BLDC.pdf (651.4 KB)
I have data sheet of motor in attachment if anyone can give any suggestion I will be thankful.
BLDC.pdf (651.4 KB)
If you are sure the link is the exact same model / Part number then their table "integrated electronics" lists all the inputs and outputs.
I would guess you would use a 5V processor,
Orange is a logical signal for direction
Yellow is a logical signal for stop start. Likely 1 = start and 0 = stop
Green would be 5V
Blue is likely a PWM signal but they don't say.
Red will be what ever voltage the motor needs.
Brown is BOTH the logic (5V) and motor voltage common (aka ground)
Thanks for reply but I still don't understand. I am not that good at it, can u share a link of the processor that I should use to run this motor. Here I have attached the image of motor
Any 5V Arduino processor will work.
It sounds to me like you question should not be "how do I hook this motor up" to "How do I start with Arduino". Then in the text explain your first goal is to be able to control this motor.
So you should start a new thread.
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
My comment may not have been explicit enough. What I was trying to suggest was you start a new thread on how to get an Arduino up and running with your motor.
If I had misled you I apologize.
