite(GLED, HIGH);
    int speedTime = map(speedControl, minSpeed, maxSpeed, 1000, 500);
    for (int i = 0; i < 100000; i++) {
      digitalWrite(stepPin, HIGH);
      delayMicroseconds(speedTime);
      digitalWrite(stepPin, LOW);
      if (digitalRead(EMOButton) == HIGH) {
        digitalWrite(GLED, LOW);
        digitalWrite(RLED, HIGH);
In what way is it not working , what actually happens? wiring diagram ? Power supply ?
Please read the guidelines on how to post .
HI, @samsand0
Thanks.. Tom.... :smiley: :+1: :coffee: :australia:
Can you use libraries ?
The encoder library would help. And of course any stepper library
Don’t lock your loop in a tighter loop -
you might benefit from studying state machines. Here is a small introduction to the topic: Yet another Finite State Machine introduction
This might help you get the basics working before adding the control etc, to establish you have control of the stepper.
And …. It’s worth getting the parts working on their own .
Get the encoder working and displaying numbers on the screen . Map
It’s values and check that works .
Get the stepper running on its own and try different speeds ( delays between steps ) .
De bugging by printing out your variables to the monitor helps you follow what is happening .
Appreciate your help. Breaking the code down helped a lot. I was able to figure out how to map the rotary encoder values to my motor. Thanks!
Appreciate your help. Adding a stepper library was much easier than using none. Thanks.
Sorry, I will be sure to add everything next time.
