I've bought an ESP32 board from here and a 3.5" TFT Screen from here. The ESP32 board has an UNO type layout so I thought it would work with the screen which is designed to plug in and play with Arduino UNOs.
However upon plugging the board and shield together (they fit perfectly, each pin goes in a corresponding slot), loading one of the example scripts (provided on the 3.5" Screen .rar download on the page), set Arduino to use ESP32 Development Board on COM3 (my usual settings for the ESP32) and uploading the code I just get a white screen on the TFT.
Upon trying with a regular UNO hte example works perfectly, so I have realised that the issue may be the connection between the two boards.
Is there some accommodation that I have to make because my board is not an UNO but instead a ESP32, i.e. is the pin layout different so maybe I'll need to wire this manually? I have plenty of jumper wires so I can manually change the pin connections physically. Is it possible to get this working?
I would have included the pin out diagrams below but the forum doesn't allow it as I am a new user, the info is in the product links about. Tho I will see if I can post the info in a reply.
EDIT: Here is the error message I get
Unknown LCD driver chip: D3D3 If using the Adafruit 2.8" TFT Arduino shield, the line: #define USE_ADAFRUIT_SHIELD_PINOUT should appear in the library header (Adafruit_TFT.h). If using the breakout board, it should NOT be #defined! Also if using the breakout, double-check that all wiring matches the tutorial. Benchmark Time (microseconds) Screen fill 1386975 Text 52997
Arduino Sketch Code:
#include <MCUFRIEND_kbv.h>
#include <Adafruit_GFX.h> // Core graphics library
// wiring with UNO or Mega2560:
//--------------POWER Pins--------------------------------
// 5V connects to DC 5V
// GND connects to Ground
// 3V3 do not need to connect(NC)
//--------------LCD Display Pins--------------------------
// LCD_RD connects to Analog pin A0
// LCD_WR connects to Analog pin A1
// LCD_RS connects to Analog pin A2
// LCD_CS connects to Analog pin A3
// LCD_RST connects to Analog pin A4
// LCD_D0 connects to digital pin 8
// LCD_D1 connects to digital pin 9
// LCD_D2 connects to digital pin 2
// LCD_D3 connects to digital pin 3
// LCD_D4 connects to digital pin 4
// LCD_D5 connects to digital pin 5
// LCD_D6 connects to digital pin 6
// LCD_D7 connects to digital pin 7
//--------------SD-card fuction Pins ----------------------
//This Connection Only for UNO, Do not support Mega2560
//because they use different Hardware-SPI Pins
//SD_SS connects to digital pin 10
//SD_DI connects to digital pin 11
//SD_DO connects to digital pin 12
//SD_SCK connects to digital pin 13
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
MCUFRIEND_kbv tft;
unsigned long testFillScreen() {
unsigned long start = micros();
tft.fillScreen(BLACK);
tft.fillScreen(RED);
tft.fillScreen(GREEN);
tft.fillScreen(BLUE);
return micros() - start;
unsigned long testText() {
tft.setCursor(0, 0);
tft.setTextColor(WHITE); tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(YELLOW); tft.setTextSize(2);
tft.println(1234.56);
tft.setTextColor(RED); tft.setTextSize(3);
tft.println(0xDEADBEEF, HEX);
tft.println();
tft.setTextColor(GREEN);
tft.setTextSize(5);
tft.println("Groop");
tft.setTextSize(2);
tft.println("I implore thee,");
tft.setTextSize(1);
tft.println("my foonting turlingdromes.");
tft.println("And hooptiously drangle me");
tft.println("with crinkly bindlewurdles,");
tft.println("Or I will rend thee");
tft.println("in the gobberwarts");
tft.println("with my blurglecruncheon,");
tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
unsigned long start, t;
int x1, y1, x2, y2,
w = tft.width(),
h = tft.height();
x1 = y1 = 0;
y2 = h - 1;
start = micros();
for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
x2 = w - 1;
for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
t = micros() - start; // fillScreen doesn't count against timing
x1 = w - 1;
y1 = 0;
y2 = h - 1;
start = micros();
x2 = 0;
t += micros() - start;
x1 = 0;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = w - 1;
x1 = w - 1;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = 0;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
unsigned long start;
int x, y, w = tft.width(), h = tft.height();
start = micros();
for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
int n, i, i2,
cx = tft.width() / 2,
cy = tft.height() / 2;
n = min(tft.width(), tft.height());
start = micros();
for(i=2; i<n; i+=6) {
i2 = i / 2;
tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
unsigned long start, t = 0;
int n, i, i2,
cx = tft.width() / 2 - 1,
cy = tft.height() / 2 - 1;
for(i=n; i>0; i-=6) {
i2 = i / 2;
start = micros();
tft.fillRect(cx-i2, cy-i2, i, i, color1);
// Outlines are not included in timing results
tft.drawRect(cx-i2, cy-i2, i, i, color2);
return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
start = micros();
for(x=radius; x<w; x+=r2) {
for(y=radius; y<h; y+=r2) {
tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
int x, y, r2 = radius * 2,
w = tft.width() + radius,
h = tft.height() + radius;
// Screen is not cleared for this one -- this is
// intentional and does not affect the reported time.
start = micros();
for(x=0; x<w; x+=r2) {
for(y=0; y<h; y+=r2) {
tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
int n, i, cx = tft.width() / 2 - 1,
n = min(cx, cy);
start = micros();
for(i=0; i<n; i+=5) {
tft.drawTriangle(
cx , cy - i, // peak
cx - i, cy + i, // bottom left
cx + i, cy + i, // bottom right
tft.color565(0, 0, i));
unsigned long testFilledTriangles() {
int i, cx = tft.width() / 2 - 1,
start = micros();
for(i=min(cx,cy); i>10; i-=5) {
start = micros();
tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(0, i, i));
tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(i, i, 0));
return t;
unsigned long testRoundRects() {
int w, i, i2,
w = min(tft.width(), tft.height());
start = micros();
for(i=0; i<w; i+=6) {
i2 = i / 2;
tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
int i, i2,
start = micros();
for(i=min(tft.width(), tft.height()); i>20; i-=6) {
i2 = i / 2;
tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
void setup(void) {
Serial.println(F("TFT LCD test"));
tft.reset();
uint16_t identifier = tft.readID();
if(identifier == 0x9325) {
Serial.println(F("Found ILI9325 LCD driver"));
} else if(identifier == 0x9328) {
Serial.println(F("Found ILI9328 LCD driver"));
} else if(identifier == 0x4535) {
Serial.println(F("Found LGDP4535 LCD driver"));
}else if(identifier == 0x7575) {
Serial.println(F("Found HX8347G LCD driver"));
} else if(identifier == 0x9595) {
Serial.println(F("Found HX8347-I LCD driver"));
} else if(identifier == 0x4747) {
Serial.println(F("Found HX8347-D LCD driver"));
} else if(identifier == 0x8347) {
Serial.println(F("Found HX8347-A LCD driver"));
}else if(identifier == 0x9341) {
Serial.println(F("Found ILI9341 LCD driver"));
}else if(identifier == 0x7783) {
Serial.println(F("Found ST7781 LCD driver"));
}else if(identifier == 0x8230) {
Serial.println(F("Found UC8230 LCD driver"));
}else if(identifier == 0x8357) {
Serial.println(F("Found HX8357D LCD driver"));
} else if(identifier==0x0101){
identifier=0x9341;
Serial.println(F("Found 0x9341 LCD driver"));
}else if(identifier==0x7793){
Serial.println(F("Found ST7793 LCD driver"));
}else if(identifier==0xB509){
Serial.println(F("Found R61509 LCD driver"));
}else if(identifier==0x9486){
Serial.println(F("Found ILI9486 LCD driver"));
}else if(identifier==0x9488){
Serial.println(F("Found ILI9488 LCD driver"));
}else {
Serial.print(F("Unknown LCD driver chip: "));
Serial.println(identifier, HEX);
Serial.println(F("If using the Adafruit 2.8\" TFT Arduino shield, the line:"));
Serial.println(F(" #define USE_ADAFRUIT_SHIELD_PINOUT"));
Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
Serial.println(F("If using the breakout board, it should NOT be #defined!"));
Serial.println(F("Also if using the breakout, double-check that all wiring"));
Serial.println(F("matches the tutorial."));
identifier=0x9486;
tft.begin(identifier);
Serial.println(F("Benchmark Time (microseconds)"));
Serial.print(F("Screen fill "));
Serial.println(testFillScreen());
Serial.print(F("Text "));
Serial.println(testText());
delay(3000);
Serial.print(F("Lines "));
Serial.println(testLines(CYAN));
Serial.print(F("Horiz/Vert Lines "));
Serial.println(testFastLines(RED, BLUE));
Serial.print(F("Rectangles (outline) "));
Serial.println(testRects(GREEN));
Serial.print(F("Rectangles (filled) "));
Serial.println(testFilledRects(YELLOW, MAGENTA));
Serial.print(F("Circles (filled) "));
Serial.println(testFilledCircles(10, MAGENTA));
Serial.print(F("Circles (outline) "));
Serial.println(testCircles(10, WHITE));
Serial.print(F("Triangles (outline) "));
Serial.println(testTriangles());
Serial.print(F("Triangles (filled) "));
Serial.println(testFilledTriangles());
Serial.print(F("Rounded rects (outline) "));
Serial.println(testRoundRects());
Serial.print(F("Rounded rects (filled) "));
Serial.println(testFilledRoundRects());
Serial.println(F("Done!"));
void loop(void) {
for(uint8_t rotation=0; rotation<4; rotation++) {
tft.setRotation(rotation);
testText();
delay(2000);
