How can I blink the LED on ESP32-S3-WROOM-1
@ptillisch and do you have any idea how I can get this LED to blink ?
I even tryed
but it didnt worked ....
which exact ESP32-S3 do you have?
the ESP32-S3-WROOM-1 is just a chip, there is no LED...
any reason why you are pinging @ptillisch specifically?
GPIO 38 is the RGB LED ...
if I run the following code it blinks the large white LED
  Blink
  Turns an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
  it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
  the correct LED pin independent of which board is used.
  If you want to know what pin the on-board LED is connected to on your Arduino
  model, check the Technical Specs of your board at:
  https://www.arduino.cc/en/Main/Products
  modified 8 May 2014
  by Scott Fitzgerald
  modified 2 Sep 2016
  by Arturo Guadalupi
  modified 8 Sep 2016
  by Colby Newman
  This example code is in the public domain.
  https://www.arduino.cc/en/Tutorial/BuiltInExamples/Blink
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  Serial.print('*');
  digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);                      // wait for a second
  digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
make sure you connect the USB cable to the correct C-type (right hand in your picture in post 3)
after upload you have to press RST
