I got a V5 circuit that I want to turn on/off with a V3.3 microcontroller.
I want to use a PNP transistor so that when the load is off, it has no voltage compared to GND.
The reason is safety in case someone accidentally touches the load while grounded. The load is a pressure sensor, so it would only be on a couple of milliseconds at a time. (I know V5 will likely not do much harm, but I am trying to learn if it can be done with a PNP transistor).
I came up with this:
I tested it out, and it seemed to work flawlessly for me. But I am not an electrical engineer. Does anyone know if this circuit makes sense/has any pitfalls I should watch out for? Or is there a better way?
I'm trying to no have the load be connected to V+ while the transistor is not saturated that's why I am trying to learn if it can be done with a PNP transistor.
Does if the Load is on the source or drain side for MOSFETs?
That is what I meant. If load is a motor or relay, it is important to saturate the transistor. If it is a digital pin or a voltmeter it will work like it is now without trouble.
[quote="philw_01, post:4, topic:1087533"]
Would adding a resistor between the load and GND help fix that?[/quote]
No. A resistor may reduce the heat produced in the transistor, but your load will now see 5V - voltage drop over transistor - voltage drop over resistor
Advantages: very low resistance when 'on'.
Low losses, low heat production.
Almost complete decoupling of arduino and motor circuit (resistance of gate is very very high).
MOSFETs are voltage controlled devices, i.e. they take no current from the Arduino output pin.
The turn on resistance Rds(on) is very low, often less than 45 milli ohms. This means the saturation voltage Vds will be low, hence the package power dissipation is very low, lower than that of the BJT.
Do you mean this?
The BD140 is a PNP transistor, so it will be ON when the base terminal is connected to the ground, and it will be off when a positive voltage is applied to the base terminal of the transistor. The base current of this transistor is less than 10mA.
That graphic is wrong, for a PNP to work the collector has to be negative with respect to the emitter, in the right diag that is wrong.
In fact the right diag should have an NPN symbol.
The left graphic will only work if the voltage to the base resistor goes up to Vcc, if Vcc is higher that the HIGH output of the controller, the PNP BJT will not turn OFF.
Tom...
PS. @crystallin where did that graphic come from?
