How could I put my file into a directory? [SOLVED]
I'm making a program for a datalogger; all the hardware etc is in the code as comments. As I could use the code to program different data loggers, I would like to use the same SD card, however, as the file name supports 8.3 file formatting, if I tried to log data on more than one program in the same day, the file names would be equal and append the data to the same file. So, I want to be able to create a directory for this file too, however, I'm a little stuck on the syntax of using the file name correctly and putting it into a directory. Any help would be appreciated. Here is the code:
/*    _______________________________________________________________________________________________________________________________________________________________________
ㅤㅤ /\             \        /            /\
ㅤ ㅤ|_\             \                                                               DATALOGGER                                                               /            /_|
ㅤㅤ |__\             \________________________________  16x2 LCD, SD ADAPTER, DS1307, DS18B20 (5.1kPU), 10k NTC THERMISTOR  ________________________________/            /__|
ㅤㅤ |___\                                             \____________________________________________________________________/                                            /___|
ㅤㅤ |____\        /____|
ㅤ ㅤ|_____\                  _______________________________________________________________________________________________________________________                  /_____|
ㅤㅤ \______\                /        \                /______/
ㅤㅤ  \_____/\______________/  THIS PROGRAM MAY ALSO BE USED AS A GENERAL DATA LOGGER BY MODIFYING THE SENSOR CODE AND INPUTTING THE NECESSARY CODE   \______________/\_____/
ㅤ ㅤ                        \________________________________________________________________________________________________________________________/
___________________________________________________________________________________________________________________________________________________________________________________
ㅤ  ㅤ   ㅤ           ㅤ/                                                   \                           /
HARDWARE WIRING LIST: /                                                     \   PROGRAM DESCRIPTION:  /
_____________________/                                                       \_______________________/
ㅤ
_________________________________                        _________________________________________________________________
FOR 16X2 LIQUID CRYSTAL DISPLAY: \                      /        \
............_____________________/                     /  This program is designed to log data from a DS18B20 temperature  \
-VSS GND   /                                           |  sensor   and   a  10K  NTC  thermistor.  Once the  SD  card  is  |
-VDD 5V    \                                           |  initialised and the start button is pressed, the  program  will  |
-V0 10K POT \                                          |  create a file in the SD card and name it according to the  date  |
-RS PIN D2  |                                          |  (the date is retrieved using a DS1307 RTC). once the  file  and  |
-RW GND    /                                           |  file name is created, 8 data samples from  the  DS18B20  sensor  |
-E PIN D3  |                                           |  and thermistor are  averaged  and  logged  within  the  logging  |
-D0 X     /                                            |  interval into the created file, as well as the time in  seconds  |
-D1 X    /                                             |  that the program started  and  the  real  time  clock.  If  the  |
-D2 X    \                                             |  program is ran  until  the  next  day,  data  logging  will  be  |
-D3 X     \                                            |  stopped, and another file will be created and  named  according  |
-D4 PIN D4 \                                           |  to the date. The  liquid  crystal  display  or  serial  monitor  |
-D5 PIN D5  \                                          |  (dependant on the DEBUG state) can be used to ensure  that  the  |
-D6 PIN D6  |                                          |  program runs correctly, displaying SD card initialisation,  RTC  |
-D7 PIN D7  /                                          |  initialisation, the filename the data is writing to,  the  time  |
-A 5V      /                                           |  the data started logging in seconds, and the  current  time  of  |
-K GND    /                                            \  the RTC. If any errors occur, the LCD or  serial  monitor  will  /
_________/                                              \__________________  display an error message.  __________________/
ㅤ        \___________________________/
FOR SD CARD ADAPTER MODULE: \
..............______________/
-CS PIN D10   \
-MOSI PIN D11  |
-MISO PIN D12 /
-SCK PIN D13 /
____________/
_________________
FOR DS1307 RTC:  \
.............____/
-SCL PIN SCL \
-SDA PIN SDA  |
-SQW X  _____/
_______/
FOR DS18B20 TEMPERATURE SENSOR: \
........._______________________/
-POS 5V  \
-NEG GND  \__
-DQ 5.1kPU   \_
-5.1kPU PIN D9 \_____________________________
-104pF CERAMIC CAPACITOR LIKNING POS AND NEG \
FOR 10k NTC THERMISTOR: \
..........._____________/
-POS 5V    \
-NEG PIN A1 \___________________________
-10k RESISTOR LIKNING NEG AND A1 TO GND \
// INCLUDE LIBRARIES AND DEFINED CONSTANTS:
#include <OneWire.h> //one wire communication
#include <DallasTemperature.h> //library for DS18B20 temperature sensor
#include <SPI.h> //library for SPI pins of the SD card module adapter
#include <SD.h> //library for the SD card
#include <LiquidCrystal.h> //library for the LCD
#include <Wire.h> //wire communcation
#include <TimeLib.h> //time elements library
#include <DS1307RTC.h> //library for the DS1307 RTC
#define totalTime() millis() / 1000 //gives the total time in seconds
#define ONE_WIRE_BUS 9 //define the communication pin of the DS18B20 temperature sensor to digital pin 9
#define getT1() sensors.getTempCByIndex(0) //redefine for ease of coding (I couldn't be bothered typing sensors.getTempCByIndex(0) all the time)
#define requestT1() sensors.requestTemperatures() //redefine for ease of coding, same as getTempCByIndex(0)
#define T2Pin A1 //define the pin of the thermistor to analog pin 1
#define year() tmYearToCalendar(tm.Year) - 2000 //gives the year as a 2 digit integer
// DEBUG STATE:
#define DEBUG 0 //current DEBUG state, spaced out for ease of navigation. Equal to 0 or 1: 0 for LCD debugging data, 1 for serial monitor debugging data
// IF DEBUG STATE
#if DEBUG == 1 //if DEBUG == 1 then serial debugging data will be printed, lcd debugging data will not. x in all of these arguments are placeholders
#define debug(x) Serial.print(x) //define debug as serial print
#define debugln(x) Serial.println(x) //define debugln as serial println
#define debugLCD(x) //lcd print undefined, therefore it will not be compiled
#define clearLCD() //lcd clear undefined, therefore it will not be compiled
#define SCLCD() //set cursor undefined, therefore it will not be compiled
#else //if DEBUG == 0 then lcd debugging data will be printed, serial debugging data will not
#define debug(x) //serial print undefined, therefore it will not be compiled
#define debugln(x) //serial println undefined, therefore it will not be compiled
#define debugLCD(x) lcd.print(x) //define debugLCD as lcd print
#define clearLCD() lcd.clear() //define lcd clear as clearLCD
#define SCLCD() lcd.setCursor(0, 0) //define set cursor LCD as lcd set cursor to 0, 0 on the display
#endif //end if definitions
// GLOBAL VARIABLES:
File dataFile; //the file we will be using to create the filename and write to
OneWire oneWire(ONE_WIRE_BUS); //used for the DS18B20 sensor
DallasTemperature sensors(&oneWire); //used for the DS18B20 sensor
LiquidCrystal lcd(2, 3, 4, 5, 6, 7); //set pins on the lcd
tmElements_t tm; //time elements
const short CS = 10; //chip select pin for the micro SD card adapter module
const short logInterval = 10; //the interval of which the data is written to the file
const float sampleInterval = 1.25; //the interval of which the samples will be taken
static unsigned long logTime = totalTime() + logInterval; //the total log time of the data logger
static float sampleTime = totalTime() + sampleInterval; //the total sample time of the data logger
const short userDelay = 2000; //delay for user opimisation
static short numSamples = 0; //the number of samples taken
static float averageT1; //the average of the sum of samples of temperature sensor 1, divided by the number of samples
static float averageT2; //the average of the sum of samples of temperature sensor 2, divided by the number of samples
static float totalT1 = 0; //the total of the sum of samples of temperature sensor 1
static float totalT2 = 0; //the total of the sum of samples of temperature sensor 2
// INITIALISATION FUNCTION:
void initialisation() { //used in setup to initialise the RTC and SD card
  delay(userDelay); //delay for user optimisation
  while (!Serial); //wait for serial port to connect
  Serial.begin(115200); //begins serial communication
  lcd.begin(16, 2); //begins LCD communication
  SCLCD(); //sets the cursor of the LCD to 0, 0
  debugln(); //prints a new line to format serial monitor data in case of zero bytes printed during serial connection
  debugln("Initialising RTC & SD card..."); //prints that the RTC and SD are being initialised to the serial monitor
  debugLCD("Initialising..."); //prints that the RTC and SD are being initialised to the LCD
  clearLCD(); //clears the LCD
  if (!SD.begin(CS)) { //checks if SD card is available and prints error message if not
    debugln("SD card failed"); //prints that the SD card has failed to the serial monitor
    debugLCD("SD card failed"); //prints that the SD card has failed to the LCD
    while (1) {
      //create an endless loop with nothing to do if file does not open
    } //end while loop
  } //end if
  else {  //prints message that the SD has been initialised
    debugln("SD initialised"); //prints message that the SD card has been initialised to the serial monitor
    debugLCD("SD initialised"); //prints message that the SD card has been initialised to the LCD
  }  //end else
  if (RTC.read(tm)) { //prints message that the RTC has been initialised
    debugln("RTC initialised"); //prints that the RTC has been initialised to the serial monitor
    debugLCD("RTC initialised"); //prints that the RTC has been initialised to the LCD
  } //end RTC if
  else { //prints debugging message if RTC fails to initialise
    debugln("RTC failed"); //prints RTC failed message to the serial monitor
    debugLCD("RTC failed"); //prints RTC failed message to the LCD
    while (1) {
    } //end while loop
  } //end else
} //end initialisation()
// CREATE FILE AND NAME() FUNCTION:
void createFileAndName() { //creates file and names the file according to the date
  char fileName[13]; //buffer to store file name
  sprintf(fileName, "%02d-%02d-%d.txt", tm.Day, tm.Month, year());  //formats and concatenates the RTC data to create the file name
  if (!SD.exists(fileName)) { //creates file if the file is not already created
    debug("Creating file..."); //prints that the file is being created to the serial monitor
    debug("File name: "); //prints the beginning of the sentence to the serial monitor
    debugln(fileName); //prints the file name to the serial monitor
  } //end SD if
  else { //appends data to already existing file
    debug("The file: "); //prints the beginning of the sentence to the file name
    debug(fileName); //prints file name to the serial monitor
    debugln(" already exists. Opening file..."); //prints message to the serial monitor
  } //end else
  debugLCD(fileName); //prints the file name to the top left of the LCD
// SD CARD FIRST WRITE- HEADER:
  dataFile = SD.open(fileName); //opens the dataFile named after the current date on the RTC
  if (dataFile) { //if the dataFile opens it will print the datalogging header
    dataFile.println(); // Helps format the data if more than one logging process has been utilised in the same file.
    dataFile.println("TEMPERATURE DATA LOGGER"); //prints the datalogging header to the dataFile
    dataFile.close(); //closes the data file to avoid data corruption
    debugln("TEMPERATURE DATA LOGGER"); //prints datalogging header to the serial monitor
  } //end dataFile if
  else { //if the file does not open
    debugln("Error opening and writing to file"); //prints error message to the serial monitor
    clearLCD(); //clears the CLCD to print the error message
    debugLCD("File write error"); //prints error message to the LCD
    while (1) {
    } //end while loop
  }  //end else
} //end createFileAndName()
// GET AVERAGE READING() FUNCTION:
void getAverageReading() { //prints and logs average temperature data to the file
  lcd.setCursor(0, 1); //sets the cursor below the file name printed at the lop left of the LCD
// RTC TIME INFO PRINT TO LCD:
  char displayTime[9]; //placeholder for displaying real time
  RTC.read(tm); //reads the time from the RTC
  sprintf(displayTime, "%02d:%02d:%02d", tm.Hour, tm.Minute, tm.Second); //concatenates and formats the data of the real time clock
  debugLCD(displayTime); //prints the real time to the LCD
// CALCULATION FOR T2:
  int tempReading = analogRead(T2Pin); //request to read the T2 pin (analog pin A1)
  double tempK = log(10000.0 * ((1024.0 / tempReading - 1))); //temperature in Kelvin from analog pin reading
  tempK = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * tempK * tempK)) * tempK); //redeclaration of tempK to convert pin reading to Kelvin
  double T2 = tempK - 273.15; //T2 calculation result in degrees celsius from Kelvin
  getT1(); //gets the temperature from the request within setup
  requestT1(); //requests temperature in the loop, which will be used in the next loop iteration
// CHARACTER ARRAYS:
  char averageData[63]; //character buffer for sprintf()
  char charLogTime[8]; //placeholder for log time character
  char charAverageT1[9]; //placeholder for averageT1 character
  char charAverageT2[9]; //placeholder for averageT2 character
// DTOSTRF FUNCTIONS:
  dtostrf(logTime, 7, 0, charLogTime); //converts int to char and used to format the logTime data within the lcd screen and the average data character buffer
  dtostrf(averageT1, 8, 2, charAverageT1); //converts float to char as sprintf cannot use float values
  dtostrf(averageT2, 8, 2, charAverageT2); //converts float to char as sprintf cannot use float values
// SPRINTF TO CONCATENATE/FORMAT LOGGED DATA:
  sprintf(averageData, "%02d:%02d:%02d  time(s):%s  T1(ºC):%s  T2(ºC):%s", tm.Hour, tm.Minute, tm.Second, charLogTime, charAverageT1, charAverageT2);
//TAKE SAMPLE:
  if (totalTime() > sampleTime) { //increments the following every 1.25 seconds
    numSamples += 1; //increments the number of samples by 1
    totalT1 += getT1(); //increments the total of T1 by the sample reading
    totalT2 += T2; //increments the total of T2 by the sample reading
    sampleTime += sampleInterval; //increments the sample time by the sample interval
  }  //end total time if
// AVERAGE TEMPERATURE READINGS:
  averageT1 = totalT1 / numSamples;  //calculate total of T1
  averageT2 = totalT2 / numSamples;  //calculate total of T2
// OPEN FILE:
  dataFile = SD.open(fileName, FILE_WRITE); //opens file to write to
    createFileAndName(); //re-runs the createFileAndName() user defined function
  } //end SD if
  else {
    //do nothing
// WRITE AND PRINT DATA TO SD & LCD:
  if (dataFile) {  //checks if the file is available
    if (totalTime() > logTime) {  //prints the data within the logging interval
      dataFile.println(averageData);  //prints the average data to the dataFile
      debugln(averageData); //prints the average data to the serial monitor
      lcd.setCursor(8, 1); //sets the cursor so the LCD displays the time at the bottom right of the LCD
      debugLCD(charLogTime); //prints the log time to the LCD
      debugLCD("s"); //prints s to format the printed log time on the LCD
      logTime += logInterval; //increments the log time by the log interval
    if (numSamples > 7) {  //resets the number of samples and the total temperature readings
      numSamples = 0; //resets the number of samples back to 0
      totalT1 = 0; //resets the total of T1 back to 0
      totalT2 = 0; //resets the total of T2 back to 0
    }  //end numSamples if
  }  //end dataFile if
    clearLCD(); //clears the LCD to print the error message
    while (1) {
    }  //end while loop
  }  //end else
  dataFile.close(); //closes the data file at the end to avoid file corruption
}  //end getAverageReading()
// SETUP() FUNCTION
void setup() {  //runs once at the start of the program
  initialisation(); //runs initialisation() user defined function in setup
  createFileAndName();  //runs createFileAndName() user defined function in setup
  requestT1();  //requests data before first loop iteration to print data at the log interval
  sensors.setWaitForConversion(false);
}  //end setup
// LOOP() FUNCTION
void loop() {  //loops getAverageReading() user defined function and displays info on the 16x2 LCD screen
  getAverageReading(); //runs the getAverageReading() user defined function
}  //end loop
// END OF PROGRAM
there is the mkdir() function to create a directory and open() can include the path with the directories in the filename
That is where I'm confused. I tried it out and, as the file name is an sprint function, if I try use that, it says that TempData was not declared in this scope. However, if I try and use quotation marks, the directory is created but then the file name is "fileName.txt". I'm pretty sure there is a way around this, but I've been running off of 8 hours of sleep and caffeine for the past 3 days, so I just can't be bothered playing around with the syntax for ages- especially considering I'm new to arduino and programming.
show us a simple code you used for that...
here is an example in wokwi
click to see the code
#include <SD.h>
#define CS_PIN 10
void createDirectoryAndFile(const char *dirName) {
  // Create a directory
  Serial.print(dirName);
  if (SD.mkdir(dirName)) {
    Serial.println(" Directory created successfully");
    Serial.println(" => Error creating directory");
    return;
void dumpFile(const char * path) {
  File file = SD.open(path, FILE_READ);
  if (file) {
    Serial.print("\n\nContent of: "); Serial.println(path);
    Serial.println("----------------------");
    while (file.available()) Serial.write(file.read());
    file.close();
    Serial.print("error reading "); Serial.println(path);
  Serial.print("Initializing SD card... ");
  if (!SD.begin(CS_PIN)) {
    Serial.println("Card initialization failed!");
    while (true);
  Serial.println("initialization done.");
  createDirectoryAndFile("DIR1");
  createDirectoryAndFile("DIR2");
  File file = SD.open("DIR1/log1.txt", FILE_WRITE);
  if (file) {
    file.println("This content is in file DIR1/log1.txt");
    file.close();
    Serial.println("Done writing in DIR1/log1.txt.");
    Serial.println("error creating DIR1/log1.txt.");
  file = SD.open("DIR2/log1.txt", FILE_WRITE);
  if (file) {
    file.println("This content is in file DIR2/log1.txt");
    file.close();
    Serial.println("Done writing in DIR2/log1.txt.");
    Serial.println("error creating DIR2/log1.txt.");
  dumpFile("DIR1/log1.txt");
  dumpFile("DIR2/log1.txt");
void loop() {}
The issue I'm having is, as the file name is not constant and the directory name is, whenever I try and open the file in the directory:
dataFile = SD.open(directoryName/fileName, FILE_WRITE);
it says "invalid operands of types 'char [9]' and 'char [13]' to binary 'operator/'
I use the sprintf for the file name:
and use a character array for the directory name:
char directoryName[9] = "TempData";
I'm unable to use quotation marks in making the directory name (or I'm just unaware of the syntax) as if I try "TempData"/fileName, it gives the binary operator error.
Would it be possible to use pointers in the SD.open function? I'm not sure
build the full path in a c-string buffer, something like that
char directoryName[] = "TempData";
char fullPath[50]; //adjust 50 to your needs
strlcpy(fullPath, directoryName, sizeof fullPath);
strlcat(fullPath, "/", sizeof fullPath);
strlcat(fullPath, fileName, sizeof fullPath);
File dataFile = SD.open(fullPath, FILE_WRITE);
try this to see the result
  sprintf(fileName, "%02d-%02d-%d.txt", 5, 2, 24);
  Serial.println(fullPath);
void loop() {}
you should see in the serial monitor
TempData/05-02-24.txt
