Greetings to everyone! I'll say sorry in advance for my bad English but I hope you can understand me.
I'm new here in this forum and I'm having a problem with my project. I wanted to do a nested ifs in my code. My code compiled and uploads fine. But the problem is my nested ifs. The conditions in my 1st if met and the statements worked fine but an if statement inside won't work. I hope you can help me solve this problem. By the way, here's the code:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7,3,POSITIVE); // 0x27 is the I2C bus address for an unmodified backpack
#define IN1 22
#define IN2 24
#define IN3 26
#define IN4 28
#define ENA 2
#define ENB 3
int echo_left = 37;
int trig_left = 39;
int echo_right = 41;
int trig_right = 43;
int echo_front = 45;
int trig_front = 47;
long duration, SensorLeft, SensorRight, SensorFront;
volatile float maxDistance = 3;
int LineTrackRight;
int LineTrackLeft;
int LineTrackCenter;
void MotorForward() {
analogWrite (ENA, 150);
analogWrite (ENB, 150);
digitalWrite (IN1, HIGH);
digitalWrite (IN2, LOW);
digitalWrite (IN3, HIGH);
digitalWrite (IN4, LOW);
void MotorBackward() {
digitalWrite (IN1, LOW);
digitalWrite (IN2, HIGH);
digitalWrite (IN3, LOW);
digitalWrite (IN4, HIGH);
void MotorRadialLeftTurn() {
analogWrite (ENB, 0);
void MotorAxialRightTurn() {
void MotorAxialRightTurnLow() {
analogWrite (ENA, 90);
analogWrite (ENB, 90);
void MotorAxialLeftTurn() {
void MotorAxialLeftTurnLow() {
void MotorRadialRightTurn() {
analogWrite (ENA, 0);
void MotorStop() {
void CheckSensorLeft() {
digitalWrite(trig_left, LOW);
delayMicroseconds(5);
digitalWrite(trig_left, HIGH);
delayMicroseconds(10);
duration = pulseIn(echo_left, HIGH);
SensorLeft = (duration/2) / 74;
void CheckSensorFront() {
digitalWrite(trig_front, LOW);
digitalWrite(trig_front, HIGH);
duration = pulseIn(echo_front, HIGH);
SensorFront = (duration/2) / 74;
void setup(){
lcd.begin (20, 4);
pinMode (31, INPUT);
pinMode (33, INPUT);
pinMode (35, INPUT);
pinMode (IN1, OUTPUT);
pinMode (IN2, OUTPUT);
pinMode (IN3, OUTPUT);
pinMode (IN4, OUTPUT);
pinMode (ENA, OUTPUT);
pinMode (ENB, OUTPUT);
pinMode (echo_left, INPUT);
pinMode (trig_left, OUTPUT);
pinMode (echo_right, INPUT);
pinMode (trig_right, OUTPUT);
pinMode (echo_front, INPUT);
pinMode (trig_front, OUTPUT);
void loop(){
CheckSensorFront();
LineTrackLeft = digitalRead(35);
LineTrackCenter = digitalRead(33);
LineTrackRight = digitalRead(31);
if ((LineTrackLeft == 0 && LineTrackRight == 0 && LineTrackCenter == 1)){
MotorForward();
else if ((LineTrackLeft == 1 && LineTrackRight == 0 && LineTrackCenter == 0) || (LineTrackLeft == 1 && LineTrackRight == 0 && LineTrackCenter == 1)){
MotorRadialLeftTurn();
else if ((LineTrackLeft == 0 && LineTrackRight == 1 && LineTrackCenter == 0) || (LineTrackLeft == 0 && LineTrackRight == 1 && LineTrackCenter == 1)){
MotorRadialRightTurn();
CheckSensorLeft();
if(SensorLeft <= maxDistance){
MotorAxialLeftTurnLow();
if (SensorFront <= maxDistance){
MotorStop();
delay(5000);
