i have this code insert on my wemos d1 r2 and i took restart message
ESP8266 library
When you use with UNO board, uncomment the follow line in uartWIFI.h.
#define UNO
When you use with MEGA board, uncomment the follow line in uartWIFI.h.
#define MEGA
Connection:
When you use it with UNO board, the connection should be like these:
ESP8266_TX->(your softserial receive pin)
ESP8266_RX->1K resistor->(your softserial transmit pin)
ESP8266_CH_PD->3.3V
ESP8266_VCC->3.3V
ESP8266_GND->GND
When you use it with MEGA board, the connection should be like these:
ESP8266_TX->RX1(D19)
ESP8266_RX->TX1(D18)
ESP8266_CH_PD->3.3V
ESP8266_VCC->3.3V
ESP8266_GND->GND
When you want to output the debug information, please use DebugSerial. For example,
DebugSerial.println("hello");
Note: The size of message from ESP8266 is too big for arduino sometimes, so the library can't receive the whole buffer because
the size of the hardware serial buffer which is defined in HardwareSerial.h is too small.
Open the file from \arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.h.
See the follow line in the HardwareSerial.h file.
#define SERIAL_BUFFER_SIZE 64
The default size of the buffer is 64. Change it into a bigger number, like 256 or more.
#define SSID "test"
#define PASSWORD "1234567890"
#include "uartWIFIUNO.h"
#include <SoftwareSerial.h>
WIFIUNO wifi;
extern int chlID; //client id(0-4)
int sprinkler = 5;
int LED2 = 6;
extern int chlID;
pinMode(sprinkler,OUTPUT);
digitalWrite(sprinkler,HIGH); //pullup to turn off.
pinMode(LED2,OUTPUT);
digitalWrite(LED2,LOW);
wifi.begin();
bool b = wifi.Initialize(STA, SSID, PASSWORD);
if(!b)
DebugSerial.println("Init error");
delay(8000); //make sure the module can have enough time to get an IP address
String ipstring = wifi.showIP();
DebugSerial.println(ipstring); //show the ip address of module
delay(2000);
wifi.confMux(1);
delay(100);
if(wifi.confServer(1,8080))
DebugSerial.println("Server is set up");
char buf[100];
int iLen = wifi.ReceiveMessage(buf);
if(iLen > 0)
DebugSerial.println(buf);
if (strstr(buf, "HELLO") != NULL)
digitalWrite(sprinkler,LOW);
DebugSerial.println("GOT HELLO");
if(wifi.Send(chlID,"HELLO from Arduino!\r\n"))
DebugSerial.println("Message sent okay.");
if (strstr(buf, "CH0ON") != NULL)
DebugSerial.println("CH0ON");
wifi.Send(chlID,"Sprinkler ON\r\n");
if (strstr(buf, "CH0OFF") != NULL)
DebugSerial.println("CH0OFF");
wifi.Send(chlID,"Sprinkler OFF\r\n");
if (strstr(buf, "CH1ON") != NULL)
digitalWrite(LED2,HIGH);
DebugSerial.println("CH1ON");
if (strstr(buf, "CH1OFF") != NULL)
DebugSerial.println("CH1OFF");
the message which I took is this
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v09f0c112
~ld
is anyone who understands why?
