Hoping for some ideas
Attempting to make the Elegoo Smart Car 4.0 parametrically navigate, but I don't quite know how to go about it, so I was hoping for some ideas
what is it?
It's a little RC car that uses Arduino code, but I can't quite figure it out
which one?
Arduino Uno
cool. I have very many codes for UNO, do you want some?
Is it all built and tested with supplied code??
I built one last week, was a FreeNove 4WD based on ESP32..
Really just wanted some to test with..
I tied it into my nard server and controlled it using a tablet, was quite surprised that it actually worked quite well..
Need to add a separate cam to the bot though as pulling a live stream and trying to drive at the same time has issues..
NardBot
fun though, want to build to another, see how many i can control at once.. :slight_smile:
If you stuck on something, post up some code using codeblocks.
have fun.. ~q
Yeah, the code that was supplied was good, it works well, I just need to figure out how to make it navigate to a point on it's own
I think this would be the code that makes it move
 if (controlED == control_enable) //Enable motot control?
    digitalWrite(PIN_Motor_STBY, HIGH);
    { //A...Right
      switch (direction_A) //movement direction control
      case direction_just:
        digitalWrite(PIN_Motor_AIN_1, HIGH);
        analogWrite(PIN_Motor_PWMA, speed_A);
      case direction_back:
        digitalWrite(PIN_Motor_AIN_1, LOW);
      case direction_void:
        analogWrite(PIN_Motor_PWMA, 0);
        digitalWrite(PIN_Motor_STBY, LOW);
      default:
    { //B...Left
      switch (direction_B)
        digitalWrite(PIN_Motor_BIN_1, HIGH);
        analogWrite(PIN_Motor_PWMB, speed_B);
        digitalWrite(PIN_Motor_BIN_1, LOW);
        analogWrite(PIN_Motor_PWMB, 0);
      default:
    return;
Looks like it, put the whole sketch up..
looks like direction_void is stop and default is stop..
strange case names direction_just, means just what?? :slight_smile:
mine was easier to understand..
 case CMD_MOTOR:{ //Serial.println("SetParams: Motor");
               Car_SetMode(0);
               if (p1 == 0 && p3 == 0)
                Motor_Move(0, 0, 0, 0);//Stop the car
                 else //If the parameters are not equal to 0
                  Motor_Move(p1, p1, p3, p3);
                  result = true;
just Motor_Move 4 params is the speed and direction..
how many motors does your bot have??
i got 4, hence the 4 params..
~q
Mine has 4 as well, and I don't quite know what some of the names mean, it's just what came with the default. Which line did you find that code under?
Line 142 in NardBot.ino
Like I said mine was a bit easier to understand..
Put the whole sketch up and I'll take a look at it..
~q
Here's the whole sketch, found under device driver set
#include "DeviceDriverSet_xxx0.h"
//#include "PinChangeInt.h"
#include <avr/wdt.h>
static void
delay_xxx(uint16_t _ms)
  wdt_reset();
  for (unsigned long i = 0; i < _ms; i++)
    delay(1);
/*RBG LED*/
static uint32_t Color(uint8_t r, uint8_t g, uint8_t b)
  return (((uint32_t)r << 16) | ((uint32_t)g << 8) | b);
void DeviceDriverSet_RBGLED::DeviceDriverSet_RBGLED_xxx(uint16_t Duration, uint8_t Traversal_Number, CRGB colour)
  if (NUM_LEDS < Traversal_Number)
    Traversal_Number = NUM_LEDS;
  for (int Number = 0; Number < Traversal_Number; Number++)
    leds[Number] = colour;
    FastLED.show();
    delay_xxx(Duration);
void DeviceDriverSet_RBGLED::DeviceDriverSet_RBGLED_Init(uint8_t set_Brightness)
  FastLED.addLeds<NEOPIXEL, PIN_RBGLED>(leds, NUM_LEDS);
  FastLED.setBrightness(set_Brightness);
#if _Test_DeviceDriverSet
void DeviceDriverSet_RBGLED::DeviceDriverSet_RBGLED_Test(void)
  leds[0] = CRGB::White;
  FastLED.show();
  delay_xxx(50);
  leds[1] = CRGB::Red;
  FastLED.show();
  delay_xxx(50);
  DeviceDriverSet_RBGLED_xxx(50 /*Duration*/, 5 /*Traversal_Number*/, CRGB::Black);
#endif
void DeviceDriverSet_RBGLED::DeviceDriverSet_RBGLED_Color(uint8_t LED_s, uint8_t r, uint8_t g, uint8_t b)
  if (LED_s > NUM_LEDS)
    return;
  if (LED_s == NUM_LEDS)
    FastLED.showColor(Color(r, g, b));
    leds[LED_s] = Color(r, g, b);
  FastLED.show();
/*Key*/
uint8_t DeviceDriverSet_Key::keyValue = 0;
static void attachPinChangeInterrupt_GetKeyValue(void)
  DeviceDriverSet_Key Key;
  static uint32_t keyValue_time = 0;
  static uint8_t keyValue_temp = 0;
  if ((millis() - keyValue_time) > 500)
    keyValue_temp++;
    keyValue_time = millis();
    if (keyValue_temp > keyValue_Max)
      keyValue_temp = 0;
    Key.keyValue = keyValue_temp;
void DeviceDriverSet_Key::DeviceDriverSet_Key_Init(void)
  pinMode(PIN_Key, INPUT_PULLUP);
  //attachPinChangeInterrupt(PIN_Key, attachPinChangeInterrupt_GetKeyValue, FALLING);
  attachInterrupt(0, attachPinChangeInterrupt_GetKeyValue, FALLING);
void DeviceDriverSet_Key::DeviceDriverSet_Key_Test(void)
  Serial.println(DeviceDriverSet_Key::keyValue);
#endif
void DeviceDriverSet_Key::DeviceDriverSet_key_Get(uint8_t *get_keyValue)
  *get_keyValue = keyValue;
/*ITR20001 Detection*/
bool DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_Init(void)
  pinMode(PIN_ITR20001xxxL, INPUT);
  pinMode(PIN_ITR20001xxxM, INPUT);
  pinMode(PIN_ITR20001xxxR, INPUT);
  return false;
int DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_getAnaloguexxx_L(void)
  return analogRead(PIN_ITR20001xxxL);
int DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_getAnaloguexxx_M(void)
  return analogRead(PIN_ITR20001xxxM);
int DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_getAnaloguexxx_R(void)
  return analogRead(PIN_ITR20001xxxR);
void DeviceDriverSet_ITR20001::DeviceDriverSet_ITR20001_Test(void)
  Serial.print("\tL=");
  Serial.print(analogRead(PIN_ITR20001xxxL));
  Serial.print("\tM=");
  Serial.print(analogRead(PIN_ITR20001xxxM));
  Serial.print("\tR=");
  Serial.println(analogRead(PIN_ITR20001xxxR));
#endif
/*Voltage Detection*/
void DeviceDriverSet_Voltage::DeviceDriverSet_Voltage_Init(void)
  pinMode(PIN_Voltage, INPUT);
  //analogReference(INTERNAL);
float DeviceDriverSet_Voltage::DeviceDriverSet_Voltage_getAnalogue(void)
  //float Voltage = ((analogRead(PIN_Voltage) * 5.00 / 1024) * 7.67); //7.66666=((10 + 1.50) / 1.50)
  float Voltage = (analogRead(PIN_Voltage) * 0.0375);
  Voltage = Voltage + (Voltage * 0.08); //Compensation 8%
  //return (analogRead(PIN_Voltage) * 5.00 / 1024) * ((10 + 1.50) / 1.50); //Read voltage value
  return Voltage;
void DeviceDriverSet_Voltage::DeviceDriverSet_Voltage_Test(void)
  float Voltage = (analogRead(PIN_Voltage) * 0.0375); //7.66666=((10 + 1.50) / 1.50)
  //Serial.println(analogRead(PIN_Voltage) * 4.97 / 1024);
  Serial.println(Voltage);
#endif
/*Motor control*/
void DeviceDriverSet_Motor::DeviceDriverSet_Motor_Init(void)
  pinMode(PIN_Motor_PWMA, OUTPUT);
  pinMode(PIN_Motor_PWMB, OUTPUT);
  pinMode(PIN_Motor_AIN_1, OUTPUT);
  pinMode(PIN_Motor_BIN_1, OUTPUT);
  pinMode(PIN_Motor_STBY, OUTPUT);
void DeviceDriverSet_Motor::DeviceDriverSet_Motor_Test(void)
  //A...Right
  //B...Left
  analogWrite(PIN_Motor_PWMA, 100);
  analogWrite(PIN_Motor_PWMB, 100);
  delay_xxx(1000);
  delay_xxx(1000);
  delay_xxx(1000);
#endif
 Motor_control:AB / movement direction and speed
void DeviceDriverSet_Motor::DeviceDriverSet_Motor_control(boolean direction_A, uint8_t speed_A, //Group A motor parameters
                                                          boolean direction_B, uint8_t speed_B, //Group B motor parameters
                                                          boolean controlED                     //AB enable setting (true)
                                                          )                                     //Motor control
    { //A...Right
      default:
    { //B...Left
      default:
    return;
/*ULTRASONIC*/
//#include <NewPing.h>
// NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
void DeviceDriverSet_ULTRASONIC::DeviceDriverSet_ULTRASONIC_Init(void)
  pinMode(ECHO_PIN, INPUT); //Ultrasonic module initialization
  pinMode(TRIG_PIN, OUTPUT);
void DeviceDriverSet_ULTRASONIC::DeviceDriverSet_ULTRASONIC_Get(uint16_t *ULTRASONIC_Get /*out*/)
  unsigned int tempda_x = 0;
  digitalWrite(TRIG_PIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIG_PIN, HIGH);
  delayMicroseconds(10);
  tempda_x = ((unsigned int)pulseIn(ECHO_PIN, HIGH) / 58);
  // *ULTRASONIC_Get = tempda_x;
  if (tempda_x > 150)
    *ULTRASONIC_Get = 150;
  // sonar.ping() / US_ROUNDTRIP_CM; // Send ping, get ping time in microseconds (uS).
void DeviceDriverSet_ULTRASONIC::DeviceDriverSet_ULTRASONIC_Test(void)
  unsigned int tempda = 0;
  tempda = ((unsigned int)pulseIn(ECHO_PIN, HIGH) / 58);
  // if (tempda_x > 50)
  //   tempda_x = 50;
  // // return tempda;
  // return tempda_x;
  Serial.print("ULTRASONIC=");
  Serial.print(tempda); // Convert ping time to distance and print result (0 = outside set distance range, no ping echo)
  Serial.println("cm");
#endif
/*Servo*/
Servo myservo; // create servo object to control a servo
void DeviceDriverSet_Servo::DeviceDriverSet_Servo_Init(unsigned int Position_angle)
  myservo.attach(PIN_Servo_z, 500, 2400); //500: 0 degree  2400: 180 degree
  myservo.attach(PIN_Servo_z);
  myservo.write(Position_angle); //sets the servo position according to the 90(middle)
  delay_xxx(500);
  myservo.attach(PIN_Servo_y, 500, 2400); //500: 0 degree  2400: 180 degree
  myservo.attach(PIN_Servo_y);
  delay_xxx(500);
  myservo.detach();
void DeviceDriverSet_Servo::DeviceDriverSet_Servo_Test(void)
  for (;;)
    myservo.write(180);
    delay_xxx(500);
    myservo.write(0);
    delay_xxx(500);
  // for (uint8_t i = 0; i < 6; i++)
  //   myservo.write(30 * i);
  //   delay(500);
  // for (uint8_t i = 6; i > 0; i--)
  //   delay(500);
  // myservo.attach(PIN_Servo_y);
  //   delay(500);
  //   delay(500);
#endif
/*0.17sec/60degree(4.8v)*/
void DeviceDriverSet_Servo::DeviceDriverSet_Servo_control(unsigned int Position_angle)
  delay_xxx(450);
  myservo.detach();
//Servo motor control:Servo motor number and position angle
void DeviceDriverSet_Servo::DeviceDriverSet_Servo_controls(uint8_t Servo, unsigned int Position_angle)
  if (Servo == 1 || Servo == 3) //Servo_z
    if (Position_angle <= 1) //minimum angle control
      Position_angle = 1;
    if (Position_angle >= 17) //maximum angle control
      Position_angle = 17;
    myservo.write(10 * Position_angle);
    delay_xxx(500);
  if (Servo == 2 || Servo == 3) //Servo_y
    if (Position_angle <= 3) //minimum angle control
      Position_angle = 3;
    if (Position_angle >= 11) //maximum angle control
      Position_angle = 11;
    delay_xxx(500);
  myservo.detach();
/*IRrecv*/
IRrecv irrecv(RECV_PIN); //  Create an infrared receive drive object
decode_results results;  //  Create decoding object
void DeviceDriverSet_IRrecv::DeviceDriverSet_IRrecv_Init(void)
  irrecv.enableIRIn(); //Enable infrared communication NEC
bool DeviceDriverSet_IRrecv::DeviceDriverSet_IRrecv_Get(uint8_t *IRrecv_Get /*out*/)
  if (irrecv.decode(&results))
    IR_PreMillis = millis();
    switch (results.value)
    case /* constant-expression */ aRECV_upper:
    case /* constant-expression */ bRECV_upper:
      /* code */ *IRrecv_Get = 1;
    case /* constant-expression */ aRECV_lower:
    case /* constant-expression */ bRECV_lower:
      /* code */ *IRrecv_Get = 2;
    case /* constant-expression */ aRECV_Left:
    case /* constant-expression */ bRECV_Left:
      /* code */ *IRrecv_Get = 3;
    case /* constant-expression */ aRECV_right:
    case /* constant-expression */ bRECV_right:
      /* code */ *IRrecv_Get = 4;
    case /* constant-expression */ aRECV_ok:
    case /* constant-expression */ bRECV_ok:
      /* code */ *IRrecv_Get = 5;
    case /* constant-expression */ aRECV_1:
    case /* constant-expression */ bRECV_1:
      /* code */ *IRrecv_Get = 6;
    case /* constant-expression */ aRECV_2:
    case /* constant-expression */ bRECV_2:
      /* code */ *IRrecv_Get = 7;
    case /* constant-expression */ aRECV_3:
    case /* constant-expression */ bRECV_3:
      /* code */ *IRrecv_Get = 8;
    case /* constant-expression */ aRECV_4:
    case /* constant-expression */ bRECV_4:
      /* code */ *IRrecv_Get = 9;
    case /* constant-expression */ aRECV_5:
    case /* constant-expression */ bRECV_5:
      /* code */ *IRrecv_Get = 10;
    case /* constant-expression */ aRECV_6:
    case /* constant-expression */ bRECV_6:
      /* code */ *IRrecv_Get = 11;
    case /* constant-expression */ aRECV_7:
    case /* constant-expression */ bRECV_7:
      /* code */ *IRrecv_Get = 12;
    case /* constant-expression */ aRECV_8:
    case /* constant-expression */ bRECV_8:
      /* code */ *IRrecv_Get = 13;
    case /* constant-expression */ aRECV_9:
    case /* constant-expression */ bRECV_9:
      /* code */ *IRrecv_Get = 14;
    default:
      // *IRrecv_Get = 5;
      irrecv.resume();
      return false;
    irrecv.resume();
    return true;
    return false;
void DeviceDriverSet_IRrecv::DeviceDriverSet_IRrecv_Test(void)
    Serial.print("IRrecv_Test:");
    Serial.println(results.value);
    irrecv.resume();
#endif
where's the colors, will they come back after i drink me coffee??
the above function is the one you're after..
these are #define 's look in the .h file see if they're in there, being bools just 2 possible values 0 and 1, bit of experimenting and you should discover direction..
you don't have separate motor control, looks like they grouped each side, which is actually fine..
lol, funny, triple x delay??
maybe I don't want to know what it's doing.. :slight_smile:
maybe start by making a function that calls Motor_control and discover how it works..
then expand it..
have fun.. ~q
