HM-10 Bluetooth AT -ERROR
Hi Guys!
I'm trying to make a connection with my HM-10 Bluetooth in a way to send it signals. The connection can be built, it's available on different scans. But when I'm trying to run the following sketch
//  SerialIn_SerialOut_HM-10_01
//  Uses hardware serial to talk to the host computer and AltSoftSerial for communication with the bluetooth module
//  What ever is entered in the serial monitor is sent to the connected device
//  Anything received from the connected device is copied to the serial monitor
//  Does not send line endings to the HM-10
//  Pins
//  BT VCC to Arduino 5V out.
//  BT GND to GND
//  Arduino D8 (SS RX) - BT TX no need voltage divider
//  Arduino D9 (SS TX) - BT RX through a voltage divider (5v to 3.3v)
#include <AltSoftSerial.h>
AltSoftSerial BTserial;
// https://www.pjrc.com/teensy/td_libs_AltSoftSerial.html
char c=' ';
boolean NL = true;
    Serial.print("Sketch:   ");   Serial.println(__FILE__);
    Serial.print("Uploaded: ");   Serial.println(__DATE__);
    Serial.println(" ");
    BTserial.begin(9600);
    Serial.println("BTserial started at 9600");
    // Read from the Bluetooth module and send to the Arduino Serial Monitor
    if (BTserial.available())
        c = BTserial.read();
        Serial.write(c);
    // Read from the Serial Monitor and send to the Bluetooth module
    if (Serial.available())
        c = Serial.read();
        // do not send line end characters to the HM-10
        if (c!=10 & c!=13 )
             BTserial.write(c);
        // Echo the user input to the main window.
        // If there is a new line print the ">" character.
        if (NL) { Serial.print("\r\n>");  NL = false; }
        Serial.write(c);
        if (c==10) { NL = true; }
and write AT in the monitor, I got
Sketch: /Users/imac5k/Documents/Arduino/BLE/BLE.ino
Uploaded: Feb 11 2022
>AT
ERROR
and I do not what is wrong.
VCC is 5V
RXD is pin 9
TXD is pin 8
(I use Arduino UNO)
As far as I understand is that my HM-10 is not fake (but not sure).
And when I get connection to it and try something send to it (the HM10.available() is always zero)...
