How can I increase scrollback of the Output-window in Arduino IDE 2
I try to compile a project with Arduino IDE 2.2.1 and from time to time I create code which throws lots of errors. Like template stuff or in case of a unfitting platform (I am trying to adapt some stuff, so this is expected). The window only shows the last lines of the error. This way I can not see if there is a message which leads to all the stuff going wrong afterwards.
How can I force the output to show me the beginning of the messages. I'd like to increase the buffer of the window or whatever... any ideas?
Welcome to the forum
Your topic has been moved to a more appropriate category of the forum than "Uncategorised" where you originally posted it
Are you saying that the you cannot scroll the IDE output window at all or that you cannot scroll it enough ?
Thank, you. I can scroll up but not enough. On a terminal window I'd just increase the buffer, but in the settings there is no option for that.
I would call the compiler manually but I hope I don't need to resolve all the dependency by hand before doing this. So I hope to just set a secret value in a hidden config file or something like this. I'm on a Ubuntu 20 LTS by the way.
Hi @stretchdude. This can be configured via the Arduino IDE advanced settings. I'll provide instructions:
  1. Press the Ctrl+Shift+P keyboard shortcut (Command+Shift+P for macOS users) to open the "Command Palette".
    A menu will appear on the editor toolbar:
  2. Select the "Preferences: Open Settings (UI)" command from the menu.
    You can scroll down through the list of commands to find it or type the name in the field.
    A "Preferences" tab will open in the Arduino IDE main panel.
  3. Type output.maxChannelHistory in the "Search Settings" field of the "Preferences" tab.
  4. Adjust the value in the field under the "Output: Max Channel History" setting according to your preferences.
  5. Close the Preferences tab by clicking its X icon.
Thank you so much <3 :partying_face: It works!
You are welcome. I'm glad if I was able to be of assistance.
Regards,
Per
