hello i am new to this. i would want to know how to connect the nodemcu ESP8266 with arduino uno and use Blynk app via WiFi for an IOT project.
i have used LM35 as temperature sensor to collect data. i have connected LM35 with LCD display, buzzer, led and 1k ohm resistor with arduino uno and i have no problem with the connections.
so how do i add in the nodemcu with the code and arduino connection?
below is my code:
#include<LiquidCrystal.h> //Header file for LCD Module
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //lcd connected pins
const int sensor = A0; //Assigning analog A0 to variable sensor
float tempC; //variable to store temp in °C
float vout; //variable to store values from sensor
pinMode(sensor,INPUT); // Configuring A0 as input
lcd.begin(16,2);
pinMode(A0,INPUT);
pinMode(6,OUTPUT); //For buzzer
pinMode(9,OUTPUT); //For LED
vout=analogRead(sensor);
vout=(vout*500)/1023;
tempC=vout; // Storing value in °C
lcd.setCursor(0,0);
Serial.println(tempC);
if(tempC>=22) //For easiness I have taken 32°C as alert temperature
lcd.print("HIGH TEMP!! ");
lcd.setCursor(0,1);
lcd.print("C=");
lcd.print(tempC);
beep(200); //beeps for 200ms
lcd.print("Temp is Normal.");
lcd.setCursor(0,1);
lcd.print("C=");
lcd.print(tempC);
digitalWrite(9,0);
void beep(unsigned char delayms){
analogWrite(6, 20); // Any value can be used except 0 & 255
digitalWrite(9,1);
delay(delayms); // wait for a delayms ms
analogWrite(6, 0); // 0 turns it off
digitalWrite(9,0);
