Here is the code, I used and what should I do next?
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <DHT.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
char auth[] = "kREKxA4WD3Km9CNeduvehx0N2dXh5tR9"; //Enter the Auth code which was send by Blink
char ssid[] = "Rivanth"; //Enter your WIFI Name
char pass[] = "12345678"; //Enter your WIFI Password
DHT dht(D3, DHT11); //(sensor pin,sensor type)
BlynkTimer timer;
void weather() {
float h = dht.readHumidity();
float t = dht.readTemperature();
int r = analogRead(A0);
bool l = digitalRead(D4);
r = map(r, 0, 1023, 100, 0);
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
Blynk.virtualWrite(V0, t); //V0 is for Temperature
Blynk.virtualWrite(V1, h); //V1 is for Humidity
Blynk.virtualWrite(V2, r); //V2 is for Rainfall
if (l == 0) {
WidgetLED led1(V3);
led1.on();
lcd.setCursor(9, 1);
lcd.print("L :");
lcd.print("High");
lcd.print(" ");
} else if (l == 1) {
WidgetLED led1(V3);
led1.off();
lcd.print("L :");
lcd.print("Low");
lcd.print(" ");
lcd.setCursor(0, 0);
lcd.print("T :");
lcd.print(t);
lcd.setCursor(0, 1);
lcd.print("H :");
lcd.print(h);
lcd.setCursor(9, 0);
lcd.print("R :");
lcd.print(r);
lcd.print(" ");
Serial.begin(9600); // See the connection status in Serial Monitor
lcd.init();
lcd.backlight();
Blynk.begin(auth, ssid, pass);
dht.begin();
// Setup a function to be called every second
timer.setInterval(10L, weather);
Blynk.run(); // Initiates Blynk
timer.run(); // Initiates SimpleTimer
