I'm starting to a new project arduino/nokia e51 as gsm message sender for domotic control; first of all i have to test at commands via windows putty; anybody can help me to set putty?
Thanks
Paolo
Thanks
Paolo
Does your nokia cable when connect install a new SerialPort on windows?
I had done what you want to test but it was in linux.My test was with a nokia e60.
All I had done in linux was conect the cable to the nokia, see what Serial port was created and open a hyper terminal(GTKTERM) on that port.
On windows the process should be the same but perhaps you will need to install the software because windows will not install it natively.
Thanks UGO.
Probably i wrong configuration parameters, can you send me screenshots of the configuration with GTKTERM?
