Hi i have this code, but the wifi connection doesnt work, ive enabled the hotspot but nothing happens
#include <WiFi.h>
#include <ESPmDNS.h>
#include <WiFiClient.h>
#include <MFRC522_I2C.h>
#include <ESP32_Servo.h>
Servo myservo1;
Servo myservo2;
MFRC522 mfrc522(0x28);
#define servoPin1 13  // Try GPIO5 instead of 13
#define servoPin2 5  // Try GPIO5 instead of 5
String Password = "";
#define LED_PIN 26
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT 4
#define button1Pin 16  // Tlačidlo 1
#define button2Pin 27
String menuItems[] = { "LED", "Temperature", "Window", "Door" };
int menuSize = sizeof(menuItems) / sizeof(menuItems[0]);
int currentMenuIndex = 0;    // Aktuálna položka menu
bool newButton1State = LOW;  // Tlačidlo stlačené (LOW)
bool newButton2State = LOW;
bool button1State = HIGH;
bool button2State = LOW;
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
String item = "0";
//const char* ssid = "ChinaNet-2.4G-0DF0";
//const char* password = "ChinaNet@233";
const char* ssid = "iPhone";
const char* password = "123Richard";
WiFiServer server(80);
#include <Wire.h>
LiquidCrystal_I2C mylcd(0x27, 16, 2);
//#include < analogWrite.h >
#include "xht11.h"
xht11 xht(17);
#include <ESP32Tone.h>
#define buzzer_pin 25
//#define windowServo 5
//#define doorServo 13
#define waterPin 34
#define fanPin1 19
#define fanPin2 18
#define led_y 12  //Define the yellow led pin to 12
#define waterPin 34
#define gasPin 32
#define pyroelectric 14
unsigned char dht[4] = { 0, 0, 0, 0 };  //Only the first 32 bits of data are received, not the parity bits
//Servo channel
int channel_PWM = 13;
int channel_PWM2 = 10;
int freq_PWM = 50;
int resolution_PWM = 10;
const int PWM_Pin1 = 5;
const int PWM_Pin2 = 13;
int DoorState = 0;
int gasVal;
  Serial.println ("Run Baby");
  mylcd.init();
  mylcd.backlight();
  pinMode(button1Pin, INPUT);  // Nastavenie tlačidiel na vstup
  pinMode(button2Pin, INPUT);
  pinMode(led_y, OUTPUT);
  pinMode(fanPin1, OUTPUT);
  pinMode(fanPin2, OUTPUT);
  ledcSetup(5, 1200, 8);      //Set the frequency of LEDC channel 1 to 1200 and PWM resolution to 8, that is duty cycle to 256.
  ledcAttachPin(fanPin2, 5);  //Bind the LEDC channel 1 to the specified left motor pin GPIO26 for output.
  pinMode(waterPin, INPUT);
  pinMode(buzzer_pin, OUTPUT);
  pinMode(gasPin, INPUT);
  pinMode(pyroelectric, INPUT);
  ledcSetup(channel_PWM, freq_PWM, resolution_PWM);  //Set servo channel and frequency as well as PWM resolution.
  ledcSetup(channel_PWM2, freq_PWM, resolution_PWM);
  ledcAttachPin(PWM_Pin1, channel_PWM);   //Binds the LEDC channel to the specified IO port for output
  ledcAttachPin(PWM_Pin2, channel_PWM2);  //Binds the LEDC channel to the specified IO port for output
  Wire.begin();
  mfrc522.PCD_Init();
  ShowReaderDetails();
  Serial.println(F("Scan PICC to see UID, type, and data blocks..."));
  myservo1.attach(servoPin1,500,2400);  // Attach servo at setup
  myservo1.write(0);
   myservo2.attach(servoPin2,500,2400);  // Attach servo at setup
  myservo2.write(0);
  mylcd.setCursor(0, 0);
  //mylcd.print("Card");
  // Wservo.attach(windowServo);
  // Dservo.attach(doorServo);
  // #if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
  // clock_prescale_set(clock_div_1);
  // #endif
  // // END of Trinket-specific code.
  // strip.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
  // strip.show(); // Turn OFF all pixels ASAP
  // strip.setBrightness(50); // Set BRIGHTNESS to about 1/5 (max = 255)
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  server.begin();
  Serial.println("TCP server started");
  MDNS.addService("http", "tcp", 80);
  mylcd.print("ip:");
  mylcd.setCursor(0, 1);
  mylcd.print(WiFi.localIP());  //LCD displays ip adress
  delay(2000);
  mylcd.print("SmartHouse");
  mylcd.print("Richard Gero");  //LCD displays ip adress
  delay(2000);
  mylcd.clear();
  mylcd.print(menuItems[currentMenuIndex]);
  mylcd.print(menuItems[currentMenuIndex + 1]);
  WiFiClient client = server.available();
  if (!client) {
    return;
  while (client.connected() && !client.available()) {
    delay(1);
  String req = client.readStringUntil('\r');
  int addr_start = req.indexOf(' ');
  int addr_end = req.indexOf(' ', addr_start + 1);
  if (addr_start == -1 || addr_end == -1) {
    Serial.print("Invalid request: ");
    Serial.println(req);
    return;
  req = req.substring(addr_start + 1, addr_end);
  item = req;
  Serial.println(item);
  String s;
  if (req == "/")  //Browser accesses address can read the information sent by the client.println(s);
    IPAddress ip = WiFi.localIP();
    String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
    s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n< !DOCTYPE HTML >\r\n< html >ESP32 ip:";
    s += ipStr;
    s += "< /html >\r\n\r\n";
    Serial.println("Sending 200");
    client.println(s);  //Send the string S, then you can read the information when visiting the address of E smart home using the browser.
  //button
  if (digitalRead(button1Pin) == LOW) {
    Serial.println("Button1 Push");
    menuItems[currentMenuIndex] = menuItems[currentMenuIndex + 1];
    mylcd.clear();
  if (digitalRead(button2Pin) == LOW) {
    Serial.println("Button2 Push");
    mylcd.clear();
  //button end
  if ((req == "/led/on") || (menuItems[currentMenuIndex] == "LED ON"))  //Browser accesses address ip address/led/on
    client.println("turn on the LED");
    digitalWrite(led_y, HIGH);
  if (req == "/led/off")  //Browser accesses address ip address/led/off
    client.println("turn off the LED");
    digitalWrite(led_y, LOW);
  if ((req == "/window/on") || (menuItems[currentMenuIndex] == "WINDOW OPEN")) {
    mylcd.clear();
    mylcd.print("Okno - otvorené");
       myservo2.write(0);
    client.println("open the window");
    //ledcWrite(channel_PWM, 100);
    //The high level of 20ms is about 2.5ms, that is, 2.5/20*1024, at this time, the servo angle is 180°.
    //Wservo.write(175);
  if ((req == "/window/off") || (menuItems[currentMenuIndex] == "WINDOW CLOSED")) {
    mylcd.clear();
    mylcd.print("Okno - Zatvorené");
      myservo2.write(180);
    client.println("close the window");
    //ledcWrite(channel_PWM, 60);
    //The high level of 20ms is about 0.5ms,that is, 0.5/20*1024,at this time, the servo angle is 0°.
    //Wservo.write(0);
  if ((req == "/music/on") || (menuItems[currentMenuIndex] == "MUSIC ON")) {
    //client.println("play music");
  if ((req == "/music/off") || (menuItems[currentMenuIndex] == "MUSIC OFF")) {
    mylcd.clear();
    mylcd.print("Hudba - OFF");
    birthday();
    noTone(buzzer_pin, 0);
    mylcd.clear();
  if ((req == "/buz/on") || (menuItems[currentMenuIndex] == "BUZZER ON")) {
    client.println("buzzer");
    tone(buzzer_pin, 392, 250, 0);
    Serial.println("1");
  if ((req == "/buz/off") || (menuItems[currentMenuIndex] == "BUZZER OFF")) {
    mylcd.clear();
    mylcd.print("Reprak - OFF");
    client.println("off");
    mylcd.clear();
  if ((req == "/door/on") || (menuItems[currentMenuIndex] == "DOOR OPEN")) {
    mylcd.clear();
    mylcd.print("Dvere - otvorené");
    client.println("open the door");
    ledcWrite(channel_PWM2, 120);
    myservo1.write(180);
  if ((req == "/door/off") || (menuItems[currentMenuIndex] == "DOOR CLOSED")) {
    mylcd.clear();
    mylcd.print("Dvere - zatvorené");
    client.println("close the door");
    ledcWrite(channel_PWM2, 20);
     myservo1.write(0);
  if ((req == "/fan/on") || (menuItems[currentMenuIndex] == "FAN ON")) {
    mylcd.clear();
    mylcd.print("Ventilátor");
    mylcd.print("ON");
    client.println("turn on the fan");
    digitalWrite(fanPin1, LOW);  //pwm = 0
    ledcWrite(5, 100);
    // mylcd.clear();
    //The LEDC channel 1 is bound to the specified left motor output PWM value of 100.
  if ((req == "/fan/off") || (menuItems[currentMenuIndex] == "FAN OFF")) {
    mylcd.clear();
    mylcd.print("OFF");
    client.println("turn off the fan");
    ledcWrite(5, 0);
    //   mylcd.clear();
    //The LEDC channel 1 is bound to the specified left motor output PWM value of 0.
  if (req == "/red/on") {
    client.println("red on");
    colorWipe(strip.Color(255, 0, 0), 50);
  if (req == "/red/off") {
    client.println("red off");
    colorWipe(strip.Color(0, 0, 0), 50);
  if (req == "/oringe/on") {
    client.println("oringe on");
    colorWipe(strip.Color(200, 100, 0), 50);
  if (req == "/oringe/off") {
    client.println("oringe off");
  if (req == "/yellow/on") {
    client.println("yellow on");
    colorWipe(strip.Color(200, 200, 0), 50);
  if (req == "/yellow/off") {
    client.println("yellow off");
  if (req == "/green/on") {
    client.println("green on");
    colorWipe(strip.Color(0, 255, 0), 50);
  if (req == "/green/off") {
    client.println("green off");
  if (req == "/cyan/on") {
    client.println("cyan on");
    colorWipe(strip.Color(0, 100, 255), 50);
  if (req == "/cyan/off") {
    client.println("cyan off");
  if (req == "/blue/on") {
    client.println("blue on");
    colorWipe(strip.Color(0, 0, 255), 50);
  if (req == "/blue/off") {
    client.println("blue off");
  if (req == "/purple/on") {
    client.println("purple on");
    colorWipe(strip.Color(100, 0, 255), 50);
  if (req == "/purple/off") {
    client.println("purple off");
  if (req == "/white/on") {
    client.println("white on");
    colorWipe(strip.Color(255, 255, 255), 50);
  if (req == "/white/off") {
    client.println("white off");
  if (req == "/sfx1/on") {
    client.println("sfx1 on");
    rainbow(10);
  if (req == "/sfx1/off") {
    client.println("sfx1 off");
  if (req == "/sfx2/on") {
    client.println("sfx2 on");
    theaterChaseRainbow(50);
  if (req == "/sfx2/off") {
    client.println("sfx2 off");
  if ((req == "/rain/on") || (menuItems[currentMenuIndex] == "RAIN ON")) {
    mylcd.clear();
    int rainVal = analogRead(waterPin);
    mylcd.print(rainVal);
    client.println(rainVal);
  if ((req == "/rain/off") || (menuItems[currentMenuIndex] == "RAIN OFF")) {
  while ((req == "/gas/on") || (menuItems[currentMenuIndex] == "GAS ON")) {
    mylcd.clear();
    gasVal = analogRead(gasPin);
    if (gasVal <= 300) {
      Serial.print ("GasVal: ");
      Serial.println (gasVal,DEC);
      client.print(" safety");
      mylcd.print(" Bezpečie");
    if (gasVal > 300 && gasVal <= 1000 ){
      client.print("  Warning");
      mylcd.print("  Pozor");
 beep(1000, 200);// Keep it ON for 100ms
      /*tone(buzzer_pin, 294, 250, 0);
      delay(1);
      delay(1);*/
    if (gasVal > 1000 ) {
      client.print("  Dangerous");
      mylcd.print("  Nebezpecné");
      beep(1000, 200);  // Keep it ON for 100ms
      delay(1);
      delay(1);*/
    mylcd.print(gasVal,DEC);
    delay(300);
  if ((req == "/gas/off") || (menuItems[currentMenuIndex] == "GAS OFF")) {
    mylcd.clear();
    mylcd.clear();
  if ((req == "/body/on") || (menuItems[currentMenuIndex] == "BODY ON")) {
    mylcd.clear();
    mylcd.print("PIR Stav");
    boolean pyroelectric_val = digitalRead(pyroelectric);
    if (pyroelectric_val == 1) {
      mylcd.print("Pohyb detekovaný");
      client.println("someone");
      mylcd.print("Žiaden pohyb");
      client.println("no one");
    //mylcd.setCursor(0, 1);
    //mylcd.print(pyroelectric_val);
    delay(300);
  if ((req == "/body/off") || (menuItems[currentMenuIndex] == "BODY OFF")) {
  if ((req == "/temp/on") || (menuItems[currentMenuIndex] == "TEMP ON")) {
    if (xht.receive(dht)) {
      mylcd.clear();  //Returns true when checked correctly
      mylcd.print("Teplota:");
      mylcd.print(dht[2]);  //The integral part of temperature, DHT [3] is the fractional part
      mylcd.print("C");
      Serial.print("Temp:");
      Serial.print(dht[2]);  //The integral part of temperature, DHT [3] is the fractional part
      Serial.println("C");
      delay(200);
    } else {  //Read error
      Serial.println("sensor error");
    client.println(dht[2]);
    delay(1000);  //It takes 1000ms to wait for the device to read
  if ((req == "/temp/off") || (menuItems[currentMenuIndex] == "TEMP OFF")) {
  if ((req == "/humidity/on") || (menuItems[currentMenuIndex] == "HUMIDITY ON")) {
    mylcd.clear();
    mylcd.print("Vlhkost");
    if (xht.receive(dht)) {  //Returns true when checked correctly
      Serial.print("Humidity:");
      Serial.print(dht[0]);  //The integral part of temperature, DHT [3] is the fractional part
      mylcd.print(dht[0]);
      mylcd.setCursor(5, 1);
      mylcd.print("%");
      Serial.println("%");
      delay(200);
    client.println(dht[0]);
  if ((req == "/humidity/off") || (menuItems[currentMenuIndex] == "HUMIDITY OFF")) {
  // Kontrola tlačidla 1 pre posun v menu
  if (newButton1State && !button1State) {
    currentMenuIndex = (currentMenuIndex + 1) % menuSize;  // Posun v menu
    mylcd.clear();
    mylcd.print(menuItems[currentMenuIndex]);  // Zobrazenie aktuálnej položky
    mylcd.print(menuItems[(currentMenuIndex + 1) % menuSize]);  // Ďalšia položka
    delay(200);                                                 // Odrušenie preťaženia
  // Kontrola tlačidla 2 pre výber aktuálnej položky
  /*if (newButton2State && !button2State) {
    mylcd.clear();
    mylcd.print("Selected:");
    mylcd.print(menuItems[currentMenuIndex]);  // Zobrazenie zvolenej položky
    handleMenuSelection();                     // Funkcia na spracovanie výberu
  // Aktualizácia predchádzajúcich stavov tlačidiel
  /*newButton1State = digitalRead(button1Pin) == LOW;  // Tlačidlo stlačené (LOW)
  newButton2State = digitalRead(button2Pin) == LOW;
  button1State = newButton1State;
  button2State = newButton2State;*/
  //client.stop();
  if (!mfrc522.PICC_IsNewCardPresent() || !mfrc522.PICC_ReadCardSerial()) {
    delay(50);
    Password = "";
    //Serial.println ("Reading the card");
    return;
  Serial.print(F("Card UID:"));
  Password = "";
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    //Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
    Serial.print(mfrc522.uid.uidByte[i]);
    Password += String(mfrc522.uid.uidByte[i]);
  Serial.println();  // New line after UID print
  //if (Password == "42 141 63 181") {
  if (Password == "4214163181" && DoorState == 0) {
    Serial.println("Access granted: Opening door");
    mylcd.clear();
    mylcd.print("Otvorené");
    DoorState = 1;
    myservo1.attach(servoPin1,500,2400);  // Ensure servo is attached
    delay(2000);  // Wait before closing
    myservo1.write(0);
    myservo1.detach();  // Detach to prevent jitter
  } else if (Password == "4214163181" && DoorState == 1) {
    Serial.println("Access granted: Closing door");
    mylcd.clear();
    mylcd.print("Zatvorené");
    DoorState = 0;
    myservo1.write(0);
    myservo1.write(0);
    Serial.println("Access denied");
    mylcd.clear();
    mylcd.print("error");
    delay(2000);
  Password = "";
void birthday() {
  tone(buzzer_pin, 294, 250, 0);  //The four parameters are pin, frequency, delay and channel
  tone(buzzer_pin, 440, 250, 0);
  tone(buzzer_pin, 532, 250, 0);
  tone(buzzer_pin, 494, 250, 0);
  tone(buzzer_pin, 587, 250, 0);
  tone(buzzer_pin, 784, 250, 0);
  tone(buzzer_pin, 659, 250, 0);
  tone(buzzer_pin, 698, 250, 0);
  tone(buzzer_pin, 532, 500, 0);
void colorWipe(uint32_t color, int wait) {
  for (int i = 0; i < strip.numPixels(); i++) {  // For each pixel in strip...
    strip.setPixelColor(i, color);               // Set pixel's color (in RAM)
    strip.show();                                // Update strip to match
    delay(wait);                                 // Pause for a moment
// Rainbow cycle along whole strip. Pass delay time (in ms) between frames.
void rainbow(int wait) {
  for (long firstPixelHue = 0; firstPixelHue < 5 * 65536; firstPixelHue += 256) {
      int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
      strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
    strip.show();  // Update strip with new contents
// Rainbow-enhanced theater marquee. Pass delay time (in ms) between frames.
void theaterChaseRainbow(int wait) {
  int firstPixelHue = 0;           // First pixel starts at red (hue 0)
  for (int a = 0; a < 30; a++) {   // Repeat 30 times...
    for (int b = 0; b < 3; b++) {  // 'b' counts from 0 to 2...
      strip.clear();               // Set all pixels in RAM to 0 (off)
      // 'c' counts up from 'b' to end of strip in increments of 3...
      for (int c = b; c < strip.numPixels(); c += 3) {
        int hue = firstPixelHue + c * 65536L / strip.numPixels();
        uint32_t color = strip.gamma32(strip.ColorHSV(hue));  // hue - > RGB
        strip.setPixelColor(c, color);                        // Set pixel 'c' to value 'color'
      firstPixelHue += 65536 / 90;  // One cycle of color wheel over 90 frames
void handleMenuSelection() {
  if (menuItems[currentMenuIndex] == "LED") {
    Serial.println("LED selected");
    // Pridaj kód na spracovanie výberu LED
  } else if (menuItems[currentMenuIndex] == "Temperature") {
    Serial.println("Temperature selected");
    // Pridaj kód na spracovanie teploty
  } else if (menuItems[currentMenuIndex] == "Window") {
    Serial.println("Window selected");
    // Pridaj kód na spracovanie okna
  } else if (menuItems[currentMenuIndex] == "Door") {
    Serial.println("Door selected");
    // Pridaj kód na spracovanie dverí
void ShowReaderDetails() {
  byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
  Serial.print(F("MFRC522 Software Version: 0x"));
  Serial.print(v, HEX);
  if (v == 0x91)
    Serial.print(F(" = v1.0"));
  else if (v == 0x92)
    Serial.print(F(" = v2.0"));
    Serial.print(F(" (unknown)"));
  Serial.println("");
  if ((v == 0x00) || (v == 0xFF)) {
    Serial.println(F("WARNING: Communication failure, check connections"));
void beep(int frequency, int duration) {
    ledcAttachPin(buzzer_pin, 1);
    ledcWriteTone(1, frequency);
    delay(duration);
    ledcWriteTone(1, 0);
ive also got a older version of my code where some things are missing: #include <WiFi.h>
#define LED_PIN 26
#define LED_COUNT 4
String item = "0";
#include <Wire.h>
#include "xht11.h"
xht11 xht(17);
//#include < ESP32_Servo.h >
//Servo Wservo;
//Servo Dservo;
#define waterPin 34
#define fanPin1 19
#define fanPin2 18
#define waterPin 34
#define gasPin 23
//Servo channel
int freq_PWM = 50;
  mylcd.init();
  mylcd.backlight();
  pinMode(button2Pin, INPUT_PULLUP);
  // #endif
    Serial.print(".");
  Serial.println("");
  server.begin();
  mylcd.print("ip:");
  delay(2000);
  mylcd.print("My SmartHouse");
  delay(2000);
  mylcd.clear();
  if (!client) {
    return;
    delay(1);
    return;
  item = req;
  String s;
    s += ipStr;
//button
  if (digitalRead(button1Pin) == HIGH) {
    mylcd.clear();
    mylcd.clear();
//button end
    mylcd.clear();
    mylcd.print("WINDOW OPEN");
    mylcd.clear();
    mylcd.print("WINDOW CLOSED");
    //Wservo.write(0);
    mylcd.clear();
    mylcd.print("birthday");
    birthday();
    mylcd.clear();
    mylcd.clear();
    mylcd.clear();
    mylcd.clear();
    mylcd.print("DOOR OPEN");
    // Dservo.write(180);
    mylcd.clear();
    mylcd.print("DOOR CLOSED");
    // Dservo.write(0);
    mylcd.clear();
    mylcd.print("FAN STATE");
    mylcd.print("ON");
    ledcWrite(5, 100);
    // mylcd.clear();
    mylcd.clear();
    mylcd.print("OFF");
    ledcWrite(5, 0);
    //   mylcd.clear();
    rainbow(10);
    mylcd.clear();
  if ((req == "/gas/on") || (menuItems[currentMenuIndex] == "GAS ON")) {
    mylcd.clear();
    boolean gasVal = analogRead(gasPin);
    if (gasVal == 0) {
      client.println("safety");
      mylcd.print("safety");
      client.println("dangerous");
      mylcd.print("dangerous");
    mylcd.print(gasVal);
    mylcd.clear();
    mylcd.print("PIR STATE");
      mylcd.print("SOMEONE");
      mylcd.print("NO ONE");
      mylcd.print("Temp:");
      mylcd.print("C");
      delay(200);
    mylcd.clear();
      mylcd.print("%");
      delay(200);
    mylcd.clear();
    mylcd.clear();
  //client.stop();
void birthday() {
}`Use code tags to format code for the forum`
Please format the code like this:
#include <WiFi.h>
Edit your post, mark all the code and click on <code>
One more thing, never include credentials like phone numbers, passwords etc.
You can edit posts as well, no need to create new ones.
Now I'll stop nag :upside_down_face:
srry im new here, this is my first post soo
But not the last I hope. Welcome btw!
I take it you share a hotspot from your iPhone? Can other devices connect fine?
no ive also tried through a router but nothing happened, previously it was working
what should i change
pls help :smiling_face_with_tear:
Can I make a suggestion?
  1. Delete the content in #5
  2. Edit #1, select all the code and click button <code>
  3. Edit #2, same as #1
There's an ocean of text in this thread, and I easily get seasick.
done
u here?
this is the new one
#include <WiFi.h>
Servo myservo1;
Servo myservo2;
#define LED_PIN 26
#define LED_COUNT 4
String item = "0";
const char* password = "C2o2lk9VUP";
#include <Wire.h>
#include "xht11.h"
xht11 xht(17);
#define waterPin 34
#define fanPin1 19
#define fanPin2 18
#define waterPin 34
#define gasPin 32
//Servo channel
int freq_PWM = 50;
int DoorState = 0;
int gasVal;
  Serial.println("Run Baby");
  mylcd.init();
  mylcd.backlight();
  Wire.begin();
  mfrc522.PCD_Init();
  myservo1.attach(servoPin1, 500, 2400);  // Attach servo at setup
  myservo1.write(0);
  myservo2.attach(servoPin2, 500, 2400);  // Attach servo at setup
  myservo2.write(0);
  // #endif
    Serial.print(".");
  Serial.println("");
  server.begin();
  mylcd.print("ip:");
  delay(2000);
  delay(2000);
  mylcd.clear();
  if (!client) {
    return;
    delay(1);
    return;
  item = req;
  String s;
    s += ipStr;
  //button
    mylcd.clear();
    mylcd.clear();
  //button end
    mylcd.clear();
    myservo2.write(0);
    mylcd.clear();
    //Wservo.write(0);
    mylcd.clear();
    birthday();
    mylcd.clear();
    mylcd.clear();
    mylcd.clear();
    mylcd.clear();
    mylcd.clear();
    myservo1.write(0);
    mylcd.clear();
    mylcd.print("ON");
    ledcWrite(5, 100);
    // mylcd.clear();
    mylcd.clear();
    mylcd.print("OFF");
    ledcWrite(5, 0);
    //   mylcd.clear();
    rainbow(10);
    mylcd.clear();
    mylcd.clear();
      Serial.print("GasVal: ");
      Serial.println(gasVal, DEC);
    if (gasVal > 300 && gasVal <= 1000) {
      delay(1);
      delay(1);*/
    if (gasVal > 1000) {
      delay(1);
      delay(1);*/
    mylcd.print(gasVal, DEC);
    delay(300);
    mylcd.clear();
    mylcd.clear();
    mylcd.clear();
      mylcd.print("C");
      delay(200);
    mylcd.clear();
      mylcd.print("%");
      delay(200);
    mylcd.clear();
    mylcd.clear();
  //client.stop();
    delay(50);
    Password = "";
    return;
  Password = "";
    mylcd.clear();
    DoorState = 1;
    myservo1.attach(servoPin1, 500, 2400);  // Ensure servo is attached
    myservo1.write(0);
    mylcd.clear();
    DoorState = 0;
    myservo1.write(0);
    myservo1.write(0);
    mylcd.clear();
    delay(2000);
  Password = "";
void birthday() {
  if (v == 0x91)
  else if (v == 0x92)
  Serial.println("");
  delay(duration);
and this is the older one
#include <WiFi.h>
#define LED_PIN 26
#define LED_COUNT 4
String item = "0";
#include <Wire.h>
#include "xht11.h"
xht11 xht(17);
//Servo Wservo;
//Servo Dservo;
#define waterPin 34
#define fanPin1 19
#define fanPin2 18
#define waterPin 34
#define gasPin 23
//Servo channel
int freq_PWM = 50;
  mylcd.init();
  mylcd.backlight();
  // #endif
    Serial.print(".");
  Serial.println("");
  server.begin();
  mylcd.print("ip:");
  delay(2000);
  delay(2000);
  mylcd.clear();
  if (!client) {
    return;
    delay(1);
    return;
  item = req;
  String s;
    s += ipStr;
  //button
    mylcd.clear();
    mylcd.clear();
  //button end
    mylcd.clear();
    mylcd.clear();
    //Wservo.write(0);
    mylcd.clear();
    birthday();
    mylcd.clear();
    mylcd.clear();
    mylcd.clear();
    mylcd.clear();
    mylcd.clear();
    // Dservo.write(0);
    mylcd.clear();
    mylcd.print("ON");
    ledcWrite(5, 100);
    // mylcd.clear();
    mylcd.clear();
    mylcd.print("OFF");
    ledcWrite(5, 0);
    //   mylcd.clear();
    rainbow(10);
    mylcd.clear();
    mylcd.clear();
    if (gasVal == 0) {
    mylcd.clear();
      mylcd.print("C");
      delay(200);
    mylcd.clear();
      mylcd.print("%");
      delay(200);
    mylcd.clear();
    mylcd.clear();
  //client.stop();
void birthday() {
ive changed some things since the older version, added new sensors etc
Don't start a new thread for you old problem.
I've flagged your post, maybe it will be tacked on to your real thread.
a7
I have merged your cross-posts @richard-1
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
can u help me pls
Since things never stop work for no reason, something has changed. The board or libraries got updated in the IDE, you perhaps changed something in the IDE or sketch yourself. The other thing is that the boards WiFi broke. What board do you have?
