What IC can I use to generate multiple variable different frequencies? The IC should output that frequency to different pins, that aren’t dependent on each other.
for example: In one moment, I want 140 kHz on pin 1, 270 kHz on pin 2, 400 kHz on pin 3.
An Arduino can do that, using the timers.
but the square wave is not perfect I want to fid the signals into LEDs and the timer can't generate specific frequencies.
Complete nonsense.
If you want help, describe your project in sufficient detail. See the "How to get the best out of the forum" post.
I want to generate three electrical ID signals with different carrier frequencies for 3 LEDs (The carrier frequencies are 140 kHz, 270 kHz, and 400 kHz); Each LED transmits an identity ID signal in the format on-off keying upconverted to a specific RF carrier frequency.
how can I do that?
An Arduino can generate the three mentioned frequencies, by programming the timers correctly. Excellent tutorial for AVR based Arduinos at: https://www.gammon.com.au/timers
You could use an Si5351 clock generator.
https://learn.adafruit.com/adafruit-si5351-clock-generator-breakout
when I tried to simulate si5351 with Arduino in proteus I didn't get any output.
I used the code below:
#include <Adafruit_SI5351.h>
#include <Wire.h>
Adafruit_SI5351 clockgen = Adafruit_SI5351();
Arduino setup function (automatically called at startup)
void setup(void)
Serial.println("Si5351 Clockgen Test"); Serial.println("");
/* Initialise the sensor */
if (clockgen.begin() != ERROR_NONE)
/* There was a problem detecting the IC ... check your connections */
Serial.print("Ooops, no Si5351 detected ... Check your wiring or I2C ADDR!");
while(1);
Serial.println("OK!");
/* INTEGER ONLY MODE --> most accurate output */
/* Setup PLLA to integer only mode @ 900MHz (must be 600..900MHz) */
/* Set Multisynth 0 to 112.5MHz using integer only mode (div by 4/6/8) */
/* 25MHz * 36 = 900 MHz, then 900 MHz / 8 = 112.5 MHz */
Serial.println("Set PLLA to 900MHz");
clockgen.setupPLLInt(SI5351_PLL_A, 36);
Serial.println("Set Output #0 to 112.5MHz");
clockgen.setupMultisynthInt(0, SI5351_PLL_A, SI5351_MULTISYNTH_DIV_8);
/* FRACTIONAL MODE --> More flexible but introduce clock jitter */
/* Setup PLLB to fractional mode @616.66667MHz (XTAL * 24 + 2/3) */
/* Setup Multisynth 1 to 13.55311MHz (PLLB/45.5) */
clockgen.setupPLL(SI5351_PLL_B, 24, 2, 3);
Serial.println("Set Output #1 to 13.553115MHz");
clockgen.setupMultisynth(1, SI5351_PLL_B, 45, 1, 2);
/* Multisynth 2 is not yet used and won't be enabled, but can be */
/* Use PLLB @ 616.66667MHz, then divide by 900 -> 685.185 KHz */
/* then divide by 64 for 10.706 KHz */
/* configured using either PLL in either integer or fractional mode */
Serial.println("Set Output #2 to 10.706 KHz");
clockgen.setupMultisynth(2, SI5351_PLL_B, 900, 0, 1);
clockgen.setupRdiv(2, SI5351_R_DIV_64);
/* Enable the clocks */
clockgen.enableOutputs(true);
Arduino loop function, called once 'setup' is complete (your own code
should go here)
void loop(void)
Does Proteus actually claim to include the SI5351? ![]()
yes, It does.
I bought a si5351 and I still getting the same error
