I'll try this thanks!
usually get continuous garbage printing when baud rate is wrong or there is noise on the GPIO input
Wrong voltage for the Tx/Rx pins - if any - might also play a role as well as available power for the module.
what happens if you switch off the 5V external power supply to the modem and just power the ESP32 via USB - do you still get garbage printed?
you need the datasheet on the SIMA7670E modem!
Understand that you may have eliminated a possibility. That’s a positive move.
Often troubleshooting amounts to eliminating unknowns (even removing code sections) to get down to the real bug.
Garbled serial is usually a transmit-and-receive problem, like when the sketch codes for115200 and serial monitor is set for 9600. It’s a quick and easy check/fix.
PS – after reading the thread it looks like you hit another Q&E problem…. your settings may still not match! But I bet a dollar that you’ll double-check that before you run it again!
your code really help me a lot especially I got confused how every works but with trial and error I realize that it work at pin 16 and 17. Retry using the 18, 19 but produces garbage thank you guys!
My ESP32 TX and RX as far as I know produces 3.3V making it compatible to the A7670E, so I didn't use level shifter but yeah thank you also for helping me! appreciated it man!
shows the problem of the lack of technical documentation with this module
I looked on Amazon and Ebay - lots of these modules - nice pictures and lots of sales talk - but no technical documentation
Yes bro
, I've been figuring this our for a week ![]()
I also don't see any datasheet specified for a7670e at SimCom website ![]()
lot of information SIMCOM A7670X product details
however, that would only cover the A7600X which it fitted to a PCB module along with other components - it is the datasheet on the finished PCB module which is required
I am facing the same issue,can you tell me what changed did you do apart from 16,17 pins?
im having the same problem, can you give me the code sketch and the wiring diagram of it?
