I just want to save the positions so when it is powered off and then on it will remember where it is . could u help me out . I don't understand coding . please help if u can . thanks
#include <JC_Button.h>
#include <Encoder.h>
#include <EEPROM.h>
String readString;
const int RELAY = {30,31,32,33,34,35,36,37}; //RELAY[0] and RELAY[1] to access the pins 29 &27 is forward , 30 ,32 is backward ,
const int BTN_EXTEND = 4;
const int BTN_RETRACT = 5;
const uint8_t MANUAL = 1; //a constant to indicate manual mode
const uint8_t AUTOMATIC = 2; //a constant to indicate automatic mode
const int BTN_MEM_PIN = {8,9,10};
const int BTN_SET_MEM = 11;
const int LED = {39,40,41};
//Set up the linear actuator encoder
//On many of the Arduino boards pins 2 and 3 are interrupt pins
// which provide the best performance of the encoder data.
Encoder myEnc(2, 3);
long oldPosition = -999;
long targetPosition = 0;
#define ACCURACY 100 //How close to your target position is close enough. Higher accuracy may result in
// a bit of jitter as the actuator nears the position
#define DEBOUNCE_MS 10 //A debounce time of 20 milliseconds usually works well for tactile button switches.
#define PULLUP true //To keep things simple, we use the Arduino's internal pullup resistor.
#define INVERT true //Since the pullup resistor will keep the pin high unless the
//switch is closed, this is negative logic, i.e. a high state
//means the button is NOT pressed. (Assuming a normally open switch.)
uint8_t MODE = MANUAL;
Button btnExtend(BTN_EXTEND, PULLUP, INVERT, DEBOUNCE_MS);
Button btnRetract(BTN_RETRACT, PULLUP, INVERT, DEBOUNCE_MS);
Button btnSetPos(BTN_SET_MEM, PULLUP, INVERT, DEBOUNCE_MS);
Button btnPos1(BTN_MEM_PIN[0], PULLUP, INVERT, DEBOUNCE_MS);
Button btnPos2(BTN_MEM_PIN[1], PULLUP, INVERT, DEBOUNCE_MS);
Button btnPos3(BTN_MEM_PIN[2], PULLUP, INVERT, DEBOUNCE_MS);
long memPosition = {0,0,0};
pinMode(RELAY[0], OUTPUT);
pinMode(RELAY[1], OUTPUT);
pinMode(RELAY[2], OUTPUT);
pinMode(RELAY[3], OUTPUT);
pinMode(RELAY[4], OUTPUT);
pinMode(RELAY[5], OUTPUT);
pinMode(RELAY[6], OUTPUT);
pinMode(RELAY[7], OUTPUT);
pinMode(LED[0], OUTPUT);
btnExtend.read();
btnRetract.read();
btnSetPos.read();
btnPos1.read();
btnPos2.read();
btnPos3.read();
if (btnExtend.isPressed()) {
extendActuator();
MODE = MANUAL;
if (btnRetract.isPressed()) {
retractActuator();
MODE = MANUAL;
if (!btnExtend.isPressed() && !btnRetract.isPressed() && MODE == MANUAL) {
stopActuator();
MODE = MANUAL;
if(btnPos1.wasReleased()) {
Serial.println("btnPos1");
MODE = AUTOMATIC;
targetPosition = memPosition[0];
if(btnPos2.wasReleased()) {
Serial.println("btnPos2");
MODE = AUTOMATIC;
targetPosition = memPosition[1];
if(btnPos3.wasReleased()) {
Serial.println("btnPos3");
MODE = AUTOMATIC;
targetPosition = memPosition[2];
//check the encoder to see if the position has changed
long newPosition = myEnc.read();
if (newPosition != oldPosition) {
oldPosition = newPosition;
Serial.println(newPosition);
if(MODE == AUTOMATIC && newPosition != targetPosition) {
Serial.print("Target/Actual:");Serial.print(targetPosition);Serial.print(" / ");Serial.print(newPosition);Serial.print(" [");Serial.print(abs(targetPosition - newPosition));Serial.println("]");
if(targetPosition < newPosition) {
Serial.println("AUTO RETRACT");
retractActuator();
MODE = AUTOMATIC;
if(targetPosition > newPosition) {
Serial.println("AUTO EXTEND");
extendActuator();
MODE = AUTOMATIC;
if( (targetPosition == newPosition) || abs(targetPosition - newPosition) <= ACCURACY) {
Serial.println("AUTO STOP");
stopActuator();
MODE = MANUAL;
if(btnSetPos.isPressed()) {
if(btnPos1.isPressed())
memPosition[0] = newPosition;
if(btnPos2.isPressed())
memPosition[1] = newPosition;
if(btnPos3.isPressed())
memPosition[2] = newPosition;
void extendActuator() {
//Serial.println("extendActuator");
digitalWrite(RELAY[0], HIGH);
digitalWrite(RELAY[1], LOW);
digitalWrite(RELAY[2], HIGH);
digitalWrite(RELAY[3], LOW);
void retractActuator() {
//Serial.println("retractActuator");
digitalWrite(RELAY[0], LOW);
digitalWrite(RELAY[1], HIGH);
digitalWrite(RELAY[2], LOW);
digitalWrite(RELAY[3], HIGH);
void stopActuator() {
//Serial.println("stopActuator");
digitalWrite(RELAY[4], HIGH);
digitalWrite(RELAY[5], HIGH);
digitalWrite(RELAY[6], HIGH);
digitalWrite(RELAY[7], HIGH);
digitalWrite(LED[0], LOW);
