How do i convert C code to Arduino code?
Im doing an elevator project and my teacher wants it in Arduino code
#define MX_ARD
#define MX_CAL_ARD
#define MX_CLK_SPEED 16000000
#define FCP_NULL Unconnected_Port
#define MX_UART_ID
#define MX_UART_UCSRC
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
#include <avr\io.h>
#include <avr\interrupt.h>
#include <avr\eeprom.h>
#include <avr\wdt.h>
Use :Include the type definitions
#include "C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\internals.c"
MX_UINT8 FCLV_LOOP1;
MX_UINT8 FCLV_LOOP2;
MX_UINT8 FCLV_LOOP3;
MX_UINT8 FCLV_LOOP4;
Use :panel
:Variable declarations
:Macro function declarations
#define FCV_FALSE (0)
#define FCV_TRUE (1)
MX_GLOBAL MX_UINT8 FCV_DATO = (0x0);
MX_GLOBAL MX_UINT8 FCV_CONTA = (0x1);
MX_GLOBAL MX_UINT8 FCV_PISOACTUAL = (0x1);
MX_GLOBAL MX_UINT8 FCV_MOVIMIENTO = (0x0);
MX_GLOBAL MX_SINT32 FCV_T = (1000);
Use :shape_cuboid2
Use :shape_cuboid1
Use :dash_IO_flasher
Use :TimeStamp1
Use :InjectorBase1
Use :COMPort1
Use :fcdhelper
Use :cal_uart
#define MX_UART_UseTX_1 (1)
#define MX_UART_TX_TRIS_1 trisd
#define MX_UART_REF1
#define MX_UART_RTS_PIN_1 (2)
#define MX_UART_DBITS_1 (8)
#define MX_UART_RETURN_1 (0)
#define MX_UART_RX_PORT_1 portd
#define MX_UART_RTS_PORT_1 portb
#define MX_UART_ECHO_1 (0)
#define MX_UART_FLOWEN_1 (0)
#define MX_UART_CTS_PORT_1 portb
#define MX_UART_TX_PIN_1 (1)
#define MX_UART_RX_TRIS_1 trisd
#define MX_UART_BAUD_1 (9600)
#define MX_UART_RTS_TRIS_1 trisb
#define MX_UART_TX_PORT_1 portd
#define MX_UART_RX_PIN_1 (0)
#define MX_UART_UseRX_1 (1)
#define MX_UART_CTS_TRIS_1 trisb
#define MX_UART_CHANNEL_1 (1)
#define MX_UART_INT_1 (0)
#define MX_UART_CTS_PIN_1 (1)
MX_GLOBAL MX_UINT32 FCV_05481_cal_uart__CONSOLE;
MX_UINT8 FCD_05481_cal_uart__ControlPin(MX_UINT8 FCL_PIN, MX_UINT8 FCL_STATE);
void FCD_05481_cal_uart__Prv_TextConsole(MX_CHAR *FCL_STR, MX_UINT16 FCLsz_STR, MX_UINT8 FCL_COLOUR);
void FC_CAL_UART_UpdateBaud_1(MX_UINT8 FCL_NEW_BAUD);
MX_UINT8 FCD_05481_cal_uart__TestProperty(MX_UINT8 FCL_PROPERTY);
void FCD_05481_cal_uart__Prv_SimShowWaveform(MX_UINT8 FCL_TXRX, MX_UINT16 FCL_DATA);
MX_SINT16 FC_CAL_UART_Receive_1(MX_UINT8 FCL_TIMEOUT);
void FC_CAL_UART_Send_1(MX_UINT16 FCL_CHAR);
void FC_CAL_UART_Init_1();
void FC_CAL_UART_Delay_1();
void FC_CAL_UART_Uninit_1();
Use :Bluetooth_HC05
void FCD_07aa1_Bluetooth_HC05__SetPairKey(MX_CHAR *PFCL_KEY);
void FCD_07aa1_Bluetooth_HC05__SendString(MX_CHAR *FCL_DATA, MX_UINT16 FCLsz_DATA);
void FCD_07aa1_Bluetooth_HC05__SendCommand(MX_CHAR *FCL_COMMAND, MX_UINT16 FCLsz_COMMAND);
void FCD_07aa1_Bluetooth_HC05__SetBaud(MX_BOOL FCL_BAUD);
void FCD_07aa1_Bluetooth_HC05__SendNumber(MX_SINT32 FCL_NUMBER);
void FCD_07aa1_Bluetooth_HC05__SendChar(MX_SINT16 FCL_CHAR);
void FCD_07aa1_Bluetooth_HC05__SetName(MX_CHAR *PFCL_NAME);
void FCD_07aa1_Bluetooth_HC05__ReceiveString(MX_CHAR *FCR_RETVAL, MX_UINT16 FCRsz_RETVAL, MX_UINT8 FCL_TIMEOUT, MX_UINT8 FCL_NUMBYTES);
void FCD_07aa1_Bluetooth_HC05__Initialise();
MX_SINT16 FCD_07aa1_Bluetooth_HC05__ReceiveChar(MX_SINT16 FCL_TIMEOUT);
Use :motion_helper1
Use :motor_base1
Use :ctrl_lcd
Use :LCD
void FCD_04071_LCD__Clear();
void FCD_04071_LCD__PrintString(MX_CHAR *FCL_TEXT, MX_UINT16 FCLsz_TEXT);
void FCD_04071_LCD__PrintAscii(MX_UINT8 FCL_CHARACTER);
void FCD_04071_LCD__PrintNumber(MX_SINT16 FCL_NUMBER);
void FCD_04071_LCD__RAMWrite(MX_UINT8 FCL_INDEX, MX_UINT8 FCL_D0, MX_UINT8 FCL_D1, MX_UINT8 FCL_D2, MX_UINT8 FCL_D3, MX_UINT8 FCL_D4, MX_UINT8 FCL_D5, MX_UINT8 FCL_D6, MX_UINT8 FCL_D7);
void FCD_04071_LCD__ClearLine(MX_UINT8 FCL_LINE);
void FCD_04071_LCD__Cursor(MX_UINT8 FCL_X, MX_UINT8 FCL_Y);
void FCD_04071_LCD__Command(MX_UINT8 FCL_INSTRUCTION);
void FCD_04071_LCD__PrintFormattedNumber(MX_UINT32 FCL_NUMBER, MX_BOOL FCL_FORMAT);
void FCD_04071_LCD__ScrollDisplay(MX_UINT8 FCL_POSITION, MX_UINT8 FCL_DIRECTION);
void FCD_04071_LCD__RawSend(MX_UINT8 FCL_DATA, MX_BOOL FCL_TYPE);
void FCD_04071_LCD__RemapCharacter(MX_UINT8 FCL_REMAPIDX, MX_UINT8 FCL_SEARCHCHARACTER, MX_UINT8 FCL_REPLACEMENTCHARACTER);
void FCD_04071_LCD__Start();
Use :lcd_16x2
#define FCD_0f9e1_lcd_16x2__Clear FCD_04071_LCD__Clear
#define FCD_0f9e1_lcd_16x2__PrintString FCD_04071_LCD__PrintString
#define FCD_0f9e1_lcd_16x2__PrintAscii FCD_04071_LCD__PrintAscii
#define FCD_0f9e1_lcd_16x2__PrintNumber FCD_04071_LCD__PrintNumber
#define FCD_0f9e1_lcd_16x2__RAMWrite FCD_04071_LCD__RAMWrite
#define FCD_0f9e1_lcd_16x2__ClearLine FCD_04071_LCD__ClearLine
#define FCD_0f9e1_lcd_16x2__Cursor FCD_04071_LCD__Cursor
#define FCD_0f9e1_lcd_16x2__Command FCD_04071_LCD__Command
#define FCD_0f9e1_lcd_16x2__PrintFormattedNumber FCD_04071_LCD__PrintFormattedNumber
#define FCD_0f9e1_lcd_16x2__ScrollDisplay FCD_04071_LCD__ScrollDisplay
#define FCD_0f9e1_lcd_16x2__RawSend FCD_04071_LCD__RawSend
#define FCD_0f9e1_lcd_16x2__RemapCharacter FCD_04071_LCD__RemapCharacter
#define FCD_0f9e1_lcd_16x2__Start FCD_04071_LCD__Start
Use :Include the chip adaption layer
#include "C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\includes.c"
Use :shape_cuboid2
:Macro implementations
Use :shape_cuboid1
Use :TimeStamp1
Use :InjectorBase1
Use :COMPort1
Use :fcdhelper
Use :cal_uart
Use :Allows direct control over the TX and RTS pins
   :Also allows for reading of the state of the RX and CTS pins.
   :Only available when the UART is uninitialised.
   :Parameters for macro ControlPin:
   :  Pin : 0=TX, 1=RX, 2=RTS, 3=CTS
   :  State : MX_UINT8
   :Returns : MX_UINT8
//Local variable definitions
MX_UINT8 FCR_RETVAL;
switch (FCL_PIN)
case 1:
#if (1)
    FCR_RETVAL = GET_PORT_PIN(D, 0);
  // #else
  //Code has been optimised out by the pre-processor
  #endif
case 2:
  #if (0)
  // #else
  #endif
case 3:
  #if (0)
  // #else
  #endif
default:
  #if (1)
    if (FCL_STATE)
      SET_PORT_PIN(D, 1, 1);
      SET_PORT_PIN(D, 1, 0);
  // #else
  #endif
return (FCR_RETVAL);
Use :Parameters for macro Prv_TextConsole:
: Str[20] : MX_CHAR (by-ref)
: colour : MX_UINT8
switch (FCL_COLOUR)
case 1:
case 2:
default:
Use :A simple macro to allow us to test the value of a single property during runtime.
:Parameters for macro TestProperty:
: Property : 0=UseTX, 1=UseRX, 2=UseFlowControl
:Returns : MX_UINT8
FCR_RETVAL = 0;
if (FCL_PROPERTY == 0)
#if (1)
  FCR_RETVAL = 1;
// #else
#endif
// } else {
if (FCL_PROPERTY == 1)
#if (1)
  FCR_RETVAL = 1;
// #else
#endif
// } else {
if (FCL_PROPERTY == 2)
#if (0)
// #else
#endif
// } else {
Use :Parameters for macro Prv_SimShowWaveform:
: TXRX : MX_UINT8
: Data : MX_UINT16
if (FCL_TXRX)
SET_PORT_PIN(D, 0, 0);
FCI_DELAYBYTE_US(104);
for (FCLV_LOOP4=0; (FCLV_LOOP4)<(8); (FCLV_LOOP4)++)
  if (FCL_DATA & 0x01)
    SET_PORT_PIN(D, 0, 1);
  FCL_DATA = FCL_DATA >> 1;
for (FCLV_LOOP3=0; (FCLV_LOOP3)<(8); (FCLV_LOOP3)++)
Use :Bluetooth_HC05
Use :Sets the Bluetooth pair key stored in the Bluetooth module's ROM.
   :Commands must be sent before Bluetooth communications are estabished e.g. right after power on and initialisation.
   :Parameters for macro SetPairKey:
   :  Key[5] : Four digit pair key e.g. "0000" or "1234"
#define FCLsz_COMMAND 28
MX_CHAR FCL_COMMAND[FCLsz_COMMAND];
#define FCLsz_KEY 5
MX_CHAR FCL_KEY[FCLsz_KEY];
FCI_CONCATENATE(PFCL_KEY,FCLsz_KEY,"",0,FCL_KEY,FCLsz_KEY);
FCI_SHEAD("AT+PIN",7, FCL_KEY,FCLsz_KEY, FCL_COMMAND,28);
FCD_07aa1_Bluetooth_HC05__SendCommand(FCL_COMMAND, FCLsz_COMMAND);
#undef FCLsz_COMMAND
#undef FCLsz_KEY
Use :Sends out a string of bytes from the UART interface.
:Parameters for macro SendString:
: Data[20] : MX_CHAR (by-ref)
MX_UINT8 FCL_LEN;
MX_UINT8 FCL_IDX;
FCL_LEN = FCI_GETLENGTH(FCL_DATA, FCLsz_DATA);
FCL_IDX = 0;
while (FCL_IDX < FCL_LEN)
FC_CAL_UART_Send_1(FCL_DATA[FCL_IDX]);
FCL_IDX = FCL_IDX + 1;
Use :Sends a command string to the HC05/HC06 module.
:Parameters for macro SendCommand:
: Command[28] : MX_CHAR (by-ref)
for (FCLV_LOOP1=0; (FCLV_LOOP1)<(10); (FCLV_LOOP1)++)
FCD_07aa1_Bluetooth_HC05__ReceiveChar(1);
FCD_07aa1_Bluetooth_HC05__SendString(FCL_COMMAND, FCLsz_COMMAND);
FCD_07aa1_Bluetooth_HC05__SendChar('\r');
FCD_07aa1_Bluetooth_HC05__SendChar('\n');
for (FCLV_LOOP2=0; (FCLV_LOOP2)<(50); (FCLV_LOOP2)++)
Use :Sets the Bluetooth baud rate stored in the Bluetooth module's ROM.
   :Parameters for macro SetBaud:
   :  Baud : 1=1200, 2=2400, 3=4800, 4=9600, 5=19200, 6=NA, 7=38400, 8=57600, 9=115200
if (FCL_BAUD > 0)
if (FCL_BAUD < 10)
  if (FCL_BAUD == 6)
    if (FCL_BAUD > 6)
      FCI_SHEAD("AT+BAUD",8, FCI_TOSTRING(FCL_BAUD - 1, FCI_TMP_STR,20),20, FCL_COMMAND,28);
      FC_CAL_UART_UpdateBaud_1(FCL_BAUD);
      FCI_SHEAD("AT+BAUD",8, FCI_TOSTRING(FCL_BAUD, FCI_TMP_STR,20),20, FCL_COMMAND,28);
// } else {
// } else {
Use :Sends out a number as an ASCII String from the UART interface.
:Parameters for macro SendNumber:
: Number : MX_SINT32 (by-ref)
#define FCLsz_NUMSTR 20
MX_CHAR FCL_NUMSTR[FCLsz_NUMSTR];
FCI_TOSTRING(FCL_NUMBER, FCL_NUMSTR,20);
FCD_07aa1_Bluetooth_HC05__SendString(FCL_NUMSTR, FCLsz_NUMSTR);
#undef FCLsz_NUMSTR
Use :Sends out a single packet from the UART interface.
:Parameters for macro SendChar:
: Char : MX_SINT16
FC_CAL_UART_Send_1(FCL_CHAR);
Use :Sets the Bluetooth Friendly name stored in the Bluetooth module's ROM.
   :Parameters for macro SetName:
   :  Name[20] : Name you wish to provide to the module
#define FCLsz_NAME 20
MX_CHAR FCL_NAME[FCLsz_NAME];
FCI_CONCATENATE(PFCL_NAME,FCLsz_NAME,"",0,FCL_NAME,FCLsz_NAME);
FCI_SHEAD("AT+NAME",8, FCL_NAME,FCLsz_NAME, FCL_COMMAND,28);
#undef FCLsz_NAME
Use :Attempts to receive a string of bytes from the UART interface.
:Parameters for macro ReceiveString:
: Timeout : MX_UINT8
: NumBytes : MX_UINT8
:Returns : MX_CHAR*
MX_SINT16 FCL_ERRORVAL;
MX_UINT8 FCL_CHCOUNT = (0x0);
MX_SINT16 FCL_RETVAL;
MX_UINT8 FCL_CH;
while (FCL_CHCOUNT < FCL_NUMBYTES)
FCL_RETVAL = FC_CAL_UART_Receive_1(FCL_TIMEOUT);
if (FCL_RETVAL < 255)
  FCL_CH = FCL_RETVAL & 0xff;
  FCR_RETVAL[FCL_CHCOUNT] = FCL_CH;
  FCL_CHCOUNT = FCL_CHCOUNT + 1;
  FCR_RETVAL[FCL_CHCOUNT] = 0;
  FCL_CHCOUNT = FCL_NUMBYTES;
Use :Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
Use :Attempts to receive a single packet from the UART interface.
:Parameters for macro ReceiveChar:
: Timeout : Time to wait for valid data before returning, 0=Dont wait, 255=Wait forever.
:Returns : MX_SINT16
MX_SINT16 FCR_RETVAL;
FCR_RETVAL = FC_CAL_UART_Receive_1(FCL_TIMEOUT);
Use :motion_helper1
Use :motor_base1
Use :ctrl_lcd
Use :LCD
Use :Clears the entire contents of the display.
FCD_04071_LCD__RawSend(0x01, 0);
FCI_DELAYBYTE_MS(2);
FCD_04071_LCD__RawSend(0x02, 0);
Use :Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro
:Parameters for macro PrintString:
: Text[20] : Enter the text or variable to print to the LCD
MX_UINT8 FCL_IDX = (0x0);
MX_UINT8 FCL_COUNT;
FCL_COUNT = FCI_GETLENGTH(FCL_TEXT, FCLsz_TEXT);
while (FCL_IDX < FCL_COUNT)
#if (0) // 0 > 0
#else
  FCD_04071_LCD__RawSend(FCL_TEXT[FCL_IDX], 0x10);
#endif
Use :Takes the ascii value for a character and prints the character
:Parameters for macro PrintAscii:
: character : Holds an ascii value.
FCD_04071_LCD__RawSend(FCL_CHARACTER, 0x10);
Use :Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
:Parameters for macro PrintNumber:
: Number : Enter the number or variable to print to the LCD
#define FCLsz_S 10
MX_CHAR FCL_S[FCLsz_S];
FCI_TOSTRING(FCL_NUMBER, FCL_S,10);
FCD_04071_LCD__PrintString(FCL_S, FCLsz_S);
#undef FCLsz_S
Use :Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory
:Parameters for macro RAMWrite:
: Index : Values 0 to 7
: d0 : MX_UINT8
: d1 : MX_UINT8
: d2 : MX_UINT8
: d3 : MX_UINT8
: d4 : MX_UINT8
: d5 : MX_UINT8
: d6 : MX_UINT8
: d7 : MX_UINT8
FCD_04071_LCD__RawSend(64 + (FCL_INDEX << 3), 0);
FCD_04071_LCD__RawSend(FCL_D0, 0x10);
FCD_04071_LCD__RawSend(FCL_D1, 0x10);
FCD_04071_LCD__RawSend(FCL_D2, 0x10);
FCD_04071_LCD__RawSend(FCL_D3, 0x10);
FCD_04071_LCD__RawSend(FCL_D4, 0x10);
FCD_04071_LCD__RawSend(FCL_D5, 0x10);
FCD_04071_LCD__RawSend(FCL_D6, 0x10);
FCD_04071_LCD__RawSend(FCL_D7, 0x10);
Use :Clears a single line on the display and then moves the cursor to the start of the line to allow you to start populating the line with data.
:Parameters for macro ClearLine:
: Line : The line to clear, zero being the first (top) line of the display
MX_UINT8 FCL_X;
if (FCL_LINE < 2)
FCD_04071_LCD__Cursor(0, FCL_LINE);
FCL_X = 0;
while (FCL_X < 16)
  FCD_04071_LCD__RawSend(' ', 0x10);
  FCL_X = FCL_X + 1;
// } else {
Use :Moves the cursor on the LCD Display
:Parameters for macro Cursor:
: x : Set the cursor position in the X plane, 0 is the left most cell
: y : Set the cursor position in the Y plane, 0 is the top most cell
#if (0) // 2 == 1
// #else
#endif
#if (1) // 2 == 2
if (FCL_Y == 0)
  FCL_Y = 0x80;
  FCL_Y = 0xC0;
// #else
#endif
#if (0) // 2 == 4
// #else
#endif
FCD_04071_LCD__RawSend(FCL_Y + FCL_X, 0);
Use :Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet.
:Parameters for macro Command:
: instruction : Send a defined command to the LCD Screen. See datasheet for supported commands.
FCD_04071_LCD__RawSend(FCL_INSTRUCTION, 0);
Use :Will allow you to print a number up to 32-bits with signed or unsigned formatting.
   :Signed = -2147483648 to 2147483647
   :Unsigned = 0 to 4294967295
   :Parameters for macro PrintFormattedNumber:
   :  Format : 0=Signed, 1=Unsigned
#define FCLsz_S 15
if (FCL_FORMAT == 1)
FCI_UTOS32(FCL_NUMBER, FCL_S,15);
FCI_ITOS32((MX_SINT32)(FCL_NUMBER), FCL_S,15);
#undef FCLsz_S
Use :Scrolls the display left or right by a number of given positions.
:Parameters for macro ScrollDisplay:
: Position : Holds the number of positions to shift the display
: Direction : 0 = left, 1 = right
MX_UINT8 FCL_CMD = (0x0);
FCL_CMD = 0;
if (FCL_DIRECTION == 0)
FCL_CMD = 0x18;
FCL_CMD = 0x1C;
if (FCL_CMD != 0 && FCL_POSITION != 0)
while (FCL_POSITION != 0)
  FCD_04071_LCD__RawSend(FCL_CMD, 0);
  FCL_POSITION = FCL_POSITION - 1;
// } else {
Use :Sends data to the LCD display
:Parameters for macro RawSend:
: data : The data byte to send to the LCD
: type : A boolean to indicate command type: true to write data, false to write a command
MX_UINT8 FCL_NIBBLE;
//Comment:
//Output upper nibble of the byte
#if (1) // 0 == 0
SET_PORT_PIN(B, 0, 0);
SET_PORT_PIN(B, 1, 0);
SET_PORT_PIN(B, 2, 0);
SET_PORT_PIN(B, 3, 0);
SET_PORT_PIN(B, 4, 0);
SET_PORT_PIN(B, 5, 0);
#if (0)
// #else
#endif
FCL_NIBBLE = (FCL_DATA >> 4);
SET_PORT_PIN(B, 0, (FCL_NIBBLE & 0x01));
FCL_NIBBLE = FCL_NIBBLE >> 1;
SET_PORT_PIN(B, 1, (FCL_NIBBLE & 0x01));
SET_PORT_PIN(B, 2, (FCL_NIBBLE & 0x01));
SET_PORT_PIN(B, 3, (FCL_NIBBLE & 0x01));
// #else
#endif
//Comment:
//Output byte to pins
#if (0) // 0 == 1
// #else
#endif
//Comment:
//Output byte to port
#if (0) // 0 == 2
// #else
#endif
if (FCL_TYPE)
SET_PORT_PIN(B, 4, 1);
// } else {
FCI_DELAYBYTE_US(100);
//Comment:
//Set Enable high, pause then set low
//to acknowledge the data has been
//submitted.
SET_PORT_PIN(B, 5, 1);
#if (1) // 0 == 0
FCL_NIBBLE = (FCL_DATA & 0xf);
if (FCL_TYPE)
// } else {
// #else
#endif
Use :Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters.
   :The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
   :Parameters for macro RemapCharacter:
   :  RemapIdx : Remap Index, Range: 0 to (Remap Characters - 1)
   :  SearchCharacter : Character to look for a replace
   :  ReplacementCharacter : New character value to use in place of the search character.
#if (0) // 0 > 0
// #else
#endif
Use :Startup routine required by the hardware device.
   :Automatically clears the display after initialising.
#if (1) // 0 == 0
// #else
#endif
#if (0) // 0 == 1
// #else
#endif
#if (0) // 0 == 2
// #else
#endif
#if (0)
// #else
#endif
FCI_DELAYBYTE_MS(12);
FCD_04071_LCD__RawSend(0x33, 0);
#if (0) // 0 > 0
#else
FCD_04071_LCD__RawSend(0x32, 0);
FCD_04071_LCD__RawSend(0x2c, 0);
#endif
FCD_04071_LCD__RawSend(0x06, 0);
FCD_04071_LCD__RawSend(0x0c, 0);
#if (0) // 0 > 0
// #else
#endif
Use :lcd_16x2
Use :panel
Use :Main
int main()
MCUSR=0x00;
// Name: Call Component Macro, Type: Call Component Macro: lcd_16x2::Start()
FCD_0f9e1_lcd_16x2__Start();
// Name: Call Component Macro, Type: Call Component Macro: lcd_16x2::Cursor(4, 0)
FCD_0f9e1_lcd_16x2__Cursor(4, 0);
// Name: Call Component Macro, Type: Call Component Macro: lcd_16x2::PrintString("piso 1")
FCD_0f9e1_lcd_16x2__PrintString("piso 1", 7);
// Name: Call Component Macro, Type: Call Component Macro: Bluetooth_HC05::Initialise()
// Name: Loop, Type: Loop: While 1
while (1)
// Name: Call Component Macro, Type: Call Component Macro: DATO=Bluetooth_HC05::ReceiveChar(30)
FCV_DATO = FCD_07aa1_Bluetooth_HC05__ReceiveChar(30);
// Name: Switch, Type: Switch: DATO?
switch (FCV_DATO)
  case 'A':
    // Name: Calculation, Type: Calculation:
    // Name: Calculation, Type:  conta = 1
    FCV_CONTA = 1;
  case 'B':
    // Name: Calculation, Type:  conta = 2
    FCV_CONTA = 2;
  case 'C':
    // Name: Calculation, Type:  conta = 3
    FCV_CONTA = 3;
  // default:
// Name: Decision, Type: Decision: conta > pisoactual?
if (FCV_CONTA > FCV_PISOACTUAL)
  // Name: Calculation, Type:  movimiento = conta - pisoactual
  FCV_MOVIMIENTO = FCV_CONTA - FCV_PISOACTUAL;
  // Name: Call Component Macro, Type: Call Component Macro: lcd_16x2::Clear()
  FCD_0f9e1_lcd_16x2__Clear();
  // Name: Output, Type: Output: 1 -> C1
  SET_PORT_PIN(C,1,(1));
  // Name: Output, Type: Output: 0 -> C0
  SET_PORT_PIN(C,0,(0));
  // Name: Call Component Macro, Type: Call Component Macro: lcd_16x2::PrintString("subiendo")
  FCD_0f9e1_lcd_16x2__PrintString("subiendo", 9);
  // Name: Delay, Type: Delay: 4 * movimiento s
  FCI_DELAYBYTE_S(4 * FCV_MOVIMIENTO);
  // Name: Output, Type: Output: 0 -> C1
  SET_PORT_PIN(C,1,(0));
  // Name: Calculation, Type:  pisoactual = conta
  FCV_PISOACTUAL = FCV_CONTA;
// } else {
// Name: Decision, Type: Decision: pisoactual == 2?
if (FCV_PISOACTUAL == 2)
  // Name: Call Component Macro, Type: Call Component Macro: lcd_16x2::PrintString("piso 2")
  FCD_0f9e1_lcd_16x2__PrintString("piso 2", 7);
// } else {
// Name: Decision, Type: Decision: pisoactual == 3?
if (FCV_PISOACTUAL == 3)
  // Name: Call Component Macro, Type: Call Component Macro: lcd_16x2::PrintString("piso 3")
  FCD_0f9e1_lcd_16x2__PrintString("piso 3", 7);
// } else {
// Name: Decision, Type: Decision: pisoactual == 1?
if (FCV_PISOACTUAL == 1)
// } else {
// Name: Decision, Type: Decision: conta < pisoactual?
if (FCV_CONTA < FCV_PISOACTUAL)
  // Name: Calculation, Type:  movimiento = pisoactual - conta
  FCV_MOVIMIENTO = FCV_PISOACTUAL - FCV_CONTA;
  // Name: Output, Type: Output: 1 -> C0
  SET_PORT_PIN(C,0,(1));
  // Name: Call Component Macro, Type: Call Component Macro: lcd_16x2::PrintString("bajando")
  FCD_0f9e1_lcd_16x2__PrintString("bajando", 8);
// } else {
mainendloop: goto mainendloop;
Use :Interrupt
Wow, that is a lot of code ...
Arduino code is equal to C code. Only the main() function is usually hidden. Instead of main() there is setup () and loop().
There is a way to get rid of this and maybe you should try. There are some threads on this subject on this forum (maybe you can find it yourself).
Otherwise you can put your main code in setup and leave loop empty.
Yeahhhh it's a lot of code cause I used flowcodev8 to make it and then copy-pasted the Flowcode C code to arduino.
so is C code the same as arduino? i didn't know. Thanks, I'll check other threads to see if i can change some stuff here
Ah, that explains the highly unusual formatting of your code...
Hope it will work immediately, because debugging machine generated code might be difficult...
I hope you’ve been paying attention during your lessons.
Arduinos use C/C++ as they stand when using the IDE and gcc compiler.
However, that’s quite a stretch for a beginner to port across to any micro as it is.
Better you ask the teacher to help, or perhaps choose a different line of study.
Yeah idk how to write in C or C++ yet. what i did was take the flowcode C code and copy paste it in arduino lol
x
@isaaconalpha
why have you posted your question as TUTORIAL for others?
when you edit your post title, you can assign a better suited section.
Furthermore, please edit your entry post, and use code-tags like described in the forum how to.
Sorry its my first post i didn't notice
I think you need to start by getting a requirements specification of the system
this will identify the basic functionality of the system and hardware required
this would give you some idea of the microcontroller required, e.g. Arduino UNO, Mega, ESP32 or possibly a Raspberry pI???
the code of post #1 was for an existing system - what was the microcontroller used?
over 1500 lines of source is excessive
  • need to recognize buttons
  • list (bitmap) of floors to stop at
  • determine when to move and in which direction
  • stop at all floors being reached when moving in a particular direction and reverse direction when no other floors in that direction beyond the current floor or stop if list empty
Looking at the flowcode website, looks like V9 has the ability to generate arduino code, but your instructor may prefer you actually learn to write code for the arduino yourself.
Please edit your post to add code tags.
