when i want use the direction keys, taking this error
#include <DigiKeyboard.h>
#include <keylayouts.h>
#include <oddebug.h>
#include <osccal.h>
#include <osctune.h>
#include <scancode-ascii-table.h>
#include <usbconfig-prototype.h>
#include <usbconfig.h>
#include <usbdrv.h>
#include <usbportability.h>
DigiKeyboard.delay(500);
DigiKeyboard.sendKeyStroke(KEY_D, MOD_GUI_LEFT);
DigiKeyboard.sendKeyStroke(KEY_R, MOD_GUI_LEFT);
DigiKeyboard.print("cmd");
DigiKeyboard.delay(100);
DigiKeyboard.sendKeyStroke(KEY_ARROW_RIGHT);
DigiKeyboard.delay(200);
DigiKeyboard.sendKeyStroke(KEY_ARROW_DOWN);
DigiKeyboard.sendKeyStroke(KEY_ENTER);
:\Users\ester\OneDrive\Masaüstü\Bağlantı Açıcı Denemeleri\denemearduino2\denemearduino2.ino: In function 'void setup()':
C:\Users\ester\OneDrive\Masaüstü\Bağlantı Açıcı Denemeleri\denemearduino2\denemearduino2.ino:20:30: error: 'KEY_ARROW_RIGHT' was not declared in this scope
C:\Users\ester\OneDrive\Masaüstü\Bağlantı Açıcı Denemeleri\denemearduino2\denemearduino2.ino:22:30: error: 'KEY_ARROW_DOWN' was not declared in this scope
exit status 1
Compilation error: 'KEY_ARROW_RIGHT' was not declared in this scope
I dont have key_arrow_left too, I just want add direction keys can't u explain simply
* Based on Obdev's AVRUSB code and under the same license.
* TODO: Make a proper file header. :-)
* Modified for Digispark by Digistump
#ifndef __DigiKeyboard_h__
#define __DigiKeyboard_h__
#include <Arduino.h>
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <avr/delay.h>
#include <string.h>
#include "usbdrv.h"
#include "keylayouts.h"
typedef uint8_t byte;
#define BUFFER_SIZE 2 // Minimum of 2: 1 for modifiers + 1 for keystroke
static uchar idleRate; // in 4 ms units
/* We use a simplifed keyboard report descriptor which does not support the
* boot protocol. We don't allow setting status LEDs and but we do allow
* simultaneous key presses.
* The report descriptor has been created with usb.org's "HID Descriptor Tool"
* which can be downloaded from http://www.usb.org/developers/hidpage/.
* Redundant entries (such as LOGICAL_MINIMUM and USAGE_PAGE) have been omitted
* for the second INPUT item.
const PROGMEM char usbHidReportDescriptor[USB_CFG_HID_REPORT_DESCRIPTOR_LENGTH] = { /* USB report descriptor */
0x05, 0x01, // USAGE_PAGE (Generic Desktop)
0x09, 0x06, // USAGE (Keyboard)
0xa1, 0x01, // COLLECTION (Application)
0x05, 0x07, // USAGE_PAGE (Keyboard)
0x19, 0xe0, // USAGE_MINIMUM (Keyboard LeftControl)
0x29, 0xe7, // USAGE_MAXIMUM (Keyboard Right GUI)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x25, 0x01, // LOGICAL_MAXIMUM (1)
0x75, 0x01, // REPORT_SIZE (1)
0x95, 0x08, // REPORT_COUNT (8)
0x81, 0x02, // INPUT (Data,Var,Abs)
0x95, 0x01, // REPORT_COUNT (simultaneous keystrokes)
0x75, 0x08, // REPORT_SIZE (8)
0x25, 0x65, // LOGICAL_MAXIMUM (101)
0x19, 0x00, // USAGE_MINIMUM (Reserved (no event indicated))
0x29, 0x65, // USAGE_MAXIMUM (Keyboard Application)
0x81, 0x00, // INPUT (Data,Ary,Abs)
0xc0 // END_COLLECTION
#define MOD_CONTROL_LEFT MODIFIERKEY_LEFT_CTRL
#define MOD_SHIFT_LEFT MODIFIERKEY_LEFT_SHIFT
#define MOD_ALT_LEFT MODIFIERKEY_LEFT_ALT
#define MOD_GUI_LEFT MODIFIERKEY_LEFT_GUI
#define MOD_CONTROL_RIGHT MODIFIERKEY_RIGHT_CTRL
#define MOD_SHIFT_RIGHT MODIFIERKEY_RIGHT_SHIFT
#define MOD_ALT_RIGHT MODIFIERKEY_RIGHT_ALT
#define MOD_GUI_RIGHT MODIFIERKEY_RIGHT_GUI
class DigiKeyboardDevice : public Print {
public:
DigiKeyboardDevice () {
cli();
usbDeviceDisconnect();
_delay_ms(1);
usbDeviceConnect();
usbInit();
sei();
// TODO: Remove the next two lines once we fix
// missing first keystroke bug properly.
memset(reportBuffer, 0, sizeof(reportBuffer));
usbSetInterrupt(reportBuffer, sizeof(reportBuffer));
void update() {
usbPoll();
// delay while updating until we are finished delaying
void delay(long milli) {
unsigned long last = millis();
while (milli > 0) {
unsigned long now = millis();
milli -= now - last;
last = now;
update();
//sendKeyStroke: sends a key press AND release
void sendKeyStroke(byte keyStroke) {
sendKeyStroke(keyStroke, 0);
//sendKeyStroke: sends a key press AND release with modifiers
void sendKeyStroke(byte keyStroke, byte modifiers) {
sendKeyPress(keyStroke, modifiers);
// This stops endlessly repeating keystrokes:
sendKeyPress(0,0);
//sendKeyPress: sends a key press only - no release
//to release the key, send again with keyPress=0
void sendKeyPress(byte keyPress) {
sendKeyPress(keyPress, 0);
//sendKeyPress: sends a key press only, with modifiers - no release
void sendKeyPress(byte keyPress, byte modifiers) {
while (!usbInterruptIsReady()) {
// Note: We wait until we can send keyPress
// so we know the previous keyPress was
// sent.
usbPoll();
_delay_ms(1);
reportBuffer[0] = modifiers;
reportBuffer[1] = keyPress;
uint8_t keycode_to_modifier(KEYCODE_TYPE keycode){
uint8_t modifier=0;
#ifdef SHIFT_MASK
if (keycode & SHIFT_MASK) modifier |= MODIFIERKEY_SHIFT;
#endif
#ifdef ALTGR_MASK
if (keycode & ALTGR_MASK) modifier |= MODIFIERKEY_RIGHT_ALT;
#endif
#ifdef RCTRL_MASK
if (keycode & RCTRL_MASK) modifier |= MODIFIERKEY_RIGHT_CTRL;
#endif
return modifier;
uint8_t keycode_to_key(KEYCODE_TYPE keycode){
uint8_t key = keycode & 0x3F;
#ifdef KEY_NON_US_100
if (key == KEY_NON_US_100) key = 100;
#endif
return key;
size_t write(uint8_t chr) {
uint8_t data = 0;
if (chr == 0x09) {
data = KEY_TAB;
}else if (chr == 0x0a) {
data = KEY_ENTER;
}else if (chr >= 0x20) {
data = pgm_read_byte_near(keycodes_ascii + (chr - 0x20));
if (data) {
sendKeyStroke(keycode_to_key(data), keycode_to_modifier(data));
return 1;
//private: TODO: Make friend?
uchar reportBuffer[2]; // buffer for HID reports [ 1 modifier byte + (len-1) key strokes]
using Print::write;
DigiKeyboardDevice DigiKeyboard = DigiKeyboardDevice();
#ifdef __cplusplus
extern "C"{
#endif
// USB_PUBLIC uchar usbFunctionSetup
uchar usbFunctionSetup(uchar data[8]) {
usbRequest_t *rq = (usbRequest_t *)((void *)data);
usbMsgPtr = DigiKeyboard.reportBuffer; //
if ((rq->bmRequestType & USBRQ_TYPE_MASK) == USBRQ_TYPE_CLASS) {
/* class request type */
if (rq->bRequest == USBRQ_HID_GET_REPORT) {
/* wValue: ReportType (highbyte), ReportID (lowbyte) */
/* we only have one report type, so don't look at wValue */
// TODO: Ensure it's okay not to return anything here?
return 0;
} else if (rq->bRequest == USBRQ_HID_GET_IDLE) {
//usbMsgPtr = &idleRate;
//return 1;
return 0;
} else if (rq->bRequest == USBRQ_HID_SET_IDLE) {
idleRate = rq->wValue.bytes[1];
/* no vendor specific requests implemented */
return 0;
#ifdef __cplusplus
} // extern "C"
#endif
#endif // __DigiKeyboard_h__
