How do I connect a 1 Channel 12V Relay Module to Arduino nano every?
I am using this relay module with arduino nano every board and I want to test it first, how do I connect it?
I tried connecting like:
Wiring the Relay Module:
  1. Relay to Arduino:
    VCC: Connect to the 5V pin on the Arduino.
    GND: Connect to the GND pin on the Arduino.
    IN (Control Signal): Connect to a digital pin on the Arduino (e.g., D4).
  2. Relay Output Connections:
    COM (Common): Connect to one terminal of the LED or lamp.
    NO (Normally Open): Connect to the positive side of a separate power supply (e.g., 9V battery for an LED or lamp).
    Negative side of the power supply: Connect to the other terminal of the LED or lamp.
It just doesn't work, can someone help me?
Welcome to the forum
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
Show us the code.
  • That module needs 9v for the coil to operate.
This should work (yours is 9v):
const int relayPin = 4; // Pin connected to the relay module
  pinMode(relayPin, OUTPUT); // Set relay pin as an output
  digitalWrite(relayPin, LOW); // Ensure relay is off initially
  digitalWrite(relayPin, HIGH); // Activate the relay
  delay(2000); // Keep the relay on for 2 seconds
  digitalWrite(relayPin, LOW); // Deactivate the relay
  delay(2000); // Keep the relay off for 2 seconds
An observation
Although it is not the cause of your problem, most relay modules are "active LOW", ie they turn on when their input is LOW
Change the relay pin as needed.
  • Show us several good images of your wiring.
  • Is your relay module 12v or 9v ?
I recently “reverse engineered” a schematic for a 12 volt relay module with selectable High/Low trigger input. It looks essentially like @LarryD ‘s schematic. The circuit Larry drew will work for “low” trigger mode.
The DC+ terminal has to be whatever voltage your relay module requires (12 per your description, 9 per the provided image). If you use the “low” trigger option you will damage your MCU by switching 12(9?) volts with the output pin. The additional transistor is required to avoid this.
What I don’t like about this type (High/Low selectable trigger) is that it does not allow complete isolation of the MCU wiring from the relay power. A common ground is required. Complete isolation can be achieved by removing the High/Low jumper entirely. Then, with the output pin from the MCU wired to the “In” terminal of the relay module, “High” trigger can be achieved by connecting the MCU ground to the “common” terminal of the selector. For low trigger the 5 volt supply from the MCU should be connected to the “common” terminal. This also eliminates the need for the additional transistor.
its 12V
it’s 12V
  • Was confused since the image you gave says 9v.
Sorry, but your schematic is nonsense garbage. You powered the Nano by 5v to VIN pin.
And you draw an analog input-only pin A7 to control the relay, while use a D7 in the code.
Only someone who doesn't understand arduino at all could draw something like this. Or, more likely, it's a product from ChatGPT that you mindlessly copied into the forum.
@andrewdonaldson177
As I see, you constantly drag all sorts of AI garbage into the forum. This is against the rules of the community. Please, answer with your own mind or better yet, keep quiet if you don't know the answer.
Actually it's called a mistake not sure why I didn't catch that I put it to A7 not D7 I must have been thinking about something else ADHD does that. Arduino Nano boards operate just fine on 5 volts. But since you feel so superior that you need to attempt to insult others in public have a good day. I hope you don't just sit in your room lonely someday after you alienate everyone you knew.
